Connection using old pairing information saved
I am running an experiment to use a static keys for pairing information without breaking the existing flow of pairing/bonding.
What I am doing is I am storing the pairing info of my central device and storing it into a structure and then erasing the flash to remove those information, and after reset I am retrieving those bonding information and connecting again using the same central devices but I am getting "Peer removed bonding info" response on my phone.
void store_ltk_in_zephyr(void)
    int id, err;
    struct bt_keys pairing_info = {
    .addr = {
        .type = BT_ADDR_LE_PUBLIC,
        .a.val = {0x43,0x82,0x5E,0xC7,0xE8,0xF4,0xFD}
    .irk = {0x8A, 0x27, 0x1E, 0xA7, 0x92, 0x2A, 0xF0, 0x15, 0x41, 0x69, 0x48, 0xDD, 0xC0, 0x7E, 0xDD, 0xF7},
    .ltk = {
        .val = {0xc0, 0xe6, 0x9a, 0x0a, 0xf7, 0x4b, 0xdc, 0xb7, 0x7d, 0x23, 0xf4, 0xb4, 0x89, 0x8d, 0x96, 0x02},
        .ediv = {0x00,0x00},
        .rand = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
    // Store the keys using the settings API
    err = bt_keys_store(&pairing_info);
    if (err) {
        printk("Failed to store keys (err %d)\n", err);
    } else {
        printk("Keys stored successfully\n");
In main, I am calling like this to load the info onto the flash-
  settings_subsys_init();
  //smp_bt_register();
	bt_conn_auth_cb_register(&auth_cb_display);
  bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
    k_sleep(K_MSEC(100));
		err = bt_enable(NULL);                                      //Trying one more time after this system reset
    if(err) NVIC_SystemReset();
  store_ltk_in_zephyr();
  if (IS_ENABLED(CONFIG_SETTINGS)) {
    settings_load();
And on connect I am using like this-
  bt_conn_set_security(conn, BT_SECURITY_L1|BT_SECURITY_FORCE_PAIR);
Do let me know, how can I connect with the same bonding info which I have made a copy of from the same bonding structure.
  •  On android, on every connection I have to do Refresh services to do the data transfer.
    Why is that?
  • Sorry, I meant to ask if it got disabled. As mentioned in my code comment, CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION must be disabled to send the indication without the subscription being enabled.
     With this settings disabled, I am seeing the pairing info getting deleted from the flash that I have stored on the nRF5SDK version.
    Pairing info I am storing in oxf5100 memory address and have saved space based on this on Zephyr version too.
    Before disabling this settings, pairing info was correctly getting copied to the Zephyr version but not now.
    Why is that?
    This also stands still, I have tested with 3-4 phones now.
  • There is no relation between the CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION setting and how bonds are managed. If you grep the SDK for "CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION," you can see that all it does is skip the "is subscribed" check when sending indications/notifications.
    Why is that?
    I have never seen anything like this before. The attribute cache should be updated when you perform a new discovery. Are you testing this with the nRF Connect app? And do you see old services appear again when you re-connect?
  • Are you testing this with the nRF Connect app? And do you see old services appear again when you re-connect?
    Yes  seeing the old services appear on reconnect.
    For this I did some test and the merged DFU zip could be the issue, because if I flash the Zephyr application then it works fine but after doing DFU I am seeing the flash memory is getting erased.
    The first read is when the bonded information is stored in nRF5SDK version and the one after reset is the one read when the migration completes and Zephyr application starts to run.
  • Yes  seeing the old services appear on reconnect.
    Can you post a screencast  from the app showing this?
    Can you show how you reserved the bond data in your zephyr app?
