Sample using nrf_802154_receive_at
is there any example using the IEEE 802.15.4 driver?
I was able to send and receive a some packets by using nrf_802154_receive and nrf_802154_transmit_raw, and now I would like to synchronize transmission and reception by using nrf_802154_receive_at and nrf_802154_transmit_raw_at. Unfortunately these functions don't even compile because the macro NRF_802154_DELAYED_TRX_ENABLED is not defined.
Where can I find an example that shows how to use those functions?
Best regards
    What driver do you refer to? Do you refer to the old legacy nRF5 SDK's IEEE 802.15.4 driver? What SDK version are you using? The nRF5 SDK or the nRF Connect SDK (NCS).
    And what sample do you refer to?
    Hopefully, a little more context makes it easier to understand what's not working Slight smile
    Edvin
  • Hi Edvin,
    Sorry for the missing information.
    I'm using NCS 2.5 with the following:
    CONFIG_NRF_802154_RADIO_DRIVER=y
    CONFIG_NRF_802154_SOURCE_HAL_NORDIC=y
    and I'm using the functions defined in nrf_802154.h
    I'm not referring to any example. My question is: where do I find any example for the functions nrf_802154_receive_at and nrf_802154_transmit_raw_at?
    Giuseppe
    Sorry. I don't think we have any raw 802.15.4 samples. Only Openthread and Zigbee samples, which are drivers that utilize the 802.15.4 driver.
    The NRF_802154_DELAYED_TRX_ENABLED is defined if CONFIG_NRF_802154_SL_OPENSOURCE is not defined. Is it defined in your build? You can check the outcome of all your configuration files in the build folder:
    build\zephyr\include\generated\autoconf.h.
    Edvni
  • Yes, CONFIG_NRF_802154_SL_OPENSOURCE is defined. I tired to set CONFIG_NRF_802154_SL_OPENSOURCE=n but since it remain defined it doesn't work. Is this an issue? Should it be
    #if CONFIG_NRF_802154_SL_OPENSOURCE
    instead of
    #ifdef CONFIG_NRF_802154_SL_OPENSOURCE
    Is there any other documentation (apart from API reference which is quite short)?
  • Ok, I need to run this by our Thread and Zigbee team. Is there a particular reason why you intend to use nrf_802154_receive_at() in particular? Perhaps you can describe the use case, and what you want to do with the application?
    Edvin
