This is my log output when i connect to my ethernet
# General config CONFIG_NEWLIB_LIBC=y CONFIG_MAIN_STACK_SIZE=8192 # nothing here CONFIG_SPI=y CONFIG_NET_L2_ETHERNET=y CONFIG_ETH_W5500=y CONFIG_ETH_W5500_TIMEOUT=1000 CONFIG_NET_DHCPV4=y # CONFIG_CONSOLE=y CONFIG_GPIO=y CONFIG_NETWORKING=y # CONFIG_NET_IPV6=y CONFIG_NET_IPV4=y CONFIG_NET_IPV6=y CONFIG_NET_ARP=y CONFIG_NET_TCP=y CONFIG_NET_UDP=y #CONFIG_APP_EVENT_MANAGER=y CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y CONFIG_NET_DHCPV4_INITIAL_DELAY_MAX=2 CONFIG_ENTROPY_GENERATOR=y CONFIG_TEST_RANDOM_GENERATOR=y CONFIG_INIT_STACKS=y CONFIG_NET_STATISTICS=y # CONFIG_MBEDTLS_USER_CONFIG_FILE="user-tls.h" # CONFIG_NET_PKT_RX_COUNT=32 # CONFIG_NET_PKT_TX_COUNT=32 # CONFIG_NET_BUF_RX_COUNT=32 # CONFIG_NET_BUF_TX_COUNT=32 # CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=3 # CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=4 #CONFIG_NET_MAX_CONTEXTS=10 CONFIG_NET_MGMT=y CONFIG_NET_MGMT_EVENT=y CONFIG_NET_LOG=y CONFIG_LOG=y # # Network address config CONFIG_NET_CONFIG_SETTINGS=y CONFIG_NET_CONFIG_NEED_IPV6=y CONFIG_NET_CONFIG_NEED_IPV4=y # CONFIG_NET_CONFIG_MY_IPV6_ADDR="2001:db8:200::1" # CONFIG_NET_CONFIG_PEER_IPV6_ADDR="2001:db8:200::2" # CONFIG_NET_CONFIG_MY_IPV4_ADDR="192.168.1.160" # CONFIG_NET_CONFIG_PEER_IPV4_ADDR="192.168.1.161" # CONFIG_NET_CONFIG_MY_IPV4_GW="192.168.1.1" # CONFIG_ETH_NATIVE_POSIX_RANDOM_MAC=n # #CONFIG_ETH_NATIVE_POSIX_MAC_ADDR="00:00:5e:00:53:c8" # CONFIG_ETH_NATIVE_POSIX_SETUP_SCRIPT="echo" # CONFIG_ETH_NATIVE_POSIX_DRV_NAME="w5500" CONFIG_DNS_RESOLVER=y CONFIG_DNS_SERVER_IP_ADDRESSES=y CONFIG_DNS_SERVER1="8.8.8.8" # CONFIG_ETH_NATIVE_POSIX=y # CONFIG_ETH_NATIVE_POSIX_RANDOM_MAC=y CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=3 CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=4 CONFIG_NET_MAX_CONTEXTS=10 CONFIG_NET_SHELL=y # CONFIG_NET_DEFAULT_IF_ETHERNET=y CONFIG_NET_SOCKETS=y # CONFIG_NET_SOCKETS_POSIX_NAMES=y # CONFIG_UART_CONSOLE=n # CONFIG_RTT_CONSOLE=y CONFIG_NET_CONFIG_SETTINGS=y CONFIG_NET_CONFIG_NEED_IPV6=y CONFIG_NET_CONFIG_NEED_IPV4=y # CONFIG_NET_CONFIG_MY_IPV4_ADDR="172.26.68.241" # CONFIG_NET_CONFIG_PEER_IPV4_ADDR="192.0.2.2" # CONFIG_NET_CONFIG_MY_IPV4_NETMASK="255.255.254.0" # CONFIG_NET_CONFIG_MY_IPV4_GW="172.26.68.1" # CONFIG_NET_IPV6=n # //////////////////////////////////// CONFIG_ETHERNET_LOG_LEVEL_DBG=n CONFIG_NET_L2_ETHERNET_LOG_LEVEL_DBG=n CONFIG_NET_DHCPV4_LOG_LEVEL_DBG=n CONFIG_NET_L2_ETHERNET_MGMT=y CONFIG_AWS_ENDPOINT="a31gokdeokxhl8-ats.iot.eu-west-1.amazonaws.com" CONFIG_AWS_MQTT_PORT=8883 CONFIG_AWS_THING_NAME="zephyr_sample" CONFIG_AWS_PUBLISH_TOPIC="zephyr_sample/data" CONFIG_AWS_SUBSCRIBE_TOPIC="zephyr_sample/downlink" CONFIG_AWS_TEST_SUITE_DQP=n # CONFIG_MAIN_STACK_SIZE=4096 CONFIG_ENTROPY_GENERATOR=y CONFIG_TEST_RANDOM_GENERATOR=y CONFIG_INIT_STACKS=y CONFIG_HW_STACK_PROTECTION=y # CONFIG_REQUIRES_FULL_LIBC=y CONFIG_SNTP=y CONFIG_JSON_LIBRARY=y CONFIG_POSIX_API=y # DNS CONFIG_DNS_RESOLVER=y CONFIG_DNS_RESOLVER_ADDITIONAL_BUF_CTR=2 CONFIG_DNS_RESOLVER_MAX_SERVERS=1 CONFIG_DNS_SERVER_IP_ADDRESSES=y CONFIG_DNS_SERVER1="8.8.8.8" CONFIG_NET_SOCKETS_DNS_TIMEOUT=5000 CONFIG_DNS_RESOLVER_LOG_LEVEL_DBG=n # Generic networking options CONFIG_NETWORKING=y CONFIG_NET_UDP=y CONFIG_NET_TCP=y CONFIG_NET_IPV4=y CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_SOCKOPT_TLS=y # Logging CONFIG_LOG=y # Network buffers CONFIG_NET_PKT_RX_COUNT=32 CONFIG_NET_PKT_TX_COUNT=16 CONFIG_NET_BUF_RX_COUNT=64 CONFIG_NET_BUF_TX_COUNT=32 # MQTT # MQTT CONFIG_MQTT_LIB=y CONFIG_MQTT_LIB_TLS=y CONFIG_MQTT_KEEPALIVE=60 # TLS CONFIG_MBEDTLS=y CONFIG_MBEDTLS_BUILTIN=y CONFIG_MBEDTLS_ENABLE_HEAP=y CONFIG_MBEDTLS_HEAP_SIZE=65536 CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=16384 CONFIG_MBEDTLS_PEM_CERTIFICATE_FORMAT=y CONFIG_MBEDTLS_SERVER_NAME_INDICATION=y CONFIG_MBEDTLS_AES_ROM_TABLES=y CONFIG_MBEDTLS_TLS_VERSION_1_2=y CONFIG_MBEDTLS_MEMORY_DEBUG=y CONFIG_MBEDTLS_HAVE_TIME_DATE=y CONFIG_MBEDTLS_SSL_ALPN=y # CONFIG_MQTT_LIB_TLS_USE_ALPN=y CONFIG_MBEDTLS_ECP_C=y CONFIG_MBEDTLS_ECDSA_C=y CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED=y CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED=y CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED=y CONFIG_MBEDTLS_HASH_SHA512_ENABLED=y CONFIG_MBEDTLS_SERVER_NAME_INDICATION=y
this is my prj.conf file
I am building the default AWS_IOT_MQTT SAMPLE. i dont know where i am getting the issue.
Since it acquires time from SNTP and some connection is happening with AWS.
Please help
