Bluetooth Mesh -> When associating a vendor model to an Element, the Nordic Mesh App fails to retrieve the models if there are more than one model.
When creating a Bluetooth Mesh Vendor model (https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/protocols/bt/bt_mesh/vendor_model/dev_overview.html) and if the vendor model is associated to the first element:
static const struct bt_mesh_elem elements[] = {
BT_MESH_ELEM(0, root_models, vnd_sampleModel ),
//BT_MESH_ELEM(1, sensrvModel, BT_MESH_MODEL_NONE ), // For some reason enabling further Models makes the NRF app unable to get the models.
The Mesh App works fine and can retrieve the node available models, including the vendor one, and work with it.  The same is true if instead of vnd_sampleModel it is replaced by the standard BT_MESH_MODE_NONE. So nothing new here.
The issue arises, if, for example, on the above case the Element 1 is activated. If Element 0, has the vendor model set as none, the Mesh app works fine and can retrieve both Element 0 and Element 1.
If however the vendor model is declared either on the Element 0 or Element 1, the Mesh app fails to retrieve the available models.
    What NCS version are you using? Are you using Mesh App on an Android phone or iPhone?
    Amanda H.
    The NCS version is nRF Connect SDK v3.5.99-ncs1-1, but the issue also happens on standard zephyr.
    I'm using the Android version of the app.
    The app hangs on the "Send composition data get" when provisioning.
  • Are you using vanilla Zepher? If so, Could you try to use the nRF Connect SDK (NCS) last version? Since our support is based on NCS.
  • Hi, I have the issue both in the NCS release and in the standard Zephyr:
    *** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
    Initializing...
    Bluetooth initialized
    Mesh initialized
    If you pick up the standard example on the bluetooth folder:
    (...)/zephyr/samples/bluetooth/mesh
    And change the example to add a generic vendor model on main.c file on line 214 just below the gen_onoff_set function:
    #define MOD_LF 0x0000 // Linux Foundation model id
    #define OP_VENDOR_SAMPLE_ACTION1 BT_MESH_MODEL_OP_3( 0x00, BT_COMP_ID_LF)
    static int vnd_action1(const struct bt_mesh_model *model, struct bt_mesh_msg_ctx *ctx, struct net_buf_simple *buf) {
    return 0;
    static const struct bt_mesh_model_op vnd_sample_ops[] = {
    { OP_VENDOR_SAMPLE_ACTION1, BT_MESH_LEN_EXACT(0), vnd_action1 },
    BT_MESH_MODEL_OP_END,
    static const struct bt_mesh_model vnd_sampleModel[] = { //
    BT_MESH_MODEL_VND( BT_COMP_ID_LF, MOD_LF, vnd_sample_ops, NULL, NULL ),
    and above the bt_mesh_model_op gen_onoff_srv_op declaration and then create a new model definition below the models declaration, for example:
    static const struct bt_mesh_model other_models[] = {
    BT_MESH_MODEL(BT_MESH_MODEL_ID_GEN_ONOFF_CLI, gen_onoff_cli_op, NULL,
    NULL),
    And change the elements declaration to:
    BT_MESH_ELEM(0, models, vnd_sampleModel ),
    BT_MESH_ELEM(1, other_models, BT_MESH_MODEL_NONE ),
    Compile it, flash it (I'm using the NRF52840 dongle), when provisioning BOTH applications for Android and iPhone hang when retrieving the available models.
    If element 1 is deleted, then the provisioning works fine.
    If the vnd_sampleModel is moved to element 1, it also fails.
    I can reproduce the issue with your modification and see the following debug log:
    Mesh initialized
    [00:00:01.709,503] <wrn> bt_l2cap: bt_l2cap_recv: Ignoring data for unknown channel ID 0x003a
    [00:00:06.489,227] <dbg> bt_mesh_access: bt_mesh_model_recv: app_idx 0xfffe src 0x0001 dst 0x0003
    [00:00:06.489,288] <dbg> bt_mesh_access: bt_mesh_model_recv: len 3: 800800
    [00:00:06.489,288] <dbg> bt_mesh_access: bt_mesh_model_recv: OpCode 0x00008008
    [00:00:06.489,318] <err> bt_mesh_access: comp_add_elem: Too large device composition
    [00:00:06.489,349] <err> bt_mesh_cfg_srv: dev_comp_data_get: Failed to get CDP0, err:-7
     This means, the max TX segment configuration is not correct, and thus there are not enough buffers to store bigger composition data. Please try to set CONFIG_BT_MESH_TX_SEG_MAX=5 to allow transmissions of messages up to 5 segments long to solve the problems. After adding this config, I see this issue goes away with the Android app on my side.
    -Amanda H.
  • Hi, sorry for the delay.
    Yes, the setting does indeed resolve the issue. Thank you.
