I have used the I2S echo sample project as a starting point and try to configure it to sample data from an I2S microphone running on the nRF5340.
However, I cannot get the I2S Master Clock to run at a multiple of the Bit Clock. There doesn't seem to be any configuration related to master clock setting in i2s_config.
I have verified that the Bit Clock and LR Clock runs at the expected frequencies using a logic analyser and observe that the Master Clock runs the same as Bit Clock...
Can someone please point me in the right direction for what I am missing?
Steinar Thon
Here is my code to setup and start the I2S interface:
#include <zephyr/drivers/i2s.h>
#define SAMPLE_FREQUENCY (48000)
#define SAMPLES_PER_BLOCK (96)
#define SAMPLE_BIT_WIDTH (32)
#define BYTES_PER_SAMPLE (4)
#define NUMBER_OF_CHANNELS (2)
#define TIMEOUT (1000)
#define I2S_RX_NODE DT_NODELABEL(i2s_rxtx)
#define BLOCK_COUNT (16)
#define BLOCK_SIZE (BYTES_PER_SAMPLE * SAMPLES_PER_BLOCK * NUMBER_OF_CHANNELS)
K_MEM_SLAB_DEFINE_STATIC(mem_slab, BLOCK_SIZE, BLOCK_COUNT, BLOCK_COUNT);
static const struct device *const i2s_dev_rx = DEVICE_DT_GET(I2S_RX_NODE);
static bool i2s_init(void)
struct i2s_config config;
if (!device_is_ready(i2s_dev_rx))
printk("%s is not ready\n", i2s_dev_rx->name);
return 0;
config.word_size = SAMPLE_BIT_WIDTH;
config.channels = NUMBER_OF_CHANNELS;
config.format = I2S_FMT_DATA_FORMAT_I2S;
config.options = I2S_OPT_BIT_CLK_MASTER | I2S_OPT_FRAME_CLK_MASTER;
config.frame_clk_freq = SAMPLE_FREQUENCY;
config.mem_slab = &mem_slab;
config.block_size = BLOCK_SIZE;
config.timeout = TIMEOUT;
int ret = i2s_configure(i2s_dev_rx, I2S_DIR_RX, &config);
if (ret < 0)
printk("Failed to configure RX stream: %d\n", ret);
return false;
ret = i2s_trigger(i2s_dev_rx, I2S_DIR_RX, I2S_TRIGGER_START);
if (ret < 0)
printk("Failed to trigger command I2S_TRIGGER_START on RX: %d\n", ret);
return false;
return true;
Here is the overlay to configure the I2S interface and pinout:
&pinctrl {
i2s0_default_alt: i2s0_default_alt {
group1 {
// I2S Mic
psels = <NRF_PSEL(I2S_SCK_M, 0, 27)>,
<NRF_PSEL(I2S_MCK, 1, 10)>,
<NRF_PSEL(I2S_LRCK_M, 1, 3)>,
<NRF_PSEL(I2S_SDIN, 1, 2)>;
&clock {
hfclkaudio-frequency = <12288000>;
i2s_rxtx: &i2s0 {
status = "okay";
pinctrl-0 = <&i2s0_default_alt>;
pinctrl-names = "default";
clock-source = "ACLK";
