Error when trying to use nrfutil pkg generate
while trying to package my hex file from zephyr  and I have gotten the following error
nrfutil pkg generate --hw-version 52 --sd-req=0x00 \
        --application build/zephyr/zephyr.hex \
        --application-version 1 blinky.zip
|You are not providing a signature key, which means the DFU     |
|files will not be signed, and are vulnerable to tampering.     |
|This is only compatible with a signature-less bootloader and is|
|not suitable for production environments.                      |
  File "/opt/homebrew/bin/nrfutil", line 8, in <module>
    sys.exit(cli())
  File "/opt/homebrew/lib/python3.12/site-packages/click/core.py", line 829, in __call__
    return self.main(*args, **kwargs)
  File "/opt/homebrew/lib/python3.12/site-packages/click/core.py", line 782, in main
    rv = self.invoke(ctx)
  File "/opt/homebrew/lib/python3.12/site-packages/click/core.py", line 1259, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/opt/homebrew/lib/python3.12/site-packages/click/core.py", line 1066, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/opt/homebrew/lib/python3.12/site-packages/click/core.py", line 610, in invoke
    return callback(*args, **kwargs)
  File "/opt/homebrew/lib/python3.12/site-packages/nordicsemi/__main__.py", line 867, in generate
    package.generate_package(zipfile_path)
  File "/opt/homebrew/lib/python3.12/site-packages/nordicsemi/dfu/package.py", line 403, in generate_package
    for key, firmware_data in self.firmwares_data.iteritems():
AttributeError: 'dict' object has no attribute 'iteritems'
  • Ok, I understand.
    the nRF52840 dongle is pre-programmed with a serial bootloader, because it doesn't have a bootloader.
    However, to update the FW on the dongle, the intention is to use nRF Connect for Desktop - Programmer app. The dongle, however does require you to interfere with the dongle to put it back in DFU mode. Both the nRF5 SDK bootloader and the MCUBOOT bootloader are capable of doing this without interfering with the device, but not the particular bootloader that is preprogrammed into that dongle. If you want to change the pre-programmed bootloader on the dongle, you still need an eternal programmer to do so.
    Either way, the dongle is not intended for app development. It is meant as a companion tool. For app development, I suggest that you get hold of a proper development kit of some sort (nRF52840 DK). This has a built in/on board debugger, which makes development much easier. And if you intend to use the nRF Connect SDK (NCS, based on Zephyr), then you should use the mcuboot bootloader.
    You can however, build a sample in NCS, and program it to the dongle using nRF Connect for Desktop -> programmer. But that will be over serial, and you need to put the dongle in DFU mode by pressing the reset button (not the big button, but the small one next to it, going sideways).
    Edvin
  • Hello Edwin,
    Thank you for your response,
    but the problems is we require a small form factor + only BLE and USB which led us to the dongle,
    As of the moment, the firmware is no big of problem,
    The problem is with the nRF Connect, as is that it's interaction based, we require a CLI, no interaction based flashing solution for our deployment. Could you give any methods go forward with this?
    And related to the question of MCUBOOT, I remember seeing buttonless DFU using MCUBOOT on the nRF5 SDK,
    are the same available in the NCS?
  • There is no such thing as MCUBOOT in the nRF5 SDK. The MCUBOOT bootloader was introduced with NCS.
    Indeed, there is something called buttonless DFU in the nRF5 SDK. This is a BLE service that tells the nRF to enter DFU mode. In fact, you can use any kind of event that you can grab onto from the application to enter DFU mode. It can be a buttonpress, a particular BLE event (which is the case in the buttonless DFU example), it can be a particular UART or USB message.
    But please note that this is not the bootloader that is pre-programmed onto the nRF52840 dongle. If you want this kind of bootloader, you need to use an external programmer to re-program the nRF52dongle. Please see this blog post. Particularly notice the section on the REGOUT0 register.
    So what kind of bootloader do you want? Do you want to be able to program it over BLE? Or via USB only?
    BR,
    Edvin
  • Oh, this has given me good understanding!
    The kind of bootloader, I am looking for is it application to flash on the board without any external intervention from the physical world(such as button click)
    And how do you want to transfer the new application? Through USB? Through BLE (via mobile phone)?
