PPK2 stops power input for short periods of time in ampere mode causing device to reboot.
Hello.
Wiring 1:
wiring 2:
Background to the case: We tested this with 2 different ppk2s and always got the same results. Our custom board works fine if we wire it directly to the battery or use the ppk2 in source mode as a power supply. The problems start when we try to connect the battery to the ppk2 in amp mode to measure how much current the PCB draws. It seems that the PPK stops supplying power to the PCB for short periods of time, causing the PCB to restart on a regular basis. We have tested wiring 1 and wiring 2 several times. The results are the same.
What could cause this behaviour?
General info:
battery 3V 950mAh
Power Profiler v4.1.1
Arttu
  • I forgot to mention that,
    We use boost converter so it should be 3.3V at all times. boost converter accepts 400mV to 3.3V as input and should give 3.3V output. Also the Device operates completely normally without PPK. Wouldnt the brown-out power reset scenarios occur with just the battery as well if the battery would be the reason? Our tests point to ppk dropping power, not the battery.
    Arttu
  • Hi Arttu,
    Thanks for explaining the scenario. If you have a boost converter, the voltage level should not be problematic.
    Does this happen if you run the PPK2 in source meter mode and provide 3.0V to your PCB?
    If this issue happens even at low uA current consumption, small periods of switching in resistors should not have an impact, as the total capacitance in your design should be able to handle this. Could it be that there is a bad connection between to/from the PPK2?
    Monitoring the voltage after the PPK2 will help here to determine what happens.
    Håkon
  • Hi Håkon.
    The device runs normally in source mode. The problems only occur in ampere mode.
    We did run the test with 2 ppk few times, so its unlikely.
    I will get back to you after we are done testing this.
    Thank you.
    Arttu
  • After updating to  Power Profiler 4.1.2 our probleblems were fixed, now we cant re-create this reboot behaviour and everything seem to work as intended.
    Arttu
  • Hello, I am currently working with the same custom board as mentioned earlier in this thread with the exact same specifics and it seems this same old problem has risen again. Would you happen to have any information what couldve caused this problem? Because the problems has come back somewhere between the release of Power Profiler version v4.1.2. and the current one v4.3.1. So i am wondering if one of the newer updates have brought back any old known problem of some sorts.
    Aki-Petteri
