when setting the fetching code this type of output is coming i.e board is resetting continuously and also Iam taken the lsm6dsv16x drivers from browser
Virat said:Is there any sample code for lsm6dsv16x which I can ran directly?
The sample is not for our boards, but there is https://docs.nordicsemi.com/bundle/ncs-latest/page/zephyr/samples/shields/x_nucleo_iks4a1/sensorhub1/README.html.
However, the Zephyr drivers should be used similarly.
Can you take a look at the setup in this sample and see if it matches yours?
Hi Edvin,
Now I am Using laser(VL53LOx),IMU sensor(LSM6DSV16x),ultrasonic sensor(CH101) but individually IMU sensor is working fine but the issue is at the time of configue the both sensors imu sensor is not initialize.So,please send how to configure the both sensors in devicetree at a time.
Hi Sigurd is out of office so I will take over the case
Please upload your devicetree, prjf.conf and error log.
If you have not please enable config_log so we can get some information. I would also suggest that you set CONFIG_RESET_ON_FATAL_ERROR=n so the device do not reboot on fatal error
Regards
Runar
