Problem uploading to AWS using NRF5340 and w5500 ethernet on MQTT sample
This is my log output when i connect to my ethernet
# General config
CONFIG_NEWLIB_LIBC=y
CONFIG_MAIN_STACK_SIZE=8192
# nothing here
CONFIG_SPI=y
CONFIG_NET_L2_ETHERNET=y
CONFIG_ETH_W5500=y
CONFIG_ETH_W5500_TIMEOUT=1000
CONFIG_NET_DHCPV4=y
# CONFIG_CONSOLE=y
CONFIG_GPIO=y
CONFIG_NETWORKING=y
# CONFIG_NET_IPV6=y
CONFIG_NET_IPV4=y
CONFIG_NET_IPV6=y
CONFIG_NET_ARP=y
CONFIG_NET_TCP=y
CONFIG_NET_UDP=y
#CONFIG_APP_EVENT_MANAGER=y
CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
CONFIG_NET_DHCPV4_INITIAL_DELAY_MAX=2
CONFIG_ENTROPY_GENERATOR=y
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_INIT_STACKS=y
CONFIG_NET_STATISTICS=y
# CONFIG_MBEDTLS_USER_CONFIG_FILE="user-tls.h"
# CONFIG_NET_PKT_RX_COUNT=32
# CONFIG_NET_PKT_TX_COUNT=32
# CONFIG_NET_BUF_RX_COUNT=32
# CONFIG_NET_BUF_TX_COUNT=32
# CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=3
# CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=4
#CONFIG_NET_MAX_CONTEXTS=10
CONFIG_NET_MGMT=y
CONFIG_NET_MGMT_EVENT=y
CONFIG_NET_LOG=y
CONFIG_LOG=y
# # Network address config
CONFIG_NET_CONFIG_SETTINGS=y
CONFIG_NET_CONFIG_NEED_IPV6=y
CONFIG_NET_CONFIG_NEED_IPV4=y
# CONFIG_NET_CONFIG_MY_IPV6_ADDR="2001:db8:200::1"
# CONFIG_NET_CONFIG_PEER_IPV6_ADDR="2001:db8:200::2"
# CONFIG_NET_CONFIG_MY_IPV4_ADDR="192.168.1.160"
# CONFIG_NET_CONFIG_PEER_IPV4_ADDR="192.168.1.161"
# CONFIG_NET_CONFIG_MY_IPV4_GW="192.168.1.1"
#  CONFIG_ETH_NATIVE_POSIX_RANDOM_MAC=n
# #CONFIG_ETH_NATIVE_POSIX_MAC_ADDR="00:00:5e:00:53:c8"
# CONFIG_ETH_NATIVE_POSIX_SETUP_SCRIPT="echo"
# CONFIG_ETH_NATIVE_POSIX_DRV_NAME="w5500"
CONFIG_DNS_RESOLVER=y
CONFIG_DNS_SERVER_IP_ADDRESSES=y
CONFIG_DNS_SERVER1="8.8.8.8"
# CONFIG_ETH_NATIVE_POSIX=y
# CONFIG_ETH_NATIVE_POSIX_RANDOM_MAC=y
CONFIG_NET_SHELL=y
# CONFIG_NET_DEFAULT_IF_ETHERNET=y
CONFIG_NET_SOCKETS=y
# CONFIG_NET_SOCKETS_POSIX_NAMES=y
# CONFIG_UART_CONSOLE=n
# CONFIG_RTT_CONSOLE=y
# CONFIG_NET_CONFIG_MY_IPV4_ADDR="172.26.68.241"
# CONFIG_NET_CONFIG_PEER_IPV4_ADDR="192.0.2.2"
# CONFIG_NET_CONFIG_MY_IPV4_NETMASK="255.255.254.0"
# CONFIG_NET_CONFIG_MY_IPV4_GW="172.26.68.1"
# CONFIG_NET_IPV6=n
CONFIG_ETHERNET_LOG_LEVEL_DBG=n
CONFIG_NET_L2_ETHERNET_LOG_LEVEL_DBG=n
CONFIG_NET_DHCPV4_LOG_LEVEL_DBG=n
CONFIG_NET_L2_ETHERNET_MGMT=y
CONFIG_AWS_ENDPOINT="a31gokdeokxhl8-ats.iot.eu-west-1.amazonaws.com"
CONFIG_AWS_MQTT_PORT=8883
CONFIG_AWS_THING_NAME="zephyr_sample"
CONFIG_AWS_PUBLISH_TOPIC="zephyr_sample/data"
CONFIG_AWS_SUBSCRIBE_TOPIC="zephyr_sample/downlink"
CONFIG_AWS_TEST_SUITE_DQP=n
# CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HW_STACK_PROTECTION=y
# CONFIG_REQUIRES_FULL_LIBC=y
CONFIG_SNTP=y
CONFIG_JSON_LIBRARY=y
CONFIG_POSIX_API=y
# DNS
CONFIG_DNS_RESOLVER_ADDITIONAL_BUF_CTR=2
CONFIG_DNS_RESOLVER_MAX_SERVERS=1
CONFIG_NET_SOCKETS_DNS_TIMEOUT=5000
CONFIG_DNS_RESOLVER_LOG_LEVEL_DBG=n
# Generic networking options
CONFIG_NETWORKING=y
CONFIG_NET_UDP=y
CONFIG_NET_TCP=y
CONFIG_NET_IPV4=y
CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
# Logging
CONFIG_LOG=y
# Network buffers
CONFIG_NET_PKT_TX_COUNT=16
CONFIG_NET_BUF_RX_COUNT=64
# MQTT
# MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=y
CONFIG_MQTT_KEEPALIVE=60
# TLS
CONFIG_MBEDTLS=y
CONFIG_MBEDTLS_BUILTIN=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=65536
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=16384
CONFIG_MBEDTLS_PEM_CERTIFICATE_FORMAT=y
CONFIG_MBEDTLS_SERVER_NAME_INDICATION=y
CONFIG_MBEDTLS_AES_ROM_TABLES=y
CONFIG_MBEDTLS_TLS_VERSION_1_2=y
CONFIG_MBEDTLS_MEMORY_DEBUG=y
CONFIG_MBEDTLS_HAVE_TIME_DATE=y
CONFIG_MBEDTLS_SSL_ALPN=y
# CONFIG_MQTT_LIB_TLS_USE_ALPN=y
CONFIG_MBEDTLS_ECP_C=y
CONFIG_MBEDTLS_ECDSA_C=y
CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED=y
CONFIG_MBEDTLS_HASH_SHA512_ENABLED=y
this is my prj.conf file
I am building the default AWS_IOT_MQTT SAMPLE. i dont know where i am getting the issue.
Since it acquires time from SNTP and some connection is happening with AWS.
Please help
