What's the nRF Connect data format when writing chraracteristics ?
Here is a stacktrace from a device I got using the nRF Connect mobile app on Android.
nRF Connect, 2024-05-11
Device Name (A4:XX:XX:XX:XX:7C)
D 13:40:23.035 [Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0)
E 13:40:23.036 Error 8 (0x8): GATT CONN TIMEOUT
I 13:40:23.036 Disconnected
D 13:40:23.096 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
D 13:40:25.687 gatt.close()
D 13:40:25.691 wait(200)
V 13:40:25.892 Connecting to A4:XX:XX:XX:XX:7C...
D 13:40:25.892 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D 13:40:27.945 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
D 13:40:27.948 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I 13:40:27.948 Connected to A4:XX:XX:XX:XX:7C
D 13:40:27.951 wait(1600ms)
I 13:40:29.080 Connection parameters updated (interval: 20.0ms, latency: 49, timeout: 4000ms)
V 13:40:29.551 Discovering services...
D 13:40:29.551 gatt.discoverServices()
D 13:40:29.560 [Callback] Services discovered with status: 0
I 13:40:29.560 Services discovered
V 13:40:29.564 Generic Access (0x1800)
- Device Name [N R] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
Generic Attribute (0x1801)
- Service Changed [I] (0x2A05)
Client Characteristic Configuration (0x2902)
Device Information (0x180A)
- PnP ID [R] (0x2A50)
Human Interface Device (0x1812)
- Protocol Mode [R WNR] (0x2A4E)
- Boot Keyboard Input Report [N R] (0x2A22)
- Boot Keyboard Output Report [R W WNR] (0x2A32)
- Report [N R] (0x2A4D)
Report Reference (0x2908)
- Report [R W WNR] (0x2A4D)
- Report Map [R] (0x2A4B)
External Report Reference (0x2907)
- HID Information [R] (0x2A4A)
- HID Control Point [WNR] (0x2A4C)
Battery Service (0x180F)
- Battery Level [N R] (0x2A19)
Unknown Service (0c6b000a-2f43-7eb4-0646-e5c28162cf6c)
- Unknown Characteristic [N R] (0c6b000b-2f43-7eb4-0646-e5c28162cf6c)
Characteristic User Description (0x2901)
- Unknown Characteristic [R WNR] (0c6b000c-2f43-7eb4-0646-e5c28162cf6c)
D 13:40:29.564 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
D 13:40:29.568 gatt.setCharacteristicNotification(00002a22-0000-1000-8000-00805f9b34fb, true)
D 13:40:29.569 gatt.setCharacteristicNotification(00002a4d-0000-1000-8000-00805f9b34fb, true)
D 13:40:29.570 gatt.setCharacteristicNotification(00002a4d-0000-1000-8000-00805f9b34fb, true)
D 13:40:29.571 gatt.setCharacteristicNotification(00002a19-0000-1000-8000-00805f9b34fb, true)
D 13:40:29.572 gatt.setCharacteristicNotification(0c6b000b-2f43-7eb4-0646-e5c28162cf6c, true)
V 13:41:08.825 Writing command to characteristic 0c6b000c-2f43-7eb4-0646-e5c28162cf6c
D 13:41:08.825 gatt.writeCharacteristic(0c6b000c-2f43-7eb4-0646-e5c28162cf6c, value=0x30055175145E9E72)
I 13:41:08.838 Data written to 0c6b000c-2f43-7eb4-0646-e5c28162cf6c, value: (0x) 30-05-51-75-14-5E-9E-72
A 13:41:08.838 "(0x) 30-05-51-75-14-5E-9E-72" sent
I 13:41:08.880 Notification received from 0c6b000b-2f43-7eb4-0646-e5c28162cf6c, value: (0x) 30-05-51-01-00-00-00-F5
A 13:41:08.880 "(0x) 30-05-51-01-00-00-00-F5" received
V 13:41:38.927 Writing command to characteristic 0c6b000c-2f43-7eb4-0646-e5c28162cf6c
D 13:41:38.927 gatt.writeCharacteristic(0c6b000c-2f43-7eb4-0646-e5c28162cf6c, value=0x2111000000000000000000000000000000000000)
I 13:41:38.932 Data written to 0c6b000c-2f43-7eb4-0646-e5c28162cf6c, value: (0x) 21-11-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
A 13:41:38.932 "(0x) 21-11-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00" sent
I 13:41:39.042 Notification received from 0c6b000b-2f43-7eb4-0646-e5c28162cf6c, value: (0x) 21-12-00-00-0A-D7-A3-3C-C3-F5-A8-3E-00-00-80-3F-00-00-00-00
A 13:41:39.042 "(0x) 21-12-00-00-0A-D7-A3-3C-C3-F5-A8-3E-00-00-80-3F-00-00-00-00" received
I 13:41:39.061 Notification received from 0c6b000b-2f43-7eb4-0646-e5c28162cf6c, value: (0x) 21-12-00-01-C3-F5-A8-3E-00-00-80-3F-00-00-00-00-7B-14-AE-3E
A 13:41:39.061 "(0x) 21-12-00-01-C3-F5-A8-3E-00-00-80-3F-00-00-00-00-7B-14-AE-3E" received
I 13:41:39.062 Notification received from 0c6b000b-2f43-7eb4-0646-e5c28162cf6c, value: (0x) 21-12-00-02-00-00-80-3F-00-00-00-00-0A-D7-A3-3C-C3-F5-A8-3E
A 13:41:39.062 "(0x) 21-12-00-02-00-00-80-3F-00-00-00-00-0A-D7-A3-3C-C3-F5-A8-3E" received
I am trying to use the react native library react-native-ble-plx to write characteristics.
If we take the very first data sent
I tried everything:
  • 0x30055175145E9E72
  • (0x) 30-05-51-75-14-5E-9E-72
  • 30-05-51-75-14-5E-9E-72
  • MHgzMDA1NTE3NTE0NUU5RTcy // value in base64
I am looking to get feedback from the device as we can see "received" in the logs.
I always have errors - or no feedback.
My question is How does nRF connect works under the hood to send data? should I send string `30055175145E9E72`? with extra `0x`? or `(0x) ` or not? I am lost.
  • Hi David,
    I'll get back to you on this tomorrow.
    Elfving
    that "0x" indicates, that following data are shown in hex. You just need to send an array of bytes with values: 0x30, 0x05, 0x51, etc. and you'll get an array as return. Don't send them as string, but as byte array.
    A byte value can be displayed in multiple formats, for example:
    • 64 (decimal)
    • 0x41 (hex)
    • 0101 (octal)
    • 0b01000001 (binary)
    • 'A' (character)
    Assuming you're using = FAQ: Passing And Retrieving Of Characteristic Value · dotintent/react-native-ble-plx Wiki (github.com) you need to Base64 the byte array.
    By using Hex to Base64 | Base64 Encode | Base64 Converter | Base64 and putting the above hex, we get: MAVRdRRennI=
  • Thanks for the explanations Aleksander Raised hands
    Following your advice I try to get returned values without any success
    one case is always null
     const result = await BLEService.writeCharacteristicWithoutResponseForDevice(
    SPP_SERVICE_UUID,
    SPP_CHARACTERISTIC_UUID, // characteristic UUID read and write
    valueToWrite // sends as byte array.
    // Result is always null
    // deviceID: "71511EB2-XXXX-XXXX-XXXX-77B2FAC78495"
    // id: 12928767904
    // isIndicatable: false
    // isNotifiable: false
    // isNotifying: false
    // isReadable: true
    // isWritableWithResponse: false
    // isWritableWithoutResponse: true
    // serviceID: 12909164416
    // serviceUUID: "0c6b000a-2f43-7eb4-0646-e5c28162cf6c"
    // uuid: "0c6b000c-2f43-7eb4-0646-e5c28162cf6c"
    // value: null
    the other one is an error
     const result = await BLEService.writeCharacteristicWithResponseForDevice(
    SPP_SERVICE_UUID,
    // return an error
     // X ~ showErrorToast: {
    // "message": "Characteristic 0c6b000c-2f43-7eb4-0646-e5c28162cf6c write failed for device 71511EB2-D2BC-D5F8-4DF7-77B2FAC78495 and service 0c6b000a-2f43-7eb4-0646-e5c28162cf6c",
    // "errorCode": 401,
    // "attErrorCode": 3,
    // "iosErrorCode": null,
    // "androidErrorCode": null,
    // "reason": "Writing is not permitted.",
    // "name": "BleError"
    Edit:
    I finally found how to get data from the device!
    On my case, I need to setup a monitor on another characteristics.
    1. send data to characteristicA
    2. get result from characteristicB
