I can successfully start commissioning role when I use cli and the leader gets the commissioner active state. But when I try the same using API all, the leader gets stuck in the petition state. Following is what I did in my software.
// custom cli command to start commissioning
otError cli_cmsn (void *aContext, uint8_t aArgsLength, char *aArgs[]) {
otOperationalDataset aDataset;
otError error;
otInstance *instance = openthread_get_default_instance();
if (instance == NULL) {
otCliOutputFormat ("get instantace error");
return OT_ERROR_FAILED;
otCliOutputFormat ("\n\r ifconfig down ");
error = otIp6SetEnabled(instance, false); // ifconfig down
if (error != OT_ERROR_NONE) {
otCliOutputFormat ("ifconfig down error");
return (error);
otCliOutputFormat ("\n\r Thread stop ");
error = otThreadSetEnabled (instance, false); // thread stop
otCliOutputFormat ("thread stop error");
return (error);
otCliOutputFormat ("\n\rCreate new dataset ");
error = otDatasetCreateNewNetwork(instance, &aDataset); // create new dataset
otCliOutputFormat ("create new dataset error");
return (error);
otCliOutputFormat ("\n\r active new dataset ");
error = otDatasetSetActive(instance, &aDataset); // active new dataset
otCliOutputFormat ("active new dataset error");
return (error);
otCliOutputFormat ("\n\r ifconfig up ");
error = otIp6SetEnabled(instance, true); // ifconfig up
otCliOutputFormat ("ifconfig up error");
return (error);
otCliOutputFormat ("\n\r thread start ");
error = otThreadSetEnabled (instance, true); // thread start
otCliOutputFormat ("thread start error");
return (error);
// spawn a thread to handle wait to connect to network
k_tid_t my_tid = k_thread_create(&cmsn_thread_data, cmsn_stack_area,
K_THREAD_STACK_SIZEOF(cmsn_stack_area),
cmsn_handler,
NULL, NULL, NULL,
CMSN_THREAD_PRIORITY, 0, K_NO_WAIT);
return (OT_ERROR_NONE);
// Thread handler to busy wait ot role change
void cmsn_handler (void *, void *, void *) {
otError error;
while (ot_connected == true) {
otCliOutputFormat (".");
k_msleep (500);
while (ot_connected == false) {
k_msleep (500);
otCliOutputFormat ("\n\r commissioner start ");
error = otCommissionerStart (instance, aStateCallback, aJoinerCallback, NULL);
otCliOutputFormat ("commissioner start error %d\n\r", error);
return (error);
I use a thread to busy wait till thread instance is back in router or leader role. The bool 'ot_connected' will be true when the role changes to router/leader.
I have only one device (leader) in this network. I have waited till device role becomes leader as well, but same result. But if I manually start using cli command 'commissioner start', it works.
How to solve this?
Cheers,
Kaushalya
