Hi there,
The nrf5340_audio application provides a -DFILE_SUFFIX=fota overlay that adds FOTA capabilities to the application. This FOTA is introduced via Sysbuild configuration files. This configuration compiles successfully.
Instead of FOTA, I would like to enable Serial Recovery mode with CDC ACM transport.
I have successfully enabled this mode on the nRF5340 with other samples that don't use Sysbuild. I achieved this by following the relevant samples at https://github.com/hellesvik-nordic/samples_for_nrf_connect_sdk/tree/main/bootloader_samples/serial_recovery. This allows me to update the application and network core with two separate .bin files contained within the dfu_application.zip. I believe this is called non-simultaneous DFU.
However, I can't get the same KConfig options working in Sysbuild in the nrf5340_audio application.
My file structure is:
sysbuild.conf
# Enable bootloaders for both cores SB_CONFIG_BOOTLOADER_MCUBOOT=y SB_CONFIG_SECURE_BOOT_NETCORE=y SB_CONFIG_NETCORE_APP_UPDATE=y
CONFIG_MAIN_STACK_SIZE=10240 # Flash CONFIG_FLASH=y CONFIG_FPROTECT=y # MCUBoot serial CONFIG_MCUBOOT_SERIAL=y CONFIG_MCUBOOT_SERIAL_DIRECT_IMAGE_UPLOAD=y # Decrease memory footprint CONFIG_CBPRINTF_NANO=y CONFIG_TIMESLICING=n CONFIG_BOOT_BANNER=n CONFIG_CONSOLE=n CONFIG_CONSOLE_HANDLER=n CONFIG_UART_CONSOLE=n CONFIG_RTT_CONSOLE=n CONFIG_USE_SEGGER_RTT=n CONFIG_LOG=n CONFIG_RESET_ON_FATAL_ERROR=n # The following configurations are required to support serial recovery of the # network image CONFIG_PCD_APP=y # The network core cannot access external flash directly. The flash simulator must be used to # provide a memory region that is used to forward the new firmware to the network core. CONFIG_FLASH_SIMULATOR=y CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y CONFIG_FLASH_SIMULATOR_STATS=n CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y CONFIG_NRF53_RECOVERY_NETWORK_CORE=y CONFIG_MCUBOOT_INDICATION_LED=y # My additions CONFIG_BOOT_SERIAL_CDC_ACM=y # CONFIG_PM_PARTITION_SIZE_MCUBOOT=0xE800 CONFIG_PM_PARTITION_SIZE_MCUBOOT=0xFC00 CONFIG_USB_DEVICE_VID=0x1915 CONFIG_USB_DEVICE_PID=0x5300
In file included from /Users/FARLY7/workspace/aura/aura-firmware/bootloader/mcuboot/boot/zephyr/include/sysflash/sysflash.h:10, from /Users/FARLY7/workspace/aura/aura-firmware/bootloader/mcuboot/boot/bootutil/src/bootutil_priv.h:33, from /Users/FARLY7/workspace/aura/aura-firmware/bootloader/mcuboot/boot/bootutil/src/tlv.c:24: /Users/FARLY7/workspace/aura/aura-firmware/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h: In function '__flash_area_ids_for_slot': /Users/FARLY7/workspace/aura/aura-firmware/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:48:62: error: 'PM_MCUBOOT_SECONDARY_1_ID' undeclared (first use in this function); did you mean 'PM_MCUBOOT_SECONDARY_ID'? 48 | #define FLASH_AREA_IMAGE_1_SLOTS PM_MCUBOOT_PRIMARY_1_ID, PM_MCUBOOT_SECONDARY_1_ID | ^~~~~~~~~~~~~~~~~~~~~~~~~ /Users/FARLY7/workspace/aura/aura-firmware/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:55:29: note: in expansion of macro 'FLASH_AREA_IMAGE_1_SLOTS' 55 | FLASH_AREA_IMAGE_1_SLOTS | ^~~~~~~~~~~~~~~~~~~~~~~~ /Users/FARLY7/workspace/aura/aura-firmware/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:67:9: note: in expansion of macro 'ALL_AVAILABLE_SLOTS' 67 | ALL_AVAILABLE_SLOTS | ^~~~~~~~~~~~~~~~~~~ /Users/FARLY7/workspace/aura/aura-firmware/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:48:62: note: each undeclared identifier is reported only once for each function it appears in 48 | #define FLASH_AREA_IMAGE_1_SLOTS PM_MCUBOOT_PRIMARY_1_ID, PM_MCUBOOT_SECONDARY_1_ID | ^~~~~~~~~~~~~~~~~~~~~~~~~ /Users/FARLY7/workspace/aura/aura-firmware/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:55:29: note: in expansion of macro 'FLASH_AREA_IMAGE_1_SLOTS' 55 | FLASH_AREA_IMAGE_1_SLOTS | ^~~~~~~~~~~~~~~~~~~~~~~~ /Users/FARLY7/workspace/aura/aura-firmware/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:67:9: note: in expansion of macro 'ALL_AVAILABLE_SLOTS' 67 | ALL_AVAILABLE_SLOTS | ^~~~~~~~~~~~~~~~~~~ [95/322] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
