I have a custom board file which is based on nrf9160, I want to use it using the west build command and later flash it. I tried the steps under this tutorial: Nordic academy and used DBoardname in the build command but it is still failing. The error is as follows :
PS C:\Users\FutureLab\zephyrproject\zephyr> west build -b ciot_connectivity_boardns -- -DBOARD_ROOT="C:\Users\FutureLab\zephyrproject\zephyr\cellular-edge-sdk-master\boards\arm" cellular-edge-sdk-master/samples/getting_started
Loading Zephyr default modules (Zephyr base (cached)).
-- Application: C:/Users/FutureLab/zephyrproject/zephyr/cellular-edge-sdk-master/samples/getting_started
-- CMake version: 3.28.0-rc1
-- Cache files will be written to: C:/Users/FutureLab/zephyrproject/zephyr/.cache
-- Zephyr version: 3.6.99 (C:/Users/FutureLab/zephyrproject/zephyr)
CMake Warning at C:/Users/FutureLab/zephyrproject/zephyr/cmake/modules/boards.cmake:136 (message):
BOARD_ROOT element without a 'boards' subdirectory:
Hints:
- if your board directory is '/foo/bar/boards/<ARCH>/my_board' then add '/foo/bar' to BOARD_ROOT, not the entire board directory
- if in doubt, use absolute paths
C:/Users/FutureLab/zephyrproject/zephyr/cmake/modules/zephyr_default.cmake:132 (include)
C:/Users/FutureLab/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
C:/Users/FutureLab/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:97 (include_boilerplate)
CMakeLists.txt:11 (find_package)
No board named 'ciot_connectivity_boardns' found. is there something I am missing?
what else do I need do?
I already have the board files so I dont think there is any need to again use the custom baord option in VS code to create the board files again.
