Getting touch working on the lvgl sample and extending to demonstrate how to capture swipes.
I am trying to get touch working with a nRF5340 DK and a Waveshare 1.69inch Touch LCD Module. I am running nRF Connect for VSC 2.6.1. My goal is to handle swipe left, swipe right, swipe down, swipe up, and long press, similar to this post.
I started with the lvgl display sample, because it seems to support a pointer and touch. I added a build configuration for the nrf5340DK and an overlay. I can't however get the touch working.
I believe I need to add settings to the prj.conf and I have been experimenting, but it would be good to have the setting in there already, even if they are commented out. Here is what I have:
CONFIG_LV_Z_MEM_POOL_SIZE=16384
CONFIG_LV_Z_SHELL=y
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_DISPLAY=y
CONFIG_DISPLAY_LOG_LEVEL_ERR=y
CONFIG_DISPLAY_LOG_LEVEL_INF=y
CONFIG_LOG=y
CONFIG_SHELL=y
CONFIG_LVGL=y
CONFIG_LV_MEM_CUSTOM=y
CONFIG_LV_USE_LOG=y
CONFIG_LV_USE_LABEL=y
CONFIG_LV_USE_BTN=y
CONFIG_LV_USE_ARC=y
CONFIG_LV_USE_IMG=y
CONFIG_LV_USE_MONKEY=y
CONFIG_LV_FONT_MONTSERRAT_16=y
#added to get touch working
CONFIG_INPUT=y
CONFIG_LV_Z_POINTER_INPUT=y
However, I am getting a message on the CONFIG_LV_Z_POINTER_INPUT:
CONFIG_LV_Z_POINTER_INPUT was assigned the value y, but got the value n. Missing dependencies:
(INPUT && DT_HAS_ZEPHYR_LVGL_POINTER_INPUT_ENABLED && LVGL) || (INPUT && DT_HAS_ZEPHYR_LVGL_POINTER_INPUT_ENABLED && LVGL && 0)
In the code main.c as well this code is dimmed in VSC, so clearly this is not set:
#ifdef CONFIG_LV_Z_ENCODER_INPUT
	lv_obj_t *arc;
	lv_group_t *arc_group;
	arc = lv_arc_create(lv_scr_act());
	lv_obj_align(arc, LV_ALIGN_CENTER, 0, 0);
	lv_obj_set_size(arc, 150, 150);
	arc_group = lv_group_create();
	lv_group_add_obj(arc_group, arc);
	lv_indev_set_group(lvgl_input_get_indev(lvgl_encoder), arc_group);
#endif /* CONFIG_LV_Z_ENCODER_INPUT */
So, I guess I need to figure out how to get CONFIG_DT_HAS_ZEPHYR_LVGL_POINTER_INPUT_ENABLED set, which I'm guessing comes from the overlay. There may be additional overlay entries required, but I did set the touch, I think:
&pinctrl {
    spi4_default: spi4_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 0, 6)>,
                <NRF_PSEL(SPIM_MOSI, 0, 25)>;
    spi4_sleep: spi4_sleep {
        group1 {
            low-power-enable;
    // Set to I2C pins that the touch screen is connected to
    i2c2_default: i2c2_default {
        group1 {
            psels = <NRF_PSEL(TWIM_SDA, 1, 2)>,
                <NRF_PSEL(TWIM_SCL, 1, 3)>;
    i2c2_sleep: i2c2_sleep {
        group1 {
            low-power-enable;
&spi4 {
	status = "okay";
	pinctrl-0 = <&spi4_default>;
	pinctrl-1 = <&spi4_sleep>;
	cs-gpios = <&gpio0 11 GPIO_ACTIVE_LOW>;
    st7789v_st7789v_tl019fqv01: st7789v@0 {
        compatible = "sitronix,st7789v";
        spi-max-frequency = <20000000>;
        reg = <0>;
        cmd-data-gpios = < &gpio1 11 GPIO_ACTIVE_LOW>;
        reset-gpios = < &gpio1 10 GPIO_ACTIVE_LOW>;
        width = <240>;
        height = <280>;
        x-offset = <0>;
        y-offset = <0>;
        vcom = <0x19>;
        gctrl = <0x35>;
        vrhs = <0x12>;
        vdvs = <0x20>;
        mdac = <0x00>;
        gamma = <0x01>;
        colmod = <0x05>;
        lcm = <0x2c>;
        porch-param = [0c 0c 00 33 33];
        cmd2en-param = [5a 69 02 01];
        pwctrl1-param = [a4 a1];
        pvgam-param = [D0 04 0D 11 13 2B 3F 54 4C 18 0D 0B 1F 23];
        nvgam-param = [D0 04 0C 11 13 2C 3F 44 51 2F 1F 1F 20 23];
        ram-param = [00 F0];
        rgb-param = [CD 08 14];
&i2c2 {
    status = "okay";
    clock-frequency = <I2C_BITRATE_FAST>;
    pinctrl-0 = <&i2c2_default>;
    pinctrl-1 = <&i2c2_sleep>;
    cst816s: cst816s@15 {
        compatible = "hynitron,cst816s";
        reg = <0x15>;
        irq-gpios = <&gpio1 0 GPIO_ACTIVE_LOW>;
        rst-gpios = <&gpio0 20 GPIO_ACTIVE_LOW>;
	fstab {
		compatible = "zephyr,fstab";
		lfs: lfs {
			compatible = "zephyr,fstab,littlefs";
			mount-point = "/lfs";
			partition = <&littlefs_storage>;
			automount;
            read-size = <16>;
			prog-size = <16>;
			cache-size = <64>;
			lookahead-size = <32>;
			block-cycles = <512>;
/delete-node/ &storage_partition;
&mx25r64 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		littlefs_storage: partition@0 {
			label = "littlefs_storage";
			reg = <0x00000000 0x00200000>;
		lvgl_raw_partition: partition@200000 {
			label = "lvgl_raw_partition";
			reg = <0x00200000 0x00200000>;
        settings_partition: partition@400000 {
            label = "settings_partition";
            reg = <0x400000 0x100000 >;
    chosen {
        nordic,pm-ext-flash = &mx25r64;
        zephyr,display = &st7789v_st7789v_tl019fqv01;
        zephyr,keyboard-scan = &cst816s;
    aliases {
        vibrator_pwm = &led0;
    vib_pwr: vib-pwr-ctrl {
        compatible = "regulator-fixed";
        regulator-name = "vib-pwr-ctrl";
        enable-gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>;
I did find the Capacitive Touch on the nRF52 series good background but I'm using lvgl which handles the touch, I believe, and I did not see specifics on getting a demo set up.
  • Hi
    This issue means that LVGL_POINTER_INPUT is not enabled in your devicetree.
    I can see that adafruit 2.8" tft touch shield v2 is one of the supported shield, and when I build the sample for this (-DSHIELD="adafruit_2_8_tft_touch_v2"), it is built correctly.
    We see that CONFIG_LV_Z_POINTER_INPUT=y and CONFIG_DT_HAS_ZEPHYR_LVGL_POINTER_INPUT_ENABLED=y in the compiled configurations (./zephyr/.config).
    These values are coming from the shield as the following snippet is there in the shield .dtsi file:
    lvgl_pointer {
    		compatible = "zephyr,lvgl-pointer-input";
    		input = <&ft5336_adafruit_2_8_tft_touch_v2>;
    		swap-xy;
    		invert-x;
    		invert-y;
    Please compile for one of the supported shields, and have a look at input files and the compiled output files and compare / modify accordingly.
