I am getting an error message when trying to use a nRF5340 DK with a Waveshare 1.69inch Touch LCD Module on the Zephyr sample code with minimal modifications. When I flash/reset I get:
[00:00:01.159,332] <err> cst816s: failed reading chip id *** Booting nRF Connect SDK v3.5.99-ncs1-1 *** [00:00:01.163,635] <inf> app: Starting...
and when I touch the screen I get:
[00:00:42.109,527] <err> cst816s: Could not read x data
The pin settings are as follows:
Module Pin
nRF5340 Pin
VCC
VDD (3.3)
GND | GND |
LCD_DIN |
P0.25
LCD_CLK |
P0.06
LCD_CS |
P0.11
LCD_DC |
P1.11
LCS_RST |
P1.10
LCS_BL |
VDD (3.3)
TP_SDA |
P1.02
TP_SCL |
P1.03
TP_RST |
P0.20
TP_IRQ |
P1.01
The nrf5340dk_nrf5340_cpuapp.overlay is:
&pinctrl { spi4_default: spi4_default { group1 { psels = <NRF_PSEL(SPIM_SCK, 0, 6)>, <NRF_PSEL(SPIM_MOSI, 0, 25)>; }; }; spi4_sleep: spi4_sleep { group1 { psels = <NRF_PSEL(SPIM_SCK, 0, 6)>, <NRF_PSEL(SPIM_MOSI, 0, 25)>; low-power-enable; }; }; // Set to I2C pins that the touch screen is connected to i2c2_default: i2c2_default { group1 { psels = <NRF_PSEL(TWIM_SDA, 1, 2)>, <NRF_PSEL(TWIM_SCL, 1, 3)>; }; }; i2c2_sleep: i2c2_sleep { group1 { psels = <NRF_PSEL(TWIM_SDA, 1, 2)>, <NRF_PSEL(TWIM_SCL, 1, 3)>; low-power-enable; }; }; }; &spi4 { compatible = "nordic,nrf-spim"; status = "okay"; pinctrl-0 = <&spi4_default>; pinctrl-1 = <&spi4_sleep>; pinctrl-names = "default", "sleep"; cs-gpios = <&gpio0 11 GPIO_ACTIVE_LOW>; st7789v_st7789v_tl019fqv01: st7789v@0 { compatible = "sitronix,st7789v"; spi-max-frequency = <20000000>; reg = <0>; cmd-data-gpios = < &gpio1 11 GPIO_ACTIVE_LOW>; reset-gpios = < &gpio1 10 GPIO_ACTIVE_LOW>; width = <240>; height = <280>; x-offset = <0>; y-offset = <20>; vcom = <0x19>; gctrl = <0x35>; vrhs = <0x12>; vdvs = <0x20>; mdac = <0x00>; gamma = <0x01>; colmod = <0x05>; lcm = <0x2c>; porch-param = [0c 0c 00 33 33]; cmd2en-param = [5a 69 02 01]; pwctrl1-param = [a4 a1]; pvgam-param = [D0 04 0D 11 13 2B 3F 54 4C 18 0D 0B 1F 23]; nvgam-param = [D0 04 0C 11 13 2C 3F 44 51 2F 1F 1F 20 23]; ram-param = [00 F0]; rgb-param = [CD 08 14]; }; }; &i2c2 { compatible = "nordic,nrf-twim"; status = "okay"; clock-frequency = <I2C_BITRATE_FAST>; pinctrl-0 = <&i2c2_default>; pinctrl-1 = <&i2c2_sleep>; pinctrl-names = "default", "sleep"; cst816s: cst816s@15 { compatible = "hynitron,cst816s"; reg = <0x15>; irq-gpios = <&gpio1 1 GPIO_ACTIVE_LOW>; rst-gpios = <&gpio0 20 GPIO_ACTIVE_LOW>; }; }; / { fstab { compatible = "zephyr,fstab"; lfs: lfs { compatible = "zephyr,fstab,littlefs"; mount-point = "/lfs"; partition = <&littlefs_storage>; automount; read-size = <16>; prog-size = <16>; cache-size = <64>; lookahead-size = <32>; block-cycles = <512>; }; }; }; /delete-node/ &storage_partition; &mx25r64 { partitions { compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>; littlefs_storage: partition@0 { label = "littlefs_storage"; reg = <0x00000000 0x00200000>; }; lvgl_raw_partition: partition@200000 { label = "lvgl_raw_partition"; reg = <0x00200000 0x00200000>; }; settings_partition: partition@400000 { label = "settings_partition"; reg = <0x400000 0x100000 >; }; }; }; / { chosen { nordic,pm-ext-flash = &mx25r64; zephyr,display = &st7789v_st7789v_tl019fqv01; zephyr,keyboard-scan = &cst816s; }; /* aliases { vibrator_pwm = &led0; }; */ lvgl_pointer_input: lvgl_pointer { compatible = "zephyr,lvgl-pointer-input"; input = <&cst816s>; swap-xy; invert-x; }; aliases { input = &cst816s; }; vib_pwr: vib-pwr-ctrl { compatible = "regulator-fixed"; regulator-name = "vib-pwr-ctrl"; enable-gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>; }; };
The prj.conf is:
CONFIG_LV_Z_MEM_POOL_SIZE=16384 CONFIG_LV_Z_SHELL=y CONFIG_MAIN_STACK_SIZE=2048 CONFIG_DISPLAY=y CONFIG_DISPLAY_LOG_LEVEL_ERR=y CONFIG_DISPLAY_LOG_LEVEL_INF=y CONFIG_LOG=y CONFIG_SHELL=y CONFIG_LVGL=y CONFIG_LV_MEM_CUSTOM=y CONFIG_LV_USE_LOG=y CONFIG_LV_USE_LABEL=y CONFIG_LV_USE_BTN=y CONFIG_LV_USE_ARC=y CONFIG_LV_USE_IMG=y CONFIG_LV_USE_MONKEY=y CONFIG_LV_FONT_MONTSERRAT_16=y #added to get touch working CONFIG_INPUT=y CONFIG_LV_Z_POINTER_INPUT=y #CONFIG_LV_Z_ENCODER_INPUT=y
and the main.c is:
#include <zephyr/device.h> #include <zephyr/devicetree.h> #include <zephyr/drivers/display.h> #include <zephyr/drivers/gpio.h> #include <lvgl.h> #include <stdio.h> #include <string.h> #include <zephyr/kernel.h> #include <lvgl_input_device.h> #define LOG_LEVEL CONFIG_LOG_DEFAULT_LEVEL #include <zephyr/logging/log.h> LOG_MODULE_REGISTER(app); static uint32_t count; #ifdef CONFIG_GPIO static struct gpio_dt_spec button_gpio = GPIO_DT_SPEC_GET_OR( DT_ALIAS(sw0), gpios, {0}); static struct gpio_callback button_callback; static void button_isr_callback(const struct device *port, struct gpio_callback *cb, uint32_t pins) { ARG_UNUSED(port); ARG_UNUSED(cb); ARG_UNUSED(pins); count = 0; } #endif /* CONFIG_GPIO */ #ifdef CONFIG_LV_Z_ENCODER_INPUT static const struct device *lvgl_encoder = DEVICE_DT_GET(DT_COMPAT_GET_ANY_STATUS_OKAY(zephyr_lvgl_encoder_input)); #endif /* CONFIG_LV_Z_ENCODER_INPUT */ static void lv_btn_click_callback(lv_event_t *e) { LOG_INF("lv_btn_click_callback called"); ARG_UNUSED(e); count = 0; } int main(void) { char count_str[11] = {0}; const struct device *display_dev; lv_obj_t *hello_world_label; lv_obj_t *count_label; LOG_INF("Starting..."); display_dev = DEVICE_DT_GET(DT_CHOSEN(zephyr_display)); if (!device_is_ready(display_dev)) { LOG_ERR("Device not ready, aborting test"); return 0; } lv_obj_set_style_bg_color(lv_scr_act(), lv_color_black(), LV_PART_MAIN); lv_obj_set_style_text_color(lv_scr_act(), lv_color_white(), LV_PART_MAIN); #ifdef CONFIG_GPIO if (gpio_is_ready_dt(&button_gpio)) { int err; err = gpio_pin_configure_dt(&button_gpio, GPIO_INPUT); if (err) { LOG_ERR("failed to configure button gpio: %d", err); return 0; } gpio_init_callback(&button_callback, button_isr_callback, BIT(button_gpio.pin)); err = gpio_add_callback(button_gpio.port, &button_callback); if (err) { LOG_ERR("failed to add button callback: %d", err); return 0; } err = gpio_pin_interrupt_configure_dt(&button_gpio, GPIO_INT_EDGE_TO_ACTIVE); if (err) { LOG_ERR("failed to enable button callback: %d", err); return 0; } } #endif /* CONFIG_GPIO */ #ifdef CONFIG_LV_Z_ENCODER_INPUT lv_obj_t *arc; lv_group_t *arc_group; arc = lv_arc_create(lv_scr_act()); lv_obj_align(arc, LV_ALIGN_CENTER, 0, 0); lv_obj_set_size(arc, 150, 150); arc_group = lv_group_create(); lv_group_add_obj(arc_group, arc); lv_indev_set_group(lvgl_input_get_indev(lvgl_encoder), arc_group); #endif /* CONFIG_LV_Z_ENCODER_INPUT */ if (IS_ENABLED(CONFIG_LV_Z_POINTER_KSCAN) || IS_ENABLED(CONFIG_LV_Z_POINTER_INPUT)) { lv_obj_t *hello_world_button; hello_world_button = lv_btn_create(lv_scr_act()); lv_obj_align(hello_world_button, LV_ALIGN_CENTER, 0, 0); lv_obj_add_event_cb(hello_world_button, lv_btn_click_callback, LV_EVENT_CLICKED, NULL); hello_world_label = lv_label_create(hello_world_button); } else { hello_world_label = lv_label_create(lv_scr_act()); } lv_label_set_text(hello_world_label, "Hello world!"); lv_obj_align(hello_world_label, LV_ALIGN_CENTER, 0, 0); lv_obj_set_style_text_font(hello_world_label, &lv_font_montserrat_16, LV_PART_MAIN); count_label = lv_label_create(lv_scr_act()); lv_obj_align(count_label, LV_ALIGN_BOTTOM_MID, 0, 0); lv_obj_set_style_text_font(count_label, &lv_font_montserrat_16, LV_PART_MAIN); lv_task_handler(); display_blanking_off(display_dev); while (1) { if ((count % 100) == 0U) { sprintf(count_str, "%d", count/100U); lv_label_set_text(count_label, count_str); } lv_task_handler(); ++count; k_sleep(K_MSEC(10)); } }
