I am building basic board on nRF5340(based on Raytac MDBT53 module) and after "Erase" operation in nRF Connect Programmer I cannot access chip anymore.
Board schematics are based on the basic example from MDBT53 documentation (see screenshot), except that the board does not have 32.7 kHz crystal, as for start I plan to use an internal oscillator.
When I power up the board for the first time, output voltage from VDD is 1.8V. When I connect nRF52840 DK board as programmer (version 3.0.0, with 5340 as debugger) to SWD with VDD nRF, GND, SWDIO, SCL - I can see the chip, read its content and use SWD normally. I could also use "nrfjprog" to set VREGHOUT to value "4" and got 3V output from VDD.
But after I build "blinky" example with "raytac_mdbt53_db_40_nrf5340_cpuapp" as board without additional/custom board configuration (as pinout, except for LF crystal is the same), drag resulting firmware to the programmer and click "Erase & write" - after Programmer finished the erasing & flashing - the chip is not accessible anymore.
It will output 1.8V from VDD and without changing SWD connection, the nRF52840 DK cannot identify and connect to the chip. Neither nRF Programmer, JLink Commander, nrfjprog nor OpenOCD cannot connect. At this point the board is effectively bricked, and I cannot connect to it through SWD to change UICR or upload another firmware. Seems more like IO problem rather than protections, but the chip becomes unresponsive immidiately after erase & write, without touching SWD connection.
Could this be because of missing LF crystal? And if so - would this solution fix the issue?
Also attached logs from "nrfjprog --recover --log".
[2024-Jun-23 11:20:40] [debug] --------------------------------------------------------------------------------
[2024-Jun-23 11:20:40] [debug] nrfjprog --recover --log
[2024-Jun-23 11:20:40] [debug] nrfjprog version 10.24.2 external
[2024-Jun-23 11:20:40] [ info] Load library at /opt/nrf-command-line-tools/lib/libnrfjprogdll.so.
[2024-Jun-23 11:20:40] [ info] Library loaded, loading member functions.
[2024-Jun-23 11:20:40] [ info] Member functions succesfully loaded.
[2024-Jun-23 11:20:40] [debug] [ Client] - open
[2024-Jun-23 11:20:40] [debug] [ Client] - start
[2024-Jun-23 11:20:40] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 32b50ec7-0c98-4355-b0bf-7960b23cb922.
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2024-Jun-23 11:20:40] [debug] [ JLink] - Logger sink registered in JLink logger
[2024-Jun-23 11:20:40] [debug] [ nRFXX] - open
[2024-Jun-23 11:20:40] [debug] [ nRFXX] - just_check_family
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - open_dll
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2024-Jun-23 11:20:40] [ info] [SeggerBackend] - Load library at /opt/SEGGER/JLink/libjlinkarm.so.7.
[2024-Jun-23 11:20:40] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2024-Jun-23 11:20:40] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - Set batch mode
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - dll_version
[2024-Jun-23 11:20:40] [trace] [ Client] - Command open executed for 12 milliseconds with result 0
[2024-Jun-23 11:20:40] [ info] [SeggerBackend] - Segger dll version 7.96.m loaded.
[2024-Jun-23 11:20:40] [trace] [ Worker] - Command open executed for 10 milliseconds with result 0
[2024-Jun-23 11:20:40] [debug] [ Client] - config
[2024-Jun-23 11:20:40] [trace] [ Client] - Command config executed for 5 milliseconds with result 0
[2024-Jun-23 11:20:40] [debug] [ Client] - enum_emu_snr
[2024-Jun-23 11:20:40] [debug] [ nRFXX] - config
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - enum_emu_snr
[2024-Jun-23 11:20:40] [trace] [ Worker] - Command config executed for 5 milliseconds with result 0
[2024-Jun-23 11:20:40] [debug] [ nRFXX] - enum_emu_con_info
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - is_connected_to_emu
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - enum_emu_con_info
[2024-Jun-23 11:20:40] [trace] [ Client] - Command enum_emu_con_info executed for 8 milliseconds with result 0
[2024-Jun-23 11:20:40] [debug] [ Client] - connect_to_emu_with_snr
[2024-Jun-23 11:20:40] [trace] [ Worker] - Command enum_emu_con_info executed for 8 milliseconds with result 0
[2024-Jun-23 11:20:40] [debug] [ nRFXX] - connect_to_emu_with_snr
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - ---just_get_num_emus
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - Segger logging enabled.
[2024-Jun-23 11:20:40] [trace] [ JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Apr 11 2024 17:44:26
[2024-Jun-23 11:20:40] [trace] [ JLink] - Hardware: V1.00
[2024-Jun-23 11:20:40] [trace] [ JLink] - S/N: 1050295380
[2024-Jun-23 11:20:40] [trace] [ JLink] - OEM: SEGGER
[2024-Jun-23 11:20:40] [trace] [ JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
[2024-Jun-23 11:20:40] [trace] [ JLink] - Bootloader: 2021 May 18
[2024-Jun-23 11:20:40] [trace] [ JLink] - USB speed mode: Full speed (12 MBit/s)
[2024-Jun-23 11:20:40] [trace] [ JLink] - TELNET listener socket opened on port 19021
[2024-Jun-23 11:20:40] [trace] [ JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2024-Jun-23 11:20:40] [trace] [ JLink] - WEBSRV Webserver running on local port 19080
[2024-Jun-23 11:20:40] [trace] [ JLink] - Looking for J-Link GUI Server exe at: /opt/SEGGER/JLink/JLinkGUIServerExe
[2024-Jun-23 11:20:40] [trace] [ JLink] - Forking J-Link GUI Server: /opt/SEGGER/JLink/JLinkGUIServerExe
[2024-Jun-23 11:20:40] [trace] [ JLink] - J-Link GUI Server info: "J-Link GUI server V7.96m "
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 48.000ms returns "O.K."
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_HasError()
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_Lock()
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.003ms returns 0x01
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.001ms returns 0x00
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.011ms returns 0
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.361ms returns 0x00
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_GetSpeedInfo()
[2024-Jun-23 11:20:40] [trace] [ JLink] - 128000000 Hz / n, n >= 64
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.007ms
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_SetSpeed(2000)
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.085ms
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_GetSpeed()
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.002ms returns 2000
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_GetSN()
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.002ms returns 1050295380
[2024-Jun-23 11:20:40] [debug] [ nRFXX] - read_device_family
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_IsOpen()
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.002ms returns 0x01
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - read_debug_port_idr
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - read_debug_port_register
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - coresight_configure
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_GetHWStatus(...)
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.084ms returns 0
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 101.735ms returns 0
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.641ms returns -1
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - ---just_abort_debug_action
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.631ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.535ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.645ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.643ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.695ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.644ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.636ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.619ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.628ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.534ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.647ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.629ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.603ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.638ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.594ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.577ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.544ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.591ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.545ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.583ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.662ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.678ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.686ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.610ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.679ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.633ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.635ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.596ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.634ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.563ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.677ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.604ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.606ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.521ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.637ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.600ms returns -1
[2024-Jun-23 11:20:40] [error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 220 milliseconds with result -102
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.543ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.195ms
[2024-Jun-23 11:20:40] [error] [ Worker] - An unknown error.
[2024-Jun-23 11:20:40] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 220 milliseconds with result -102
[2024-Jun-23 11:20:40] [debug] [ nRFXX] - close
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.010ms returns 0x01
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - close
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - disconnect_from_emu
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - is_connected_to_device
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_IsConnected()
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.007ms returns FALSE
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.690ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.714ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.713ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.697ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.613ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.618ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.640ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.627ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.622ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.527ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.498ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.491ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.585ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.517ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.567ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.569ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.542ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.595ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.655ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.555ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.554ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.566ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.557ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.503ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.593ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.665ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.598ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.587ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.576ms returns -1
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.711ms returns -1
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - Ignore exception An unknown error.
[2024-Jun-23 11:20:40] [trace] [ JLink] - - 0.090ms
[2024-Jun-23 11:20:40] [trace] [ JLink] - JLINK_Close()
[2024-Jun-23 11:20:40] [debug] [SeggerBackend] - Segger Backend closed.
[2024-Jun-23 11:20:40] [debug] [ nRFXX] - nRF family DLL closed
[2024-Jun-23 11:20:40] [trace] [ Client] - Command close executed for 64 milliseconds with result 0
[2024-Jun-23 11:20:40] [debug] [ Client] - terminate
[2024-Jun-23 11:20:40] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2024-Jun-23 11:20:40] [trace] [ Worker] - Command close executed for 64 milliseconds with result 0
[2024-Jun-23 11:20:40] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2024-Jun-23 11:20:40] [trace] [ Worker] - Executed 6 commands for 307 milliseconds
[2024-Jun-23 11:20:40] [debug] [ Client] - Worker process exited with code: 0
