Here are my 2 scenarios:
- I need a radio chip that will be used to form a mesh network in dense bush with each node up to 150m apart. Is this possible?
- I need the best chip in long range communication and smallest size.
Thanks
Thanks
2.4GHz is not your best option. Our experience is that lower frequencies have more success over longer distances. Maybe look into 868MHz solutions or even 433MHz.
You should stay in sub-GHz modules for ranges like that, especially if you don't want to consume lot of power. 433MHz or 868/915MHz depending your location and legislation that applies locally. 433MHz modules generally use a 2x longer 1/4λ wire antenna than the one used for 868/915MHz (16cm vs 8cm for example), but might provide increased range.
Have a look at the NRF905 or the NRF9E5 (SoC) from Nordic.
You could also use RFM69 (W@13dB or HW@20dB), RFM22B and RFM12B modules from Hoperf (I already experimented with the RFM69 on a mesh network implementation, it worked great).
Yes - it is a consequence of the Laws Of Physics that, other things being comparable, 433MHz is (almost) bound to give longer range than 2.4GHz
Thanks for that info
