Connection using old pairing information saved
I am running an experiment to use a static keys for pairing information without breaking the existing flow of pairing/bonding.
What I am doing is I am storing the pairing info of my central device and storing it into a structure and then erasing the flash to remove those information, and after reset I am retrieving those bonding information and connecting again using the same central devices but I am getting "Peer removed bonding info" response on my phone.
void store_ltk_in_zephyr(void)
    int id, err;
    struct bt_keys pairing_info = {
    .addr = {
        .type = BT_ADDR_LE_PUBLIC,
        .a.val = {0x43,0x82,0x5E,0xC7,0xE8,0xF4,0xFD}
    .irk = {0x8A, 0x27, 0x1E, 0xA7, 0x92, 0x2A, 0xF0, 0x15, 0x41, 0x69, 0x48, 0xDD, 0xC0, 0x7E, 0xDD, 0xF7},
    .ltk = {
        .val = {0xc0, 0xe6, 0x9a, 0x0a, 0xf7, 0x4b, 0xdc, 0xb7, 0x7d, 0x23, 0xf4, 0xb4, 0x89, 0x8d, 0x96, 0x02},
        .ediv = {0x00,0x00},
        .rand = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
    // Store the keys using the settings API
    err = bt_keys_store(&pairing_info);
    if (err) {
        printk("Failed to store keys (err %d)\n", err);
    } else {
        printk("Keys stored successfully\n");
In main, I am calling like this to load the info onto the flash-
  settings_subsys_init();
  //smp_bt_register();
	bt_conn_auth_cb_register(&auth_cb_display);
  bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
    k_sleep(K_MSEC(100));
		err = bt_enable(NULL);                                      //Trying one more time after this system reset
    if(err) NVIC_SystemReset();
  store_ltk_in_zephyr();
  if (IS_ENABLED(CONFIG_SETTINGS)) {
    settings_load();
And on connect I am using like this-
  bt_conn_set_security(conn, BT_SECURITY_L1|BT_SECURITY_FORCE_PAIR);
Do let me know, how can I connect with the same bonding info which I have made a copy of from the same bonding structure.
  • iOS does not expose any APIs to the app to force service discovery like Android. Therefore, the only way to manually clear the attribute cache is to toggle Bluetooth enable from settings, or reboot the phone.
    Here is an updated version of my code which attempts to send the SC indication on the first connection. I verified that it worked with my iPhone.
     * Copyright (c) 2018 Nordic Semiconductor ASA
    /** @file
     *  @brief Nordic UART Bridge Service (NUS) sample
    #include "uart_async_adapter.h"
    #include <zephyr/types.h>
    #include <zephyr/kernel.h>
    #include <zephyr/drivers/uart.h>
    #include <zephyr/usb/usb_device.h>
    #include <zephyr/device.h>
    #include <soc.h>
    #include <zephyr/bluetooth/uuid.h>
    #include <zephyr/bluetooth/gatt.h>
    #include <zephyr/bluetooth/hci.h>
    #include <zephyr/bluetooth/addr.h>
    #include <zephyr/sys/byteorder.h>
    /* BLE internal headers, use with caution. */
    #include <host/keys.h>
    #include <host/smp.h>
    #include <bluetooth/services/nus.h>
    #include <dk_buttons_and_leds.h>
    #include <zephyr/settings/settings.h>
    #include <stdio.h>
    #define LOG_MODULE_NAME peripheral_uart
    LOG_MODULE_REGISTER(LOG_MODULE_NAME);
    #define STACKSIZE CONFIG_BT_NUS_THREAD_STACK_SIZE
    #define PRIORITY 7
    #define DEVICE_NAME CONFIG_BT_DEVICE_NAME
    #define DEVICE_NAME_LEN	(sizeof(DEVICE_NAME) - 1)
    #define RUN_STATUS_LED DK_LED1
    #define RUN_LED_BLINK_INTERVAL 1000
    #define CON_STATUS_LED DK_LED2
    #define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
    #define KEY_PASSKEY_REJECT DK_BTN2_MSK
    #define UART_BUF_SIZE CONFIG_BT_NUS_UART_BUFFER_SIZE
    #define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
    #define UART_WAIT_FOR_RX CONFIG_BT_NUS_UART_RX_WAIT_TIME
    static K_SEM_DEFINE(ble_init_ok, 0, 1);
    static bool pre_shared_bond_applied;
    static void service_changed_work_handle(struct k_work *item);
    static K_WORK_DEFINE(sc_work, service_changed_work_handle);
    static struct bt_conn *current_conn;
    static struct bt_conn *auth_conn;
    static const struct device *uart = DEVICE_DT_GET(DT_CHOSEN(nordic_nus_uart));
    static struct k_work_delayable uart_work;
    struct uart_data_t {
    	void *fifo_reserved;
    	uint8_t data[UART_BUF_SIZE];
    	uint16_t len;
    static K_FIFO_DEFINE(fifo_uart_tx_data);
    static K_FIFO_DEFINE(fifo_uart_rx_data);
    static const struct bt_data ad[] = {
    	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
    	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
    static const struct bt_data sd[] = {
    	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
    #if CONFIG_BT_NUS_UART_ASYNC_ADAPTER
    UART_ASYNC_ADAPTER_INST_DEFINE(async_adapter);
    #else
    static const struct device *const async_adapter;
    static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
    	ARG_UNUSED(dev);
    	static size_t aborted_len;
    	struct uart_data_t *buf;
    	static uint8_t *aborted_buf;
    	static bool disable_req;
    	switch (evt->type) {
    	case UART_TX_DONE:
    		LOG_DBG("UART_TX_DONE");
    		if ((evt->data.tx.len == 0) ||
    		    (!evt->data.tx.buf)) {
    			return;
    		if (aborted_buf) {
    			buf = CONTAINER_OF(aborted_buf, struct uart_data_t,
    					   data[0]);
    			aborted_buf = NULL;
    			aborted_len = 0;
    		} else {
    			buf = CONTAINER_OF(evt->data.tx.buf, struct uart_data_t,
    					   data[0]);
    		k_free(buf);
    		buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
    		if (!buf) {
    			return;
    		if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
    			LOG_WRN("Failed to send data over UART");
    	case UART_RX_RDY:
    		LOG_DBG("UART_RX_RDY");
    		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data[0]);
    		buf->len += evt->data.rx.len;
    		if (disable_req) {
    			return;
    		if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
    		    (evt->data.rx.buf[buf->len - 1] == '\r')) {
    			disable_req = true;
    			uart_rx_disable(uart);
    	case UART_RX_DISABLED:
    		LOG_DBG("UART_RX_DISABLED");
    		disable_req = false;
    		buf = k_malloc(sizeof(*buf));
    		if (buf) {
    			buf->len = 0;
    		} else {
    			LOG_WRN("Not able to allocate UART receive buffer");
    			k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
    			return;
    		uart_rx_enable(uart, buf->data, sizeof(buf->data),
    			       UART_WAIT_FOR_RX);
    	case UART_RX_BUF_REQUEST:
    		LOG_DBG("UART_RX_BUF_REQUEST");
    		if (buf) {
    			buf->len = 0;
    			uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
    		} else {
    	case UART_RX_BUF_RELEASED:
    		LOG_DBG("UART_RX_BUF_RELEASED");
    		buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
    				   data[0]);
    		if (buf->len > 0) {
    			k_fifo_put(&fifo_uart_rx_data, buf);
    		} else {
    			k_free(buf);
    	case UART_TX_ABORTED:
    		LOG_DBG("UART_TX_ABORTED");
    		if (!aborted_buf) {
    			aborted_buf = (uint8_t *)evt->data.tx.buf;
    		aborted_len += evt->data.tx.len;
    		buf = CONTAINER_OF((void *)aborted_buf, struct uart_data_t,
    				   data);
    		uart_tx(uart, &buf->data[aborted_len],
    			buf->len - aborted_len, SYS_FOREVER_MS);
    static void uart_work_handler(struct k_work *item)
    	if (buf) {
    		buf->len = 0;
    	} else {
    		return;
    	uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_WAIT_FOR_RX);
    static bool uart_test_async_api(const struct device *dev)
    	const struct uart_driver_api *api =
    			(const struct uart_driver_api *)dev->api;
    	return (api->callback_set != NULL);
    static int uart_init(void)
    	int err;
    	int pos;
    	struct uart_data_t *rx;
    	struct uart_data_t *tx;
    	if (!device_is_ready(uart)) {
    		return -ENODEV;
    	if (IS_ENABLED(CONFIG_USB_DEVICE_STACK)) {
    		err = usb_enable(NULL);
    		if (err && (err != -EALREADY)) {
    			LOG_ERR("Failed to enable USB");
    			return err;
    	rx = k_malloc(sizeof(*rx));
    	if (rx) {
    		rx->len = 0;
    	} else {
    		return -ENOMEM;
    	k_work_init_delayable(&uart_work, uart_work_handler);
    	if (IS_ENABLED(CONFIG_BT_NUS_UART_ASYNC_ADAPTER) && !uart_test_async_api(uart)) {
    		/* Implement API adapter */
    		uart_async_adapter_init(async_adapter, uart);
    		uart = async_adapter;
    	err = uart_callback_set(uart, uart_cb, NULL);
    	if (err) {
    		k_free(rx);
    		LOG_ERR("Cannot initialize UART callback");
    		return err;
    	if (IS_ENABLED(CONFIG_UART_LINE_CTRL)) {
    		LOG_INF("Wait for DTR");
    		while (true) {
    			uint32_t dtr = 0;
    			uart_line_ctrl_get(uart, UART_LINE_CTRL_DTR, &dtr);
    			if (dtr) {
    			/* Give CPU resources to low priority threads. */
    		LOG_INF("DTR set");
    		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DCD, 1);
    		if (err) {
    			LOG_WRN("Failed to set DCD, ret code %d", err);
    		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DSR, 1);
    		if (err) {
    			LOG_WRN("Failed to set DSR, ret code %d", err);
    	tx = k_malloc(sizeof(*tx));
    	if (tx) {
    		pos = snprintf(tx->data, sizeof(tx->data),
    			       "Starting Nordic UART service example\r\n");
    		if ((pos < 0) || (pos >= sizeof(tx->data))) {
    			k_free(rx);
    			k_free(tx);
    			LOG_ERR("snprintf returned %d", pos);
    			return -ENOMEM;
    		tx->len = pos;
    	} else {
    		k_free(rx);
    		return -ENOMEM;
    	err = uart_tx(uart, tx->data, tx->len, SYS_FOREVER_MS);
    	if (err) {
    		k_free(rx);
    		k_free(tx);
    		LOG_ERR("Cannot display welcome message (err: %d)", err);
    		return err;
    	err = uart_rx_enable(uart, rx->data, sizeof(rx->data), UART_WAIT_FOR_RX);
    	if (err) {
    		LOG_ERR("Cannot enable uart reception (err: %d)", err);
    		/* Free the rx buffer only because the tx buffer will be handled in the callback */
    		k_free(rx);
    	return err;
    static void connected(struct bt_conn *conn, uint8_t err)
    	if (err) {
    		LOG_ERR("Connection failed (err %u)", err);
    		return;
    	LOG_INF("Connected %s", addr);
    	current_conn = bt_conn_ref(conn);
    	dk_set_led_on(CON_STATUS_LED);
    	LOG_INF("Disconnected: %s (reason %u)", addr, reason);
    	if (auth_conn) {
    		bt_conn_unref(auth_conn);
    		auth_conn = NULL;
    	if (current_conn) {
    		bt_conn_unref(current_conn);
    		current_conn = NULL;
    		dk_set_led_off(CON_STATUS_LED);
    	/* Clear flag for subsequent connections */
    	pre_shared_bond_applied = false;
    static void sc_indicate_rsp(struct bt_conn *conn,
                        struct bt_gatt_indicate_params *params,
                        uint8_t err)
        LOG_INF("sc_indicate_rsp received. (err %d)", err);
    	int err;
    	static struct bt_gatt_indicate_params indicate_params;
    	/* Harcode the attribute handle for SC characteristic from nRF5 SDK application (12 in this case).
    	 * CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION must be disabled in project configuration
    	 * to allow the indication to be sent, as the Zephyr host has know way
    	 * of knowing if the client was subscribed to this characteristic.
    	 * IMPORTANT: consider if disabling CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION
    	 * has security implications for your application.
    	static struct bt_gatt_attr attr = {.handle = 12};
    	static uint16_t sc_range[2];
    	sc_range[0] = sys_cpu_to_le16(0x0001);
    	sc_range[1] = 0xffff;
    	indicate_params.attr = &attr;
    	indicate_params.func = sc_indicate_rsp;
    	indicate_params.data = &sc_range[0];
    	indicate_params.len = sizeof(sc_range);
    	err = bt_gatt_indicate(current_conn, &indicate_params);
    	if (err) {
    		LOG_ERR("Failed to send SC indication. (err %d)", err);
    #ifdef CONFIG_BT_NUS_SECURITY_ENABLED
    static void security_changed(struct bt_conn *conn, bt_security_t level,
    			     enum bt_security_err err)
    	if (!err) {
    		LOG_INF("Security changed: %s level %u", addr, level);
    		if (pre_shared_bond_applied) {
    			/* Inform GATT client that the attribute table has changed by sending a
    			 * SC changed indication.
    			k_work_submit(&sc_work);
    	} else {
    		LOG_WRN("Security failed: %s level %u err %d", addr,
    			level, err);
    BT_CONN_CB_DEFINE(conn_callbacks) = {
    	.connected    = connected,
    	.disconnected = disconnected,
    	.security_changed = security_changed,
    #if defined(CONFIG_BT_NUS_SECURITY_ENABLED)
    static void auth_cancel(struct bt_conn *conn)
    	LOG_INF("Pairing cancelled: %s", addr);
    static void pairing_complete(struct bt_conn *conn, bool bonded)
    	LOG_INF("Pairing completed: %s, bonded: %d", addr, bonded);
    static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
    	LOG_INF("Pairing failed conn: %s, reason %d", addr, reason);
    static struct bt_conn_auth_cb conn_auth_callbacks = {
    	//.passkey_display = auth_passkey_display,
    	//.passkey_confirm = auth_passkey_confirm,
    	.cancel = auth_cancel,
    static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
    	.pairing_complete = pairing_complete,
    	.pairing_failed = pairing_failed
    #else
    static struct bt_conn_auth_cb conn_auth_callbacks;
    static struct bt_conn_auth_info_cb conn_auth_info_callbacks;
    static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data,
    			  uint16_t len)
    	int err;
    	char addr[BT_ADDR_LE_STR_LEN] = {0};
    	bt_addr_le_to_str(bt_conn_get_dst(conn), addr, ARRAY_SIZE(addr));
    	LOG_INF("Received data from: %s", addr);
    	for (uint16_t pos = 0; pos != len;) {
    		struct uart_data_t *tx = k_malloc(sizeof(*tx));
    		if (!tx) {
    			LOG_WRN("Not able to allocate UART send data buffer");
    			return;
    		/* Keep the last byte of TX buffer for potential LF char. */
    		size_t tx_data_size = sizeof(tx->data) - 1;
    		if ((len - pos) > tx_data_size) {
    			tx->len = tx_data_size;
    		} else {
    			tx->len = (len - pos);
    		memcpy(tx->data, &data[pos], tx->len);
    		pos += tx->len;
    		/* Append the LF character when the CR character triggered
    		 * transmission from the peer.
    		if ((pos == len) && (data[len - 1] == '\r')) {
    			tx->data[tx->len] = '\n';
    			tx->len++;
    		if (err) {
    			k_fifo_put(&fifo_uart_tx_data, tx);
    static struct bt_nus_cb nus_cb = {
    	.received = bt_receive_cb,
    void error(void)
    	dk_set_leds_state(DK_ALL_LEDS_MSK, DK_NO_LEDS_MSK);
    	while (true) {
    		/* Spin for ever */
    		k_sleep(K_MSEC(1000));
    static void num_comp_reply(bool accept)
    	if (accept) {
    		bt_conn_auth_passkey_confirm(auth_conn);
    		LOG_INF("Numeric Match, conn %p", (void *)auth_conn);
    	} else {
    		bt_conn_auth_cancel(auth_conn);
    		LOG_INF("Numeric Reject, conn %p", (void *)auth_conn);
    	auth_conn = NULL;
    void button_changed(uint32_t button_state, uint32_t has_changed)
    	uint32_t buttons = button_state & has_changed;
    	if (auth_conn) {
    		if (buttons & KEY_PASSKEY_ACCEPT) {
    			num_comp_reply(true);
    		if (buttons & KEY_PASSKEY_REJECT) {
    			num_comp_reply(false);
    #endif /* CONFIG_BT_NUS_SECURITY_ENABLED */
    static void configure_gpio(void)
    	int err;
    	err = dk_buttons_init(button_changed);
    	if (err) {
    		LOG_ERR("Cannot init buttons (err: %d)", err);
    	err = dk_leds_init();
    	if (err) {
    		LOG_ERR("Cannot init LEDs (err: %d)", err);
    static void bond_cb(const struct bt_bond_info *info, void *user_data)
    	ARG_UNUSED(info);
    	*(int *) user_data += 1;
    	LOG_INF("Existing bond found");
    	return;
    static void pre_shared_bond_set(void)
    	int err;
    	int bond_num = 0;
    	struct bt_keys *pairing_info;
    	// true if pm_peer_data_bonding.own_ltk.enc_info.ltk.lesc == 0
    	bool legacy_pairing = true;
    	bt_foreach_bond(BT_ID_DEFAULT, bond_cb, &bond_num);
    	if (bond_num) {
    		return;
    	//pm_peer_data_bonding.peer_ble_id.id_addr_info
    	bt_addr_le_t addr = {
    	    .a.val = {0x23,...}
    	//pm_peer_data_bonding.own_ltk.enc_info.ltk
    	struct bt_ltk ltk = {
    	    .val = {0x91, 0x1a, 0x96, 0x6d, 0xe8, 0x69, 0x0e, 0x78, 0x56, 0x93, 0x86,
    	            0x0c, 0x9b, 0x43, 0x49, 0xee},
    	    .ediv = {0xb8,0x78},
    	    .rand = {0x36, 0x7b, 0xad, 0x8e, 0x31, 0xb4, 0x2c, 0xab}
    	struct bt_irk irk = {
    		.val = {0xd6,...},
    		.rpa.val = {0}
    	pairing_info = bt_keys_get_addr(0, &addr);
    	if (pairing_info == NULL) {
    		LOG_ERR("Failed to get keyslot");
    		return;
    	if (legacy_pairing) {
    		memcpy(&pairing_info->periph_ltk, &ltk, sizeof(pairing_info->periph_ltk));
    	else {
    		memcpy(&pairing_info->ltk, &ltk, sizeof(pairing_info->ltk));
    	memcpy(&pairing_info->irk, &irk, sizeof(pairing_info->irk));
    		pairing_info->flags = 0;
    		pairing_info->enc_size = BT_SMP_MAX_ENC_KEY_SIZE;
    		pairing_info->keys = BT_KEYS_IRK | BT_KEYS_PERIPH_LTK;
    	else {
    		pairing_info->flags = BT_KEYS_SC;
    		pairing_info->keys = BT_KEYS_IRK | BT_KEYS_LTK_P256;
    	err = bt_keys_store(pairing_info);
        if (err) {
            LOG_ERR("Failed to store keys (err %d)\n", err);
        } else {
            LOG_INF("Keys stored successfully\n");
    		pre_shared_bond_applied = true;
    	int blink_status = 0;
    	int err = 0;
    	configure_gpio();
    	err = uart_init();
    	if (err) {
    		error();
    	if (IS_ENABLED(CONFIG_BT_NUS_SECURITY_ENABLED)) {
    		err = bt_conn_auth_cb_register(&conn_auth_callbacks);
    		if (err) {
    			printk("Failed to register authorization callbacks.\n");
    			return 0;
    		err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
    		if (err) {
    			printk("Failed to register authorization info callbacks.\n");
    			return 0;
    	if (err) {
    		error();
    	LOG_INF("Bluetooth initialized");
    	k_sem_give(&ble_init_ok);
    		settings_load();
    	pre_shared_bond_set();
    	err = bt_nus_init(&nus_cb);
    	if (err) {
    		LOG_ERR("Failed to initialize UART service (err: %d)", err);
    		return 0;
    	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd,
    			      ARRAY_SIZE(sd));
    	if (err) {
    		LOG_ERR("Advertising failed to start (err %d)", err);
    		return 0;
    	for (;;) {
    		dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
    		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
    void ble_write_thread(void)
    	/* Don't go any further until BLE is initialized */
    	k_sem_take(&ble_init_ok, K_FOREVER);
    	for (;;) {
    		/* Wait indefinitely for data to be sent over bluetooth */
    		struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data,
    						     K_FOREVER);
    		if (bt_nus_send(NULL, buf->data, buf->len)) {
    			LOG_WRN("Failed to send data over BLE connection");
    		k_free(buf);
    K_THREAD_DEFINE(ble_write_thread_id, STACKSIZE, ble_write_thread, NULL, NULL,
    		NULL, PRIORITY, 0, 0);
  •  I am getting error -22 from bt_gatt_indicate ,Invalid argument. On Android phones, discover services is doing the trick but on iOS phone I have to do a phone restart to get the GATT cache cleared.
    If toggling bluetooth button is also a possibility then that will be a better solution for this issue. Please do suggest on this.
    BTW I have also enabled CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION as suggested.
    00> [00:00:12.531,250] <wrn> bt_gatt: Device is not subscribed to characteristic
    00> Failed to send SC indication. (err -22)
  • Please verify that CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION got selected by checking the generated config in build/zephyr/.config. The error suggests that it is not.
    This requires the user to go to settings->bluetooth and turn bluetooth off and on.
    Yes  its selected.
    Tried this but didn`t worked
  • Sorry, I meant to ask if it got disabled. As mentioned in my code comment, CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION must be disabled to send the indication without the subscription being enabled.
    It's important that you turn bluetooth off and on from the 'Settings->Bluetooth' and not the Control Center.
