Hi
I am designing a 4-layer pcb. How much do you think my signal trace thickness should be?
I use https://www.trgcomponents.de/en/ant-24-cw-rah-rps.html
connector —> www.ozdisan.com/.../954516
Hi
This looks fine, but trace width seems a bit big, are you sure that the values are correct? Trace width seems a little wide.
From the first image you shared in comment here it seems that the Hight is 0.5mm
Just using a online calculator here and i with the second layer as reference GND then thickness is less then1 mm for 50 ohms.
Or here:
Trace Impedance Calculator | DigiKey
Muhammed said:will it cause problems if the thickness between PCB layers is more than 0.7 mm?
It will depend on how much different, if there is just minor variance then no big issue.
Jonathan
Thank you for help.
