I'm just trying to get my feet under me to write some code for the nina-306 module. I'm playing along, and following the dev academy course. I can't tell if this worked or not (my boards not coming till monday so I can't try to flash it).
After I build, in the terminal I see this:
* Executing task: nRF Connect: Build: blinky/build_1 (active)
Building blinky
west build --build-dir /Users/eric/Documents/work/beacon/blinky/build_1 /Users/eric/Documents/work/beacon/blinky
[7/7] Linking C executable zephyr/zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 21912 B 1 MB 2.09%
RAM: 7680 B 256 KB 2.93%
IDT_LIST: 0 GB 32 KB 0.00%
Generating files from /Users/eric/Documents/work/beacon/blinky/build_1/zephyr/zephyr.elf for board: ubx_evkninab3
* Terminal will be reused by tasks, press any key to close it.
But under problems I see:
CMake Error at /opt/nordic/ncs/v2.7.0-rc2/zephyr/cmake/modules/extensions.cmake:3333 (message):BOARD is not being defined on the CMake command-line, in the environment or
by the app.
I did define the board by picking it in the build configuration I thought, but maybe there's an issue.
I also get 22 warnings in the prj section.
I'm guessing this didn't work? Any advice to move forward?
Thank you
