Error -134 when trying to connect to WiFi using net_mgmt with static credentials on custom board
Hello
I am working on a WiFi application using a custom board equipped with both the nRF5340 aswell as the nRF7002. When requesting a WiFi connection using the net_mgmt function and static credentials I get the errorcode -134 (ENOTSUP).
    struct wifi_connect_req_params cnx_params;
	struct net_if *iface = net_if_get_first_wifi();
	if (iface == NULL) {
		LOG_ERR("Returned network interface is NULL");
	/* Sleep to allow initialization of Wi-Fi driver */
	k_sleep(K_SECONDS(1));
	/* STEP 9 - Initialize and add the callback function for network events */
	net_mgmt_init_event_callback(&mgmt_cb, net_mgmt_event_handler, EVENT_MASK);
	net_mgmt_add_event_callback(&mgmt_cb);
	/* STEP 10 - Populate cnx_params with the network configuration */
	wifi_args_to_params(&cnx_params);
	/* STEP 11 - Call net_mgmt() to request the Wi-Fi connection */
	LOG_INF("Connecting to Wi-Fi");
	int err = net_mgmt(NET_REQUEST_WIFI_CONNECT, iface, &cnx_params, sizeof(struct wifi_connect_req_params));
	if (err) {
		LOG_ERR("Connecting to Wi-Fi failed, err: %d", err);
		while(1)
			gpio_pin_toggle_dt(&outputs[1]);
			k_msleep(700);
	k_sem_take(&run_app, K_FOREVER);
I don't understand this error means exactly. When I flash the same firmware on the nRF7002 DK I don't get any errors at all.
I found this forum post which seems to present a similar issue. However the solution from that post does not work for me. My custom board does not have an external flash and when I add CONFIG_FLASH to my prj.conf I get this error when building because of it (__device_dts_ord_152 is spi, which is disabled on my board):
[101/425] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[102/425] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[103/425] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/debug/thread_info.c.obj
[104/425] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[105/425] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[106/425] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/mem_mgmt/mem_attr.c.obj
[107/425] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[108/425] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[109/425] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[110/425] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_line.c.obj
[111/425] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
[112/425] Building ASM object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.6.1/modules/debug/segger/SEGGER/DebugMon/JLINK_MONITOR_ISR_SES.s.obj
[113/425] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_init.c.obj
[114/425] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.6.1/modules/debug/segger/SEGGER/DebugMon/JLINK_MONITOR.c.obj
[115/425] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings.c.obj
[116/425] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_store.c.obj
[117/425] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.6.1/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[118/425] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_nvs.c.obj
[119/425] Generating linker_zephyr_pre0.cmd
[120/425] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_psa_crypto.c.obj
[121/425] Building C object zephyr/drivers/adc/CMakeFiles/drivers__adc.dir/adc_common.c.obj
[122/425] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/nrf_clock_calibration.c.obj
[123/425] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
[124/425] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[125/425] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
[126/425] Building C object zephyr/drivers/adc/CMakeFiles/drivers__adc.dir/adc_nrfx_saadc.c.obj
[127/425] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/spi_nor.c.obj
FAILED: zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/spi_nor.c.obj
C:\ncs\toolchains\cf2149caf2\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DCONFIG_NRF_WIFI_FW_BIN=C:/ncs/v2.6.1/nrfxlib/nrf_wifi/fw_bins/default/nrf70.bin -DCONFIG_ZEPHYR -DKERNEL -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-want-config.h\" -DMBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DNRF52_ERRATA_215_ENABLE_WORKAROUND=0 -DNRF5340_XXAA_APPLICATION -DNRF53_ERRATA_43_ENABLE_WORKAROUND=0 -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DUSE_PARTITION_MANAGER=1 -D_ANSI_SOURCE -D_FORTIFY_SOURCE=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -IC:/ncs/v2.6.1/zephyr/include -IC:/Users/wadn/Desktop/VT2_muscle_detector/Firmware/build_1/zephyr/include/generated -IC:/ncs/v2.6.1/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/ncs/v2.6.1/zephyr/lib/libc/newlib/include -IC:/ncs/v2.6.1/zephyr/soc/common/nordic_nrf/. -IC:/ncs/v2.6.1/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.6.1/zephyr/subsys/net/l2 -IC:/ncs/v2.6.1/zephyr/subsys/net/ip -IC:/ncs/v2.6.1/zephyr/subsys/net/conn_mgr/. -IC:/ncs/v2.6.1/zephyr/subsys/settings/include -IC:/ncs/v2.6.1/nrf/include -IC:/Users/wadn/Desktop/VT2_muscle_detector/Firmware/build_1/tfm/api_ns/interface/include -IC:/ncs/v2.6.1/nrf/modules/trusted-firmware-m/. -IC:/ncs/v2.6.1/nrf/include/tfm -IC:/ncs/v2.6.1/nrf/modules/hostap/src -IC:/ncs/v2.6.1/nrf/modules/hostap/../../../modules/lib/hostap -IC:/ncs/v2.6.1/nrf/modules/hostap/../../../modules/lib/hostap/wpa_supplicant -IC:/ncs/v2.6.1/nrf/modules/hostap/../../../modules/lib/hostap/src -IC:/ncs/v2.6.1/nrf/drivers/wifi/nrf700x/inc -IC:/ncs/v2.6.1/nrfxlib/nrf_wifi/utils/inc -IC:/ncs/v2.6.1/nrfxlib/nrf_wifi/os_if/inc -IC:/ncs/v2.6.1/nrfxlib/nrf_wifi/bus_if/bus/qspi/inc -IC:/ncs/v2.6.1/nrfxlib/nrf_wifi/bus_if/bal/inc -IC:/ncs/v2.6.1/nrfxlib/nrf_wifi/fw_if/umac_if/inc -IC:/ncs/v2.6.1/nrfxlib/nrf_wifi/fw_load/mips/fw/inc -IC:/ncs/v2.6.1/nrfxlib/nrf_wifi/hw_if/hal/inc -IC:/ncs/v2.6.1/nrf/drivers/wifi/nrf700x/src/qspi/inc -IC:/ncs/v2.6.1/nrfxlib/nrf_wifi/hw_if/hal/inc/fw -IC:/ncs/v2.6.1/nrfxlib/nrf_wifi/fw_if/umac_if/inc/fw -IC:/ncs/v2.6.1/nrfxlib/nrf_wifi/fw_if/umac_if/inc/default -IC:/ncs/v2.6.1/nrf/tests/include -IC:/ncs/v2.6.1/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.6.1/zephyr/modules/cmsis/. -IC:/ncs/v2.6.1/modules/hal/nordic/nrfx -IC:/ncs/v2.6.1/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.6.1/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.6.1/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.6.1/modules/debug/segger/SEGGER/DebugMon/include -IC:/Users/wadn/Desktop/VT2_muscle_detector/Firmware/build_1/modules/nrf/subsys/nrf_security/src/include/generated -IC:/ncs/v2.6.1/nrf/subsys/nrf_security/include -IC:/ncs/v2.6.1/nrf/ext/oberon/psa/core/include -IC:/ncs/v2.6.1/nrf/ext/oberon/psa/core/library -IC:/ncs/v2.6.1/modules/crypto/mbedtls/include -IC:/ncs/v2.6.1/modules/crypto/mbedtls/library -IC:/ncs/v2.6.1/nrfxlib/crypto/nrf_oberon/include/mbedtls -IC:/ncs/v2.6.1/nrfxlib/crypto/nrf_oberon/include -isystem C:/ncs/v2.6.1/zephyr/lib/libc/common/include -Wshadow -fno-strict-aliasing -Og -imacros C:/Users/wadn/Desktop/VT2_muscle_detector/Firmware/build_1/zephyr/include/generated/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=C:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.6.1/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/Users/wadn/Desktop/VT2_muscle_detector/Firmware=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.6.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.6.1=WEST_TOPDIR -ffunction-sections -fdata-sections -D_POSIX_THREADS -std=c99 -MD -MT zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/spi_nor.c.obj -MF zephyr\drivers\flash\CMakeFiles\drivers__flash.dir\spi_nor.c.obj.d -o zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/spi_nor.c.obj -c C:/ncs/v2.6.1/zephyr/drivers/flash/spi_nor.c
In file included from C:/ncs/v2.6.1/zephyr/include/zephyr/toolchain/gcc.h:98,
from C:/ncs/v2.6.1/zephyr/include/zephyr/toolchain.h:50,
from C:/ncs/v2.6.1/zephyr/include/zephyr/sys/util.h:18,
from C:/ncs/v2.6.1/zephyr/include/zephyr/devicetree.h:26,
from C:/ncs/v2.6.1/zephyr/include/zephyr/device.h:12,
from C:/ncs/v2.6.1/zephyr/include/zephyr/drivers/flash.h:28,
from C:/ncs/v2.6.1/zephyr/drivers/flash/spi_nor.c:14:
C:/ncs/v2.6.1/zephyr/include/zephyr/device.h:89:41: error: '__device_dts_ord_152' undeclared here (not in a function); did you mean '__device_dts_ord_15'?
89 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
C:/ncs/v2.6.1/zephyr/include/zephyr/toolchain/common.h:137:26: note: in definition of macro '_DO_CONCAT'
137 | #define _DO_CONCAT(x, y) x ## y
C:/ncs/v2.6.1/zephyr/include/zephyr/device.h:89:33: note: in expansion of macro '_CONCAT'
C:/ncs/v2.6.1/zephyr/include/zephyr/device.h:216:37: note: in expansion of macro 'DEVICE_NAME_GET'
216 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_ID(node_id))
C:/ncs/v2.6.1/zephyr/include/zephyr/device.h:233:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
233 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
C:/ncs/v2.6.1/zephyr/include/zephyr/drivers/spi.h:388:24: note: in expansion of macro 'DEVICE_DT_GET'
388 | .bus = DEVICE_DT_GET(DT_BUS(node_id)), \
C:/ncs/v2.6.1/zephyr/include/zephyr/drivers/spi.h:404:9: note: in expansion of macro 'SPI_DT_SPEC_GET'
404 | SPI_DT_SPEC_GET(DT_DRV_INST(inst), operation_, delay_)
C:/ncs/v2.6.1/zephyr/drivers/flash/spi_nor.c:1528:16: note: in expansion of macro 'SPI_DT_SPEC_INST_GET'
1528 | .spi = SPI_DT_SPEC_INST_GET(0, SPI_WORD_SET(8),
[128/425] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[129/425] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[130/425] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[131/425] Linking C static library zephyr\drivers\adc\libdrivers__adc.a
[132/425] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/jesd216.c.obj
[133/425] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
[134/425] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
[135/425] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/nvs/nvs.c.obj
[136/425] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\cf2149caf2\opt\bin\cmake.EXE' --build 'c:\Users\wadn\Desktop\VT2_muscle_detector\Firmware\build_1'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
I am not very familiar with Zephyr so I don't know if the issue is coming from the devicetree. I am using the same board file as the DK with an overlay file to change the pins and peripherals according to the custom board:
	zephyr,user{
		io-channels = <&adc 0>,<&adc 1>,<&adc 2>,<&adc 3>,<&adc 4>,<&adc 5>,<&adc 6>,<&adc 7>;
	buttons{
		button2: button2 {
			gpios = <&gpio1 2 0>;
			label = "Button_3";
	leds{
		sen1: sen1 {
			gpios = <&gpio0 3 GPIO_PULL_DOWN>;
			label = "Sensor_Enable1";
		sen2: sen2 {
			gpios = <&gpio0 2 GPIO_PULL_DOWN>;
			label = "Sensor_Enable2";
		sen3: sen3 {
			gpios = <&gpio1 4 GPIO_PULL_DOWN>;
			label = "Sensor_Enable3";
		sen4: sen4 {
			gpios = <&gpio1 6 GPIO_PULL_DOWN>;
			label = "Sensor_Enable4";
		sen5: sen5 {
			gpios = <&gpio1 15 GPIO_PULL_DOWN>;
			label = "Sensor_Enable5";
		sen6: sen6 {
			gpios = <&gpio1 14 GPIO_PULL_DOWN>;
			label = "Sensor_Enable6";
		sen7: sen7 {
			gpios = <&gpio1 12 GPIO_PULL_DOWN>;
			label = "Sensor_Enable7";
		sen8: sen8 {
			gpios = <&gpio1 11 GPIO_PULL_DOWN>;
			label = "Sensor_Enable8";
		//vdd7002: vdd7002 {
		//	gpios = <&gpio0 10 0>;
		//	label = "7002_VDD_ENABLE";
&adc {
	#address-cells = <1>;
	#size-cells = <0>;
	status = "okay";
	channel@0 {
		reg = <0>;
		zephyr,gain = "ADC_GAIN_1_6";
		zephyr,reference = "ADC_REF_INTERNAL";
		zephyr,acquisition-time = <ADC_ACQ_TIME_DEFAULT>;
		zephyr,input-positive = <NRF_SAADC_AIN0>; /* P0.02 for nRF52xx, P0.04 for nRF53xx */
		zephyr,resolution = <12>;
	channel@1 {
		reg = <1>;
		zephyr,input-positive = <NRF_SAADC_AIN1>;
	channel@2 {
		reg = <2>;
		zephyr,input-positive = <NRF_SAADC_AIN2>;
	channel@3 {
		reg = <3>;
		zephyr,input-positive = <NRF_SAADC_AIN3>;
	channel@4 {
		reg = <4>;
		zephyr,input-positive = <NRF_SAADC_AIN4>;
	channel@5 {
		reg = <5>;
		zephyr,input-positive = <NRF_SAADC_AIN5>;
	channel@6 {
		reg = <6>;
		zephyr,input-positive = <NRF_SAADC_AIN6>;
	channel@7 {
		reg = <7>;
		zephyr,input-positive = <NRF_SAADC_AIN7>;
&ieee802154 {
	status = "okay";
&nrf_radio_coex {
	swctrl1-gpios = <&gpio1 8 0>;
	req-gpios = <&gpio0 29 0>;
&led0 {
	gpios = <&gpio0 19 GPIO_PULL_DOWN>;
	label = "LED_1";
&led1 {
	gpios = <&gpio0 21 GPIO_PULL_DOWN>;
	label = "LED_2";
&arduino_adc {
	io-channel-map = <0 &adc 0>, <1 &adc 1>, <2 &adc 2>, <3 &adc 3>, <4 &adc 4>, <5 &adc 5>;
&arduino_header {
	gpio-map = <0 0 &gpio0 4 0>,
			<1 0 &gpio0 5 0>,
			<2 0 &gpio0 6 0>,
			<3 0 &gpio0 7 0>,
			<4 0 &gpio0 25 0>,
			<5 0 &gpio0 26 0>,
			<6 0 &gpio1 0 0>,
			<7 0 &gpio1 1 0>,
			<8 0 &gpio1 4 0>,
			<9 0 &gpio1 5 0>,
			<10 0 &gpio1 6 0>,
			<11 0 &gpio1 7 0>,
			<12 0 &gpio1 8 0>,
			<13 0 &gpio1 9 0>,
			<14 0 &gpio1 10 0>,
			<15 0 &gpio1 11 0>,
			<16 0 &gpio1 12 0>,
			<17 0 &gpio1 13 0>,
			<18 0 &gpio1 14 0>,
			<19 0 &gpio1 15 0>,
			<20 0 &gpio1 2 0>,
			<21 0 &gpio1 3 0>;
&button0 {
	gpios = <&gpio1 0 0>;
	label = "Button_1";
&button1 {
	gpios = <&gpio1 1 0>;
	label = "Button_2";
&i2c1 {
	status = "disabled";
&uart0 {
&pwm0 {
&nrf_radio_coex {
	/delete-property/ btrf-switch-gpios;
&arduino_adc {
&gpio_fwd {
&spi4 {
&gpio_fwd {
    /delete-node/ uart;
I am using version 2.6.1 of the SDK
Regards
wadn
  • Hi Håkon
    When i change the pin in the devicetree from high active to low active I get a signal, which means the connection should be fine. This would then mean the MCU is not setting the pin active for some reason.
    Regards
    wadn
    Q1: Can you scope your pins using a logic analyzer to see how the boot-up sequence is applied?
    And please share how it looks from reset
    Q2: Can you try with a stock sample, like wifi/scan or wifi/sta to see if they behave the same?
    Q3: Can you try with another of your custom boards, to see if the issue is local to one board or if this is a generic problem on all boards that you've manufacturered?
    Håkon
  • Hi Håkon
    Sorry for the late response, I assembled a second board aswell as resoldered the nRF5340 on the first one. Now on both of them BUCKEN and IOVDD_EN are set and the timing seems to be good aswell:
    VBAT in blue is enabled more than 6ms before BUCKEN in purple and after a little more than 1ms IOVDD is enabled.
    Still when I run my code I get error -134 on the net_mgmt function.
    Regards
    wadn
    Can you please use JLink RTT for log output and share what is printed?
    Add this to your prj.conf and use JLink RTT Viewer to see the traces after flashing:
    # RTT backends
    CONFIG_RTT_CONSOLE=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
    # UART backends
    CONFIG_UART_CONSOLE=n
    CONFIG_LOG_BACKEND_UART=n
    Håkon
  • Hi
    This is what I got from the RTT Viewer:
    00> [00:00:00.565,490] <err> wifi_nrf_bus: RDSR failed: -16
    00> [00:00:00.565,551] <err> wifi_nrf: zep_shim_bus_qspi_dev_add: QSPI device init failed
    00> [00:00:00.565,612] <err> wifi_nrf: nrf_wifi_bus_qspi_dev_add: nrf_wifi_osal_bus_qspi_dev_add failed
    00> [00:00:00.565,673] <err> wifi_nrf: nrf_wifi_bal_dev_add: Bus dev_add failed
    00> [00:00:00.565,734] <err> wifi_nrf: nrf_wifi_hal_dev_add: nrf_wifi_bal_dev_add failed
    00> [00:00:00.565,826] <err> wifi_nrf: nrf_wifi_fmac_dev_add: nrf_wifi_hal_dev_add failed
    00> [00:00:00.565,856] <err> wifi_nrf: nrf_wifi_fmac_dev_add_zep: nrf_wifi_fmac_dev_add failed
    00> [00:00:00.565,856] <err> wifi_nrf: nrf_wifi_if_start_zep: nrf_wifi_fmac_dev_add_zep failed
    00> *** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
    00> [00:00:01.567,382] <inf> Lesson6_Exercise1: Connecting to Wi-Fi
    00> [00:00:01.567,413] <err> Lesson6_Exercise1: Connecting to Wi-Fi failed, err: -134
    seems to be something wrong with the QSPI connection if I understand correctly.
    Regards
    wadn
