Hii,
I am using NFC tag reader to interfacing with nrf52832 board , I am using nrf connect 2.6.0v. The sample file is also given( TAG_READER )
I am using spi protocol to communicate with nrf boad ,
I got error to connect ....
Error 1.
Error 2
My overlay file.
&spi0 {
compatible = "nordic,nrf-spi";
status = "okay";
cs-gpios = <&gpio0 22 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&spi0_default_alt>;
pinctrl-1 = <&spi0_sleep_alt>;
st25r3911b@0 {
compatible = "st,st25r3911b";
reg = <0>;
spi-max-frequency = <4000000>;
irq-gpios = <&gpio0 3 GPIO_ACTIVE_HIGH>;
led-nfca-gpios = <&gpio0 29 GPIO_ACTIVE_HIGH>;
// &spi1 {
// status = "disabled";
// &spi2 {
&pinctrl {
spi0_default_alt: spi0_default_alt {
group1 {
psels = <NRF_PSEL(SPIM_SCK, 0, 25)>,
<NRF_PSEL(SPIM_MOSI, 0, 23)>,
<NRF_PSEL(SPIM_MISO, 0, 24)>;
spi0_sleep_alt: spi0_sleep_alt {
group1 {
low-power-enable;
My prj file
# Copyright (c) 2019 Nordic Semiconductor ASA
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_SPI=y
CONFIG_ST25R3911B_LIB=y
CONFIG_NFC_NDEF=y
CONFIG_NFC_NDEF_RECORD=y
CONFIG_NFC_NDEF_MSG=y
CONFIG_NFC_NDEF_PARSER=y
CONFIG_NFC_NDEF_LE_OOB_REC_PARSER=y
CONFIG_NFC_T2T_PARSER=y
CONFIG_NFC_T4T_HL_PROCEDURE=y
CONFIG_NFC_NDEF_CH_PARSER=y
CONFIG_POLL=y
CONFIG_MAIN_STACK_SIZE=2048
my main.c file
/* main.c - Application main entry point */
* Copyright (c) 2019 Nordic Semiconductor ASA
#include <zephyr/types.h>
#include <stddef.h>
#include <stdbool.h>
#include <string.h>
#include <zephyr/kernel.h>
#include <st25r3911b_nfca.h>
#include <nfc/ndef/msg_parser.h>
#include <nfc/ndef/le_oob_rec_parser.h>
#include <nfc/t2t/parser.h>
#include <nfc/t4t/ndef_file.h>
#include <nfc/t4t/isodep.h>
#include <nfc/t4t/hl_procedure.h>
#include <nfc/ndef/ch_rec_parser.h>
#include <zephyr/sys/byteorder.h>
#define NFCA_BD 128
#define BITS_IN_BYTE 8
#define MAX_TLV_BLOCKS 10
#define MAX_NDEF_RECORDS 10
#define NFCA_T2T_BUFFER_SIZE 1024
#define NFCA_LAST_BIT_MASK 0x80
#define NFCA_FDT_ALIGN_84 84
#define NFCA_FDT_ALIGN_20 20
#define NFC_T2T_READ_CMD 0x30
#define NFC_T2T_READ_CMD_LEN 0x02
#define NFC_T4T_ISODEP_FSD 256
#define NFC_T4T_ISODEP_RX_DATA_MAX_SIZE 1024
#define NFC_T4T_APDU_MAX_SIZE 1024
#define NFC_NDEF_REC_PARSER_BUFF_SIZE 128
#define NFC_TX_DATA_LEN NFC_T4T_ISODEP_FSD
#define NFC_RX_DATA_LEN NFC_T4T_ISODEP_FSD
#define T2T_MAX_DATA_EXCHANGE 16
#define TAG_TYPE_2_DATA_AREA_MULTIPLICATOR 8
#define TAG_TYPE_2_DATA_AREA_SIZE_OFFSET (NFC_T2T_CC_BLOCK_OFFSET + 2)
#define TAG_TYPE_2_BLOCKS_PER_EXCHANGE (T2T_MAX_DATA_EXCHANGE / NFC_T2T_BLOCK_SIZE)
#define TRANSMIT_DELAY 3000
#define ALL_REQ_DELAY 2000
static uint8_t tx_data[NFC_TX_DATA_LEN];
static uint8_t rx_data[NFC_RX_DATA_LEN];
static struct k_poll_event events[ST25R3911B_NFCA_EVENT_CNT];
static struct k_work_delayable transmit_work;
NFC_T4T_CC_DESC_DEF(t4t_cc, MAX_TLV_BLOCKS);
static struct st25r3911b_nfca_buf tx_buf = {
.data = tx_data,
.len = sizeof(tx_data)
static const struct st25r3911b_nfca_buf rx_buf = {
.data = rx_data,
.len = sizeof(rx_data)
enum nfc_tag_type {
NFC_TAG_TYPE_UNSUPPORTED = 0,
NFC_TAG_TYPE_T2T,
NFC_TAG_TYPE_T4T
enum t2t_state {
T2T_IDLE,
T2T_HEADER_READ,
T2T_DATA_READ
struct t2t_tag {
enum t2t_state state;
uint16_t data_bytes;
uint8_t data[NFCA_T2T_BUFFER_SIZE];
struct t4t_tag {
uint8_t data[NFC_T4T_ISODEP_RX_DATA_MAX_SIZE];
uint8_t ndef[MAX_TLV_BLOCKS][NFC_T4T_APDU_MAX_SIZE];
uint8_t tlv_index;
static enum nfc_tag_type tag_type;
static struct t2t_tag t2t;
static struct t4t_tag t4t;
static void nfc_tag_detect(bool all_request)
int err;
enum st25r3911b_nfca_detect_cmd cmd;
tag_type = NFC_TAG_TYPE_UNSUPPORTED;
cmd = all_request ? ST25R3911B_NFCA_DETECT_CMD_ALL_REQ :
ST25R3911B_NFCA_DETECT_CMD_SENS_REQ;
err = st25r3911b_nfca_tag_detect(cmd);
if (err) {
printk("Tag detect error: %d.\n", err);
static int ftd_calculate(uint8_t *data, size_t len)
uint8_t ftd_align;
ftd_align = (data[len - 1] & NFCA_LAST_BIT_MASK) ?
NFCA_FDT_ALIGN_84 : NFCA_FDT_ALIGN_20;
return len * NFCA_BD * BITS_IN_BYTE + ftd_align;
static int nfc_t2t_read_block_cmd_make(uint8_t *tx_data,
size_t tx_data_size,
uint8_t block_num)
if (!tx_data) {
return -EINVAL;
if (tx_data_size < NFC_T2T_READ_CMD_LEN) {
return -ENOMEM;
tx_data[0] = NFC_T2T_READ_CMD;
tx_data[1] = block_num;
return 0;
static int t2t_header_read(void)
int err;
int ftd;
err = nfc_t2t_read_block_cmd_make(tx_data, sizeof(tx_data), 0);
if (err) {
return err;
tx_buf.data = tx_data;
tx_buf.len = NFC_T2T_READ_CMD_LEN;
ftd = ftd_calculate(tx_data, NFC_T2T_READ_CMD_LEN);
t2t.state = T2T_HEADER_READ;
err = st25r3911b_nfca_transfer_with_crc(&tx_buf, &rx_buf, ftd);
return err;
/** .. include_startingpoint_le_oob_rec_parser_rst */
static void ndef_le_oob_rec_analyze(const struct nfc_ndef_record_desc *le_oob_rec_desc)
int err;
uint8_t desc_buf[NFC_NDEF_REC_PARSER_BUFF_SIZE];
uint32_t desc_buf_len = sizeof(desc_buf);
err = nfc_ndef_le_oob_rec_parse(le_oob_rec_desc, desc_buf,
&desc_buf_len);
if (err) {
printk("Error during NDEF LE OOB Record parsing, err: %d.\n",
err);
} else {
nfc_ndef_le_oob_rec_printout(
(struct nfc_ndef_le_oob_rec_payload_desc *) desc_buf);
/** .. include_endpoint_le_oob_rec_parser_rst */
/** .. include_startingpoint_ch_rec_parser_rst */
static void ndef_ch_rec_analyze(const struct nfc_ndef_record_desc *ndef_rec_desc)
int err;
uint8_t hs_buf[NFC_NDEF_REC_PARSER_BUFF_SIZE];
uint32_t hs_buf_len = sizeof(hs_buf);
uint8_t ac_buf[NFC_NDEF_REC_PARSER_BUFF_SIZE];
uint32_t ac_buf_len = sizeof(ac_buf);
struct nfc_ndef_ch_rec *ch_rec;
struct nfc_ndef_ch_ac_rec *ac_rec;
err = nfc_ndef_ch_rec_parse(ndef_rec_desc, hs_buf, &hs_buf_len);
if (err) {
printk("Error during parsing Handover Select record: %d\n",
err);
return;
ch_rec = (struct nfc_ndef_ch_rec *)hs_buf;
printk("Handover Select Record payload");
nfc_ndef_ch_rec_printout(ch_rec);
for (size_t i = 0; i < ch_rec->local_records->record_count; i++) {
if (nfc_ndef_ch_ac_rec_check(ch_rec->local_records->record[i])) {
err = nfc_ndef_ch_ac_rec_parse(ch_rec->local_records->record[i],
ac_buf, &ac_buf_len);
if (err) {
printk("Error during parsing AC record: %d\n",
err);
return;
ac_rec = (struct nfc_ndef_ch_ac_rec *)ac_buf;
nfc_ndef_ac_rec_printout(ac_rec);
/** .. include_endpoint_ch_rec_parser_rst */
static void ndef_rec_analyze(const struct nfc_ndef_record_desc *ndef_rec_desc)
/* Match NDEF Record with specific NDEF Record parser. */
if (nfc_ndef_ch_rec_check(ndef_rec_desc,
NFC_NDEF_CH_REC_TYPE_HANDOVER_SELECT)) {
ndef_ch_rec_analyze(ndef_rec_desc);
} else if (nfc_ndef_le_oob_rec_check(ndef_rec_desc)) {
ndef_le_oob_rec_analyze(ndef_rec_desc);
} else {
/* Do nothing */
static void ndef_data_analyze(const uint8_t *ndef_msg_buff, size_t nfc_data_len)
int err;
struct nfc_ndef_msg_desc *ndef_msg_desc;
uint8_t desc_buf[NFC_NDEF_PARSER_REQUIRED_MEM(MAX_NDEF_RECORDS)];
size_t desc_buf_len = sizeof(desc_buf);
err = nfc_ndef_msg_parse(desc_buf,
&desc_buf_len,
ndef_msg_buff,
&nfc_data_len);
if (err) {
printk("Error during parsing a NDEF message, err: %d.\n", err);
return;
ndef_msg_desc = (struct nfc_ndef_msg_desc *) desc_buf;
nfc_ndef_msg_printout(ndef_msg_desc);
for (size_t i = 0; i < ndef_msg_desc->record_count; i++) {
ndef_rec_analyze(ndef_msg_desc->record[i]);
static void t2t_data_read_complete(uint8_t *data)
int err;
if (!data) {
printk("No T2T data read.\n");
return;
/* Declaration of Type 2 Tag structure. */
NFC_T2T_DESC_DEF(tag_data, MAX_TLV_BLOCKS);
struct nfc_t2t *t2t = &NFC_T2T_DESC(tag_data);
err = nfc_t2t_parse(t2t, data);
if (err) {
printk("Not enought memory to read whole tag. Printing what have been read.\n");
nfc_t2t_printout(t2t);
struct nfc_t2t_tlv_block *tlv_block = t2t->tlv_block_array;
for (size_t i = 0; i < t2t->tlv_count; i++) {
if (tlv_block->tag == NFC_T2T_TLV_NDEF_MESSAGE) {
ndef_data_analyze(tlv_block->value, tlv_block->length);
tlv_block++;
st25r3911b_nfca_tag_sleep();
k_work_reschedule(&transmit_work, K_MSEC(TRANSMIT_DELAY));
static int t2t_on_data_read(const uint8_t *data, size_t data_len,
void (*t2t_read_complete)(uint8_t *))
int err;
int ftd;
uint8_t block_to_read;
uint16_t offset = 0;
static uint8_t block_num;
block_to_read = t2t.data_bytes / NFC_T2T_BLOCK_SIZE;
offset = block_num * NFC_T2T_BLOCK_SIZE;
memcpy(t2t.data + offset, data, data_len);
block_num += TAG_TYPE_2_BLOCKS_PER_EXCHANGE;
if (block_num > block_to_read) {
block_num = 0;
t2t.state = T2T_IDLE;
if (t2t_read_complete) {
t2t_read_complete(t2t.data);
return 0;
err = nfc_t2t_read_block_cmd_make(tx_data, sizeof(tx_data), block_num);
if (err) {
return err;
return err;
static int on_t2t_transfer_complete(const uint8_t *data, size_t len)
switch (t2t.state) {
case T2T_HEADER_READ:
t2t.data_bytes = TAG_TYPE_2_DATA_AREA_MULTIPLICATOR *
data[TAG_TYPE_2_DATA_AREA_SIZE_OFFSET];
if ((t2t.data_bytes + NFC_T2T_FIRST_DATA_BLOCK_OFFSET) > sizeof(t2t.data)) {
return -ENOMEM;
t2t.state = T2T_DATA_READ;
return t2t_on_data_read(data, len, t2t_data_read_complete);
case T2T_DATA_READ:
return -EFAULT;
static void transfer_handler(struct k_work *work)
nfc_tag_detect(false);
static void nfc_field_on(void)
printk("NFC field on.\n");
static void nfc_timeout(bool tag_sleep)
if (tag_sleep) {
printk("Tag sleep or no detected, sending ALL Request.\n");
} else if (tag_type == NFC_TAG_TYPE_T4T) {
nfc_t4t_isodep_on_timeout();
return;
} else {
/* Do nothing. */
/* Sleep will block processing loop. Accepted as it is short. */
k_sleep(K_MSEC(ALL_REQ_DELAY));
nfc_tag_detect(true);
static void nfc_field_off(void)
printk("NFC field off.\n");
static void tag_detected(const struct st25r3911b_nfca_sens_resp *sens_resp)
printk("Anticollision: 0x%x Platform: 0x%x.\n",
sens_resp->anticollison,
sens_resp->platform_info);
int err = st25r3911b_nfca_anticollision_start();
if (err) {
printk("Anticollision error: %d.\n", err);
static void anticollision_completed(const struct st25r3911b_nfca_tag_info *tag_info,
int err)
if (err) {
printk("Error during anticollision avoidance.\n");
return;
printk("Tag info, type: %d.\n", tag_info->type);
if (tag_info->type == ST25R3911B_NFCA_TAG_TYPE_T2T) {
printk("Type 2 Tag.\n");
tag_type = NFC_TAG_TYPE_T2T;
err = t2t_header_read();
if (err) {
printk("Type 2 Tag data read error %d.\n", err);
} else if (tag_info->type == ST25R3911B_NFCA_TAG_TYPE_T4T) {
printk("Type 4 Tag.\n");
tag_type = NFC_TAG_TYPE_T4T;
/* Send RATS command */
err = nfc_t4t_isodep_rats_send(NFC_T4T_ISODEP_FSD_256, 0);
if (err) {
printk("Type 4 Tag RATS sending error %d.\n", err);
} else {
printk("Unsupported tag type.\n");
return;
static void transfer_completed(const uint8_t *data, size_t len, int err)
if (err) {
printk("NFC Transfer error: %d.\n", err);
return;
switch (tag_type) {
case NFC_TAG_TYPE_T2T:
err = on_t2t_transfer_complete(data, len);
if (err) {
printk("NFC-A T2T read error: %d.\n", err);
case NFC_TAG_TYPE_T4T:
err = nfc_t4t_isodep_data_received(data, len, err);
if (err) {
printk("NFC-A T4T read error: %d.\n", err);
static void tag_sleep(void)
printk("Tag entered the Sleep state.\n");
static const struct st25r3911b_nfca_cb cb = {
.field_on = nfc_field_on,
.field_off = nfc_field_off,
.tag_detected = tag_detected,
.anticollision_completed = anticollision_completed,
.rx_timeout = nfc_timeout,
.transfer_completed = transfer_completed,
.tag_sleep = tag_sleep
static void t4t_isodep_selected(const struct nfc_t4t_isodep_tag *t4t_tag)
int err;
printk("NFC T4T selected.\n");
if ((t4t_tag->lp_divisor != 0) &&
(t4t_tag->lp_divisor != t4t_tag->pl_divisor)) {
printk("Unsupported bitrate divisor by Reader/Writer.\n");
err = nfc_t4t_hl_procedure_ndef_tag_app_select();
if (err) {
printk("NFC T4T app select err %d.\n", err);
return;
static void t4t_isodep_error(int err)
printk("ISO-DEP Protocol error %d.\n", err);
static void t4t_isodep_data_send(uint8_t *data, size_t data_len, uint32_t ftd)
int err;
tx_buf.data = data;
tx_buf.len = data_len;
if (err) {
printk("NFC T4T ISO-DEP transfer error: %d.\n", err);
static void t4t_isodep_received(const uint8_t *data, size_t data_len)
int err;
err = nfc_t4t_hl_procedure_on_data_received(data, data_len);
if (err) {
printk("NFC Type 4 Tag HL data received error: %d.\n", err);
static void t4t_isodep_deselected(void)
static const struct nfc_t4t_isodep_cb t4t_isodep_cb = {
.selected = t4t_isodep_selected,
.deselected = t4t_isodep_deselected,
.error = t4t_isodep_error,
.ready_to_send = t4t_isodep_data_send,
.data_received = t4t_isodep_received
static void t4t_hl_selected(enum nfc_t4t_hl_procedure_select type)
int err = 0;
switch (type) {
case NFC_T4T_HL_PROCEDURE_NDEF_APP_SELECT:
printk("NFC T4T NDEF Application selected.\n");
err = nfc_t4t_hl_procedure_cc_select();
if (err) {
printk("NFC T4T Capability Container select error: %d.\n",
err);
case NFC_T4T_HL_PROCEDURE_CC_SELECT:
printk("NFC T4T Capability Container file selected.\n");
err = nfc_t4t_hl_procedure_cc_read(&NFC_T4T_CC_DESC(t4t_cc));
if (err) {
printk("Capability Container read error: %d.\n", err);
case NFC_T4T_HL_PROCEDURE_NDEF_FILE_SELECT:
printk("NFC T4T NDEF file selected.\n");
err = nfc_t4t_hl_procedure_ndef_read(&NFC_T4T_CC_DESC(t4t_cc),
t4t.ndef[t4t.tlv_index], NFC_T4T_APDU_MAX_SIZE);
if (err) {
printk("NFC T4T NDEF file read error %d.\n", err);
if (err) {
static void t4t_hl_cc_read(struct nfc_t4t_cc_file *cc)
printk("NFC T4T Capability Container file read.\n");
for (size_t i = 0; i < cc->tlv_count; i++) {
int err;
struct nfc_t4t_tlv_block *tlv_block = &cc->tlv_block_array[i];
if ((tlv_block->type == NFC_T4T_TLV_BLOCK_TYPE_NDEF_FILE_CONTROL_TLV) &&
(tlv_block->value.read_access == NFC_T4T_TLV_BLOCK_CONTROL_FILE_READ_ACCESS_GRANTED)) {
err = nfc_t4t_hl_procedure_ndef_file_select(tlv_block->value.file_id);
if (err) {
printk("NFC T4T NDEF file select error: %d.\n", err);
return;
printk("No NDEF File TLV in Capability Container.");
static void t4t_hl_ndef_read(uint16_t file_id, const uint8_t *data, size_t len)
int err;
struct nfc_t4t_cc_file *cc;
struct nfc_t4t_tlv_block *tlv_block;
printk("NDEF file read, id: 0x%x.\n", file_id);
t4t.tlv_index++;
cc = &NFC_T4T_CC_DESC(t4t_cc);
for (size_t i = t4t.tlv_index; i < cc->tlv_count; i++) {
if (err) {
return;
t4t.tlv_index++;
nfc_t4t_cc_file_printout(cc);
tlv_block = cc->tlv_block_array;
if ((tlv_block[i].type == NFC_T4T_TLV_BLOCK_TYPE_NDEF_FILE_CONTROL_TLV) ||
(tlv_block[i].value.file.content != NULL)) {
ndef_data_analyze(nfc_t4t_ndef_file_msg_get(tlv_block[i].value.file.content),
nfc_t4t_ndef_file_msg_size_get(tlv_block[i].value.file.len));
t4t.tlv_index = 0;
err = nfc_t4t_isodep_tag_deselect();
if (err) {
printk("NFC T4T Deselect error: %d.\n", err);
static const struct nfc_t4t_hl_procedure_cb t4t_hl_procedure_cb = {
.selected = t4t_hl_selected,
.cc_read = t4t_hl_cc_read,
.ndef_read = t4t_hl_ndef_read
int err;
printk("Starting NFC TAG Reader example\n");
nfc_t4t_hl_procedure_cb_register(&t4t_hl_procedure_cb);
k_work_init_delayable(&transmit_work, transfer_handler);
err = nfc_t4t_isodep_init(tx_data, sizeof(tx_data),
t4t.data, sizeof(t4t.data),
&t4t_isodep_cb);
if (err) {
printk("NFC T4T ISO-DEP Protocol initialization failed err: %d.\n",
err);
return 0;
err = st25r3911b_nfca_init(events, ARRAY_SIZE(events), &cb);
if (err) {
printk("NFCA initialization failed err: %d.\n", err);
return 0;
err = st25r3911b_nfca_field_on();
if (err) {
printk("Field on error %d.", err);
return 0;
while (true) {
k_poll(events, ARRAY_SIZE(events), K_FOREVER);
err = st25r3911b_nfca_process();
if (err) {
printk("NFC-A process failed, err: %d.\n", err);
return 0;
ST25R3911B BOARD..
Help me to solve the error .
best regards
Ashleo.
