I want to send audio to multiple headset(Readily avaiable from market), So is there any hardware, Software solution avaiable for that.
So, Is there any Hardware and Software Solution to send audio to multiple Headsets.
Thank You
Bivay
Thank You
Bivay
We do have hardware and software solution for the same.
The nRF5340 Audio Development Kit (DK) is a hardware platform that can be used for this purpose. It is configurable and can function as a USB dongle to send or receive audio data from a PC. It can also function as a headset or a True Wireless Stereo (TWS) Earbud.
As for the software, we have a reference application for the nRF5340 Audio DK that can be used to set up the functionality you describe using LE Audio. With two such DKs, you could have the application up and running.
LE Audio introduces the feature of Multi-Stream Audio, which allows for multiple audio streams between an audio source and different sinks.
Please take a look at the following tickets too:
Hope this helps you begin.
Priyanka
Thank you for your response.
How many headsets can the nRF5340 Audio Development Kit (DK) transmit audio ?
As mentioned here, there should be no limit to how many headsets can be connected simultaneously in a broadcast, except for the range, which can reduce when a lot of headsets are connected.
-Priyanka
Also, I want know How many headset I can use if need send audio to individuals Headset.
I am not clear about the question. In BIS mode you can connect to an unlimited number of headsets. Is this what you asked?
-Priyanka
