Custom board revision/extension with new Zephyr hardware model
I'm upgrading from SDK version v2.4 to v2.7 which introduces the new Zephyr hardware model and I'm struggling with the transition. I have two custom revisions is based off of the nrf5340dk:
In my v2.4 project I added the following to my CMakeLists.txt:
set(REVISIONS "foo_v4" "bar_v1")
if (NOT DEFINED BOARD_REVISION)
    string(REGEX MATCH "nrf5340dk_nrf5340_cpuapp@([a-zA-Z0-9_]+)" _ ${BOARD})
    set(BOARD_REVISION ${CMAKE_MATCH_1})
endif()
if (NOT BOARD_REVISION IN_LIST REVISIONS)
    message(FATAL_ERROR "${BOARD_REVISION} is invalid. Accepted revisions: ${REVISIONS}")
endif()
I then added the following files:
build/
  nrf5340dk_nrf5340_cpuapp_bar_v1.conf
  nrf5340dk_nrf5340_cpuapp_bar_v1.overlay
  nrf5340dk_nrf5340_cpuapp_foo_v4.conf
  nrf5340dk_nrf5340_cpuapp_foo_v4.overlay
Then I built with: west build -b nrf5340dk_nrf5340_cpuapp@foo_v4 --build-dir build/foo_v4
This worked great.
After updating to v2.7 I tweaked my CMakeLists.txt to match the new string, I tried to build with: west build -b nrf5340dk@foo_v4/nrf5340/cpuapp --build-dir=build/foo_v4
but I get the following error:
Invalid board revision: foo_v4
Board 'nrf5340dk' does not define any revisions.
Looking at the "Board Extensions" section of the documentation it seems like this should still be valid: docs.zephyrproject.org/.../board_porting.html
  • Hi dethredic,
    You shouldn't have to tweak CMakeLists.txt to make use of the board revision feature.
    I wonder if it's just because you haven't updated the nrf5340dk board's YAML file? See: Board Porting Guide — Zephyr Project Documentation.
    If you are concerned about changing the SDK files too much, perhaps you can consider using custom board files.
    Hieu
  • My application is a "freestanding application", so changing the SDK isn't a viable option since every developer on the project would need follow suit. I would also lose these changes when updating the SDK. Is there maybe a way to override / extend the board's YAML file from my application?
    I liked the idea of just using a revision of the nrf5340dk because:
    1. It's way simpler, only 2 files are needed to tweak some pins / add some configs
    2. I would get updates / fixes automatically as the SDK gets updated
    If there is no longer a way to use a custom revision without updating the SDK then I guess I will bite the bullet and implement a custom board
  • I think that would work, at least as a short term solution. Are you suggesting that I ignore the official revision field and just add a custom "REVISION" (or similar) cmake that will set DTC_OVERLAY_FILE/ EXTRA_CONF_FILE?
  • I got this working, but it feels super hacky:
    if (NOT MY_CUSTOM_REVISION IN_LIST REVISIONS)
        message(FATAL_ERROR "Revision '${MY_CUSTOM_REVISION}' is invalid. Accepted revisions: ${REVISIONS}")
    endif()
    set(DTC_OVERLAY_FILE ${CMAKE_CURRENT_SOURCE_DIR}/boards/nrf5340dk_nrf5340_cpuapp_${MY_CUSTOM_REVISION}.overlay)
    set(EXTRA_CONF_FILE ${CMAKE_CURRENT_SOURCE_DIR}/boards/nrf5340dk_nrf5340_cpuapp_${MY_CUSTOM_REVISION}.conf)
    Then I can build with
    west build -b nrf5340dk/nrf5340/cpuapp -- -DMY_CUSTOM_REVISION=foo_v4
    Any suggestions on a better way to do this without creating a new board would be welcome
  • Yes, exactly something like that. Since we are doing something different from the concept called Revision in Zephyr, it might be better to use a different term though. Perhaps variant, or model.
    This is of course not what most projects do usually, so I understand why you call it a little hacky.
    If you want a more mainstream solution, for the Kconfig part, you can create a new Kconfig for just the project and add a "Kconfig description 'overlay'" to set the default value of other configs differently.
    But I can't think of anything for Devicetree...
    By the way, regarding the setup that works for you in 2.4, are the overlay files under the "build" folder or the "boards" folder? I think it should be "boards?"
  • The overlay files are in the "boards" folder, just a typo.
    I still find it a little unfortunate that applications can't define a custom revision anymore. I'll think about it over the weekend and maybe see how much work creating new boards is going to be.
  • Would you like to also check this with the Zephyr community? Board revision management are mostly if not all Zephyr, so the community there might have better ideas.
