Connection using old pairing information saved
I am running an experiment to use a static keys for pairing information without breaking the existing flow of pairing/bonding.
What I am doing is I am storing the pairing info of my central device and storing it into a structure and then erasing the flash to remove those information, and after reset I am retrieving those bonding information and connecting again using the same central devices but I am getting "Peer removed bonding info" response on my phone.
void store_ltk_in_zephyr(void)
    int id, err;
    struct bt_keys pairing_info = {
    .addr = {
        .type = BT_ADDR_LE_PUBLIC,
        .a.val = {0x43,0x82,0x5E,0xC7,0xE8,0xF4,0xFD}
    .irk = {0x8A, 0x27, 0x1E, 0xA7, 0x92, 0x2A, 0xF0, 0x15, 0x41, 0x69, 0x48, 0xDD, 0xC0, 0x7E, 0xDD, 0xF7},
    .ltk = {
        .val = {0xc0, 0xe6, 0x9a, 0x0a, 0xf7, 0x4b, 0xdc, 0xb7, 0x7d, 0x23, 0xf4, 0xb4, 0x89, 0x8d, 0x96, 0x02},
        .ediv = {0x00,0x00},
        .rand = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
    // Store the keys using the settings API
    err = bt_keys_store(&pairing_info);
    if (err) {
        printk("Failed to store keys (err %d)\n", err);
    } else {
        printk("Keys stored successfully\n");
In main, I am calling like this to load the info onto the flash-
  settings_subsys_init();
  //smp_bt_register();
	bt_conn_auth_cb_register(&auth_cb_display);
  bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
    k_sleep(K_MSEC(100));
		err = bt_enable(NULL);                                      //Trying one more time after this system reset
    if(err) NVIC_SystemReset();
  store_ltk_in_zephyr();
  if (IS_ENABLED(CONFIG_SETTINGS)) {
    settings_load();
And on connect I am using like this-
  bt_conn_set_security(conn, BT_SECURITY_L1|BT_SECURITY_FORCE_PAIR);
Do let me know, how can I connect with the same bonding info which I have made a copy of from the same bonding structure.
  • My Flash partitions are like this-
    &flash0 {
    	partitions {
            #address-cells = <1>;
            #size-cells = <1>;
            boot_partition: partition@f8000 {
                label = "mcuboot";
                reg = <0x000f8000 0x006000>;
            slot0_partition: partition@1200 {
                label = "image-0";
                reg = <0x00001200 0x0007ae00>;
            slot1_partition: partition@7c000 {
                label = "image-1";
                reg = <0x0007c000 0x00078000>;
            scratch_partition: partition@f7000 {
                label = "image-scratch";
                reg = <0x000f7000 0x00001000>;
             * The flash starting at 0x000f8000 and ending at
             * 0x000fffff is reserved for use by the application.
             * Storage partition will be used by FCB/LittleFS/NVS
             * if enabled.
            storage_partition: partition@f4000 {
                label = "storage";
                reg = <0x000f4000 0x00003000>;
    app:
      address: 0x1200
      end_address: 0x7B000
      region: flash_primary
    mcuboot:
      address: 0xF8000
      end_address: 0xFE000
      placement:
        after:
        - mcuboot_secondary
    mcuboot_pad:
      address: 0x1000
      end_address: 0x1200
      placement:
        before:
        - mcuboot_primary_app
    mcuboot_primary:
      address: 0x1000
      end_address: 0x7C000
      orig_span: &id001
      - app
      - mcuboot_pad
      sharers: 0x1
      span: *id001
    mcuboot_primary_app:
      address: 0x1200
      orig_span: &id002
      - app
      span: *id002
    mcuboot_secondary:
      address: 0x7C000
      end_address: 0xF8000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x1000
      share_size:
      - mcuboot_primary
    device_info:
      address: 0xf4000
      end_address: 0xf5000
      placement:
        align:
          start: 0x1000
        before:
        - pairing_info
    pairing_info:
      address: 0xf5000
      end_address: 0xf6000
      placement:
        align:
          start: 0x1000
        before:
        - nvs_storage
    nvs_storage:
      address: 0xf6000
      end_address: 0xf7000
      placement:
        align:
          start: 0x1000
        before:
        - unused_page
    unused_page:
      address: 0xf7000
      placement:
        after:
        - mcuboot_secondary
    nrf5_mbr:
      address: 0x0
      end_address: 0x1000
      placement:
        after:
        - start
    settings_storage:
      address: 0xfe000
      end_address: 0x100000
      placement:
        align:
          start: 0x1000
        before:
        - end
    sram_primary:
      address: 0x20000000
      end_address: 0x20040000
      region: sram_primary
  • Interestingly its happening for all the critical device information I am storing in flash on nRF5SDK and copying in Zephyr version is getting wiped out.
    These are the relevant areas that I am using-
    device_info:
      address: 0xf4000
      placement:
        align:
          start: 0x1000
        before:
        - pairing_info
    pairing_info:
      address: 0xf5000
      placement:
        align:
          start: 0x1000
        before:
        - nvs_storage
    nvs_storage:
      address: 0xf6000
      placement:
        align:
          start: 0x1000
        before:
        - unused_page
  • It may be overwritten by the nRF5 SDK bootloader during DFU if the data is outside of the reserved application data region.
    https://docs.nordicsemi.com/bundle/sdk_nrf5_v17.1.0/page/lib_bootloader.html
  • Yes  , just verified when sending the device into bootloader mode is causing the wipe out of the memory region.
    Anyway to save it?
  • Anyway to save it?
    I have increased the NRF_DFU_APP_DATA_AREA_SIZE to 20480 (0x5000) so that the application data region could be till 0xf3000 memory region, but this also hasnt helped.
    In my nRF5SDK application, I have 5 FDS pages defined.
