Compile active file in VS Code
Sometimes I just want to compile a single file for an nRF Connect project with VS Code and the nRF Connect extension. This sometimes fails because an include file isn't found (for example <app_event_manager_priv.h> included from app_event_manager.h in my case). The file compiles fine when the whole project is built from the nRF Connect extension but not with the 'Compile Active File' function. In the terminal output I see that a lot of '-I<folder>' arguments is given to the 'arm-zephyr-eabi-gcc.exe' compiler but no path covers the <app_event_manager_priv.h> file.
I get the error when the file <app_event_manager.h> is included somewhere in my include hierarchy for a .c file.
Which file or setting do I need to edit to add include paths for the 'Compile Active File' function?
I have added includepaths to the c_cpp_properties.json which works when the whole project is built but these include paths does not seem to be used when running 'Compile Active File'.
The file app_event_manager_priv.h lives in ${workspaceFolder}/nrf/subsys/app_event_manager
Best regards /Ruben
    Could you provide information why you want to compile single file? Is this single file already a part of existing NCS project?
    As it sometimes fails, I assume it sometimes succeeds. What do you do differently that could lead to these 2 completely different outcomes?
    Dejan
  • Could you provide information why you want to compile single file? Is this single file already a part of existing NCS project?
    When I refactor a larger project containing many source files, and I haven't built the whole project for a while, there could be a lot of output in the terminal during the build if something is wrong (especially for simple typos in the macros in zephyr, e.g. LOG_INF and others) it is nice to simply just compile the single file I am currently working on.
    It is not random but depending on the file being compiled. For any given file it always either succeeds or always fails. In my case it always fails if the file app_event_manager.h is included which leads to error: .../nrf/include/app_event_manager.h:27:10: fatal error: app_event_manager_priv.h: No such file or directory
    Which leads to my question:
    Thanks /Ruben
  • Hi Ruben,
    Could you show how you do this? Some screenshots with descriptions of both working and non-working case could be useful.
    Dejan
  • Found the problem: Turns out I had missed setting CONFIG_APP_EVENT_MANAGER=y in a .conf file and after doing a pristine build it seems to work to also Compile Active File for files that include app_event_manager.h
    /Ruben
  • Hi Ruben,
    Thank you for the update.
    Did you refer to "Run Active File" when you mentioned "Compile Active File"?
    Dejan
1 2
