PPK2 stops power input for short periods of time in ampere mode causing device to reboot.
Hello.
Wiring 1:
wiring 2:
Background to the case: We tested this with 2 different ppk2s and always got the same results. Our custom board works fine if we wire it directly to the battery or use the ppk2 in source mode as a power supply. The problems start when we try to connect the battery to the ppk2 in amp mode to measure how much current the PCB draws. It seems that the PPK stops supplying power to the PCB for short periods of time, causing the PCB to restart on a regular basis. We have tested wiring 1 and wiring 2 several times. The results are the same.
What could cause this behaviour?
General info:
battery 3V 950mAh
Power Profiler v4.1.1
Arttu
Parents Reply
  • Hello, I am currently working with the same custom board as mentioned earlier in this thread with the exact same specifics and it seems this same old problem has risen again. Would you happen to have any information what couldve caused this problem? Because the problems has come back somewhere between the release of Power Profiler version v4.1.2. and the current one v4.3.1. So i am wondering if one of the newer updates have brought back any old known problem of some sorts.
    Aki-Petteri
