So I'm trying to setup the driver files and default configurations for CS47L63 Hardware Codec. There are no build errors or flash errors but after flashing I get this error from the codec file.
<err> CS47L63: Tried writing to I2C, not supported
Am I missing something ?
This is my register configuration which I'm pushing to CS47L63, note that I got this from the audio application example directly
* Copyright (c) 2018 Nordic Semiconductor ASA
#ifndef _CS47L63_REG_CONF_H_
#define _CS47L63_REG_CONF_H_
#include "cs47l63_spec.h"
/* Magic value to signal a sleep instead of register address.
* This can be used e.g. after resets where time is needed before
* a device is ready.
* Note that this is a busy wait, and should only be used sparingly where fast
* execution is not critical.
* 0001 is used as the reg addr. In case of a fault, this reg is read only.
#define SPI_BUSY_WAIT 0x0001
#define SPI_BUSY_WAIT_US_1000 1000
#define SPI_BUSY_WAIT_US_3000 3000
#define MAX_VOLUME_REG_VAL 0x80
#define MAX_VOLUME_DB 64
#define OUT_VOLUME_DEFAULT 0x62
#define VOLUME_UPDATE_BIT (1 << 9)
#define CS47L63_SOFT_RESET_VAL 0x5A000000
/* clang-format off */
/* Set up clocks */
const uint32_t clock_configuration[][2] = {
{ CS47L63_SAMPLE_RATE3, 0x0012 },
{ CS47L63_SAMPLE_RATE2, 0x0002 },
{ CS47L63_SAMPLE_RATE1, 0x0003 },
{ CS47L63_SYSTEM_CLOCK1, 0x034C },
{ CS47L63_ASYNC_CLOCK1, 0x034C },
{ CS47L63_FLL1_CONTROL2, 0x88200008 },
{ CS47L63_FLL1_CONTROL3, 0x10000 },
{ CS47L63_FLL1_GPIO_CLOCK, 0x0005 },
{ CS47L63_FLL1_CONTROL1, 0x0001 },
/* clang-format on */
/* Set up GPIOs */
const uint32_t GPIO_configuration[][2] = {
{ CS47L63_GPIO6_CTRL1, 0x61000001 },
{ CS47L63_GPIO7_CTRL1, 0x61000001 },
{ CS47L63_GPIO8_CTRL1, 0x61000001 },
/* Enable CODEC LED */
{ CS47L63_GPIO10_CTRL1, 0x41008001 },
const uint32_t pdm_mic_enable_configure[][2] = {
/* Set MICBIASes */
{ CS47L63_LDO2_CTRL1, 0x0005 },
{ CS47L63_MICBIAS_CTRL1, 0x00EC },
{ CS47L63_MICBIAS_CTRL5, 0x0272 },
/* Enable IN1L */
{ CS47L63_INPUT_CONTROL, 0x000F },
/* Enable PDM mic as digital input */
{ CS47L63_INPUT1_CONTROL1, 0x50021 },
/* Un-mute and set gain to 0dB */
{ CS47L63_IN1L_CONTROL2, 0x800080 },
{ CS47L63_IN1R_CONTROL2, 0x800080 },
/* Volume Update */
{ CS47L63_INPUT_CONTROL3, 0x20000000 },
/* Send PDM MIC to I2S Tx */
{ CS47L63_ASP1TX1_INPUT1, 0x800010 },
{ CS47L63_ASP1TX2_INPUT1, 0x800011 },
/* Set up input */
const uint32_t line_in_enable[][2] = {
/* Select LINE-IN as analog input */
{ CS47L63_INPUT2_CONTROL1, 0x50020 },
/* Set IN2L and IN2R to single-ended */
{ CS47L63_IN2L_CONTROL1, 0x10000000 },
{ CS47L63_IN2R_CONTROL1, 0x10000000 },
{ CS47L63_IN2L_CONTROL2, 0x800080 },
{ CS47L63_IN2R_CONTROL2, 0x800080 },
/* Enable IN2L and IN2R */
/* Volume Update */
/* Route IN2L and IN2R to I2S */
{ CS47L63_ASP1TX1_INPUT1, 0x800012 },
{ CS47L63_ASP1TX2_INPUT1, 0x800013 },
/* Set up output */
const uint32_t output_enable[][2] = {
{ CS47L63_OUTPUT_ENABLE_1, 0x0002 },
{ CS47L63_OUT1L_INPUT1, 0x800020 },
{ CS47L63_OUT1L_INPUT2, 0x800021 },
const uint32_t output_disable[][2] = {
{ CS47L63_OUTPUT_ENABLE_1, 0x00 },
/* Set up ASP1 (I2S) */
const uint32_t asp1_enable[][2] = {
/* Enable ASP1 GPIOs */
{ CS47L63_GPIO1_CTRL1, 0x61000000 },
{ CS47L63_GPIO2_CTRL1, 0xE1000000 },
{ CS47L63_GPIO3_CTRL1, 0xE1000000 },
{ CS47L63_GPIO4_CTRL1, 0xE1000000 },
{ CS47L63_GPIO5_CTRL1, 0x61000001 },
/* Set correct sample rate */
#if CONFIG_AUDIO_SAMPLE_RATE_16000_HZ
{ CS47L63_SAMPLE_RATE1, 0x000000012 },
#elif CONFIG_AUDIO_SAMPLE_RATE_24000_HZ
{ CS47L63_SAMPLE_RATE1, 0x000000002 },
#elif CONFIG_AUDIO_SAMPLE_RATE_48000_HZ
{ CS47L63_SAMPLE_RATE1, 0x000000003 },
/* Disable unused sample rates */
{ CS47L63_SAMPLE_RATE2, 0 },
{ CS47L63_SAMPLE_RATE3, 0 },
{ CS47L63_SAMPLE_RATE4, 0 },
/* Set ASP1 in slave mode and 16 bit per channel */
{ CS47L63_ASP1_CONTROL2, 0x10100200 },
{ CS47L63_ASP1_CONTROL3, 0x0000 },
{ CS47L63_ASP1_DATA_CONTROL1, 0x0020 },
{ CS47L63_ASP1_DATA_CONTROL5, 0x0020 },
{ CS47L63_ASP1_ENABLES1, 0x30003 },
const uint32_t FLL_toggle[][2] = {
{ CS47L63_FLL1_CONTROL1, 0x0000 },
{ SPI_BUSY_WAIT, SPI_BUSY_WAIT_US_1000 },
const uint32_t soft_reset[][2] = {
{ CS47L63_SFT_RESET, CS47L63_SOFT_RESET_VAL },
{ SPI_BUSY_WAIT, SPI_BUSY_WAIT_US_3000 },
#endif /* _CS47L63_REG_CONF_H_ */
my execution sequence is as follows
hw_codec_init();
hw_codec_default_conf_enable();
(both the functions are taken from hw_codec header file given in audio application)
What could be the possible issue?
