Hi could you provide any insight on the following issue:
Source code in main.c
Further information for engineer :-
Please note I performed the build using nrf5340dk_nrf5340_cpuapp_ns. If I build with nrf5340dk_nrf5340_cpuapp the output is visible in the console.
To test an alternative I installed zephyr on Windows 11 in accordance with the instructions on the zephyr site and performed the build from the command line. The build fails when using nrf5340dk_nrf5340_cpuapp_ns but not when using nrf5340dk_nrf5340_cpuapp. There appears to be an unresolved bug in zephyr which is causing this see https://github.com/zephyrproject-rtos/zephyr/issues/73988. Not sure if the issues are related but it may help you in your review.
Is it possible to .zip and upload the application folder that you are using? The one that stops responding when you set CONFIG_I2C=y?
Did you modify anything else, such as the board files? Or do you have some .overlay file in your application folder that could cause a pin conflict?
Edvin
Hi Edvin
Thanks for your prompt response.
I made no changes to dts files for the board, no changes in menuconfig and I have no overlay file in my hello_world project. I will .zip the folder as requested but can you clarify if you just need the files that I created or do you require the build folder included in the zip as this will obviously make it quite large.
I have succeeded in getting a modified version of the sample sht3xd working for an nrf5340dk board with an sht31 sensor attached to the default I2C pins (SCL to P1.03 SDA to P1.02) and including an nrf5340dk_nrf5340_cpuapp.overaly file in the boards folder (file content below).
For 'add build configuration' I selected the nrf5340dk_nrf5340_cpuapp.
The temp and humidity readings appear in the console.
I also included an nrf5340dk_nrf5340_cpuapp_dk file in the boards folder with exactly the same code. When I remove the build configuration and create a new one using nrf5340dk_nrf5340_cpuapp_dk it builds OK but when flashed to the board nothing appears in the console.
&i2c1 {
sht31: sht3xd@44 {
compatible = "sensirion,sht3xd";
reg = <0x44>;
label = "SHT31";
I notice that in the sht3xd sample none of the boards in the boards folder include an NS version. Is this a clue?
Many thanks for you help.
Seán
You can read about the difference between nrf5340dk_nrf5340_cpuapp and nrf5340dk_nrf5340_cpuapp_ns here. The main difference is that there are security features enabled when you are building for the *_ns. This means that if you want to use a particular peripheral from there, you need to assign it for that partition.
The main feature here is to make the device more secure. By splitting your application into two, you can have one part handling most of your application logic, and one part handling the important peripherals.
One example would be if you had an application controlling an elevator (or a set of elevators). Then you could have the main part of the application handling buttons, and controlling lights and doors, and communication between the elevators, but then you could have the secure partition being in charge of motor control. This means that if an attacker would be able to hack your device, he could push the buttons, close the doors and turn off the light, but he will not be able to tell it to crash into the basement.
But if this is not something you are using, you should build for the board that does not end with _ns. This is the part that by default has access to all the peripherals.
Edvin
Hi Edwin,
I had briefly read the documentation regarding security. I will study it in more detail in light of what you say. However I was influenced to use the *_ns version in light of the warning message that appears in the Add Build Configuration when a non ns buard is selected vis:-
"You are going to build without Cortex-M Security extensions. Consider selecting the _ns board target ......"
Based on this message I assumed, perhaps wrongly, that the _ns board should be used in all circumstances.
For the benefit of anybody who may be interested I have put the working code for the nrf5340dk using the sht31 sensor on github here:-
https://github.com/skealy/sht31
Please note however based on the above advice to use the nrf5340dk_nrf5340_cpuapp board and not the nrf5340dk_nrf5340_cpuapp_ns which is also included in the boards folder.
Thanks for your help and for responding so promptly.
Regards
Seán
