when setting the fetching code this type of output is coming i.e board is resetting continuously and also Iam taken the lsm6dsv16x drivers from browser
Try to set CONFIG_LOG=y.
How does the logs look then?
Sigurd Hellesvik
Hi Nordic,
I added CONFIG_LOG=y this line in prj.conf but I am getting this type of raw data when setting the sampling frequency code.
Hi Nordic,
when setup the below code device is resetting continuously and some issues are coming please find the below
issues.
Try to run addr2line.
See https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-2-debugging/topic/build-errors-and-fatal-errors/
Maybe some other stuff from that guide can also be useful here.
Let me know what is returned, and I will help you analyze it.
I am using VS code with nRF connect SDK v2.2.0, toolchain v2.2.0 & cmake v3.20.0.
I ran % bin/symquery.exe -e build/zephyr/zephyr.elf 0x000045a2 this command from nRF connect terminal but following error has shown
ForEach-Object : Cannot bind parameter 'End'. Cannot convert the "build/zephyr/zephyr.elf" value of type "System.String" to type
"System.Management.Automation.ScriptBlock".
At line:1 char:23
+ % bin/symquery.exe -e build/zephyr/zephyr.elf 0x000045a2
+ CategoryInfo : InvalidArgument: (:) [ForEach-Object], ParameterBindingException
+ FullyQualifiedErrorId : CannotConvertArgumentNoMessage,Microsoft.PowerShell.Commands.ForEachObjectCommand
First of all, I need to understand whether lsm6dsl sample code works with the lsm6dsv16x(actual sensor connected to nRF5340). Atleast Iam expecting the following code should pass
