I want to send audio to multiple headset(Readily avaiable from market), So is there any hardware, Software solution avaiable for that.
So, Is there any Hardware and Software Solution to send audio to multiple Headsets.
Thank You
Bivay
Thank You
Bivay
For broadcast audio, there's no limited number of receivers, since there's no connection between gateway and headset. Any headsets in the range of broadcaster can receive and play the stream. But all receivers are received the same stream. And now the stream number is two because of the input interface and also the CPU resource for encoding.
For connected based audio, we haven't tested the maximum number of connected devices, but since it is connected based, so the bandwidth will be shared between each connection links, which means the more connections then less audio quality will be expected. And also, the the number of stream contents is limited with CPU resource for encoding. But we have them well tested for one gateway to two headsets.
bivay said:I want to connect multiple headset, and also want option to send audio to specific headset.
So I guess you are looking for just a broadcast to a specific headset? Then you can use the broadcast and the broadcaster can encrypt the stream and just share the key to specific headsets. Or are you looking for two way communication, i.e. back from headset ?
Also could you tell me your specific application, i.e. what do you want this connection for?
-Priyanka
Sorry for delay,
I have a team having each person a headphone(Readily available in market earbuds/headsets), I want to pair them all with this master device, this device should have ability to pair to each headset and stream audio to all headset simultaneously.
Hi Brevy,
For connected based audio, we have tested well only for one gateway to two headsets. We haven't tested the maximum number of connected devices, but since it is connected based, so the bandwidth will be shared between each connection links, which means the more connections then less audio quality will be expected. And also, the the number of stream contents is limited with CPU resource for encoding.
-Priyanka
