I have the following setup where I am trying to access a function in nrfx_spim.c (red box) from the file mm101_drive.c (green box).
However this function is not compiling because it is relying on the NRFX_SPIM_ENABLED variable in the sdk_config.h file to be true (see grayed out code from nrfx_spim.c below).
I have tried to set this variable to true in the sdk config file as proven below:
However this is not resolving the issue of the grayed out code. The nrfx_spim.c file shows the sdk_config in it's list of dependencies and I have verified that it is the correct config file by copying the full path and following it in the folder explorer. I have tried cleaning, rebuilding, etc. with no luck. Please let me know how to get this to recognize my sdk config settings.
Thank you,
Skyler
