Hi. I'm on a relatively old ryzen-5 windows 11 PC and I get 30 FPS when recording power with Power Profiler version 4.0.0 and 2 FPS when recording with newer versions (4.1.<0,1,2>)
Don't really know what to do except keep the old version.
Hi Jason and Mathew,
Could you please try the following and let me know.?
Try recording for 5 minutes using version 4.0.0 and version 4.1.2
Do must make sure that you rely on some external clock to count the 5 minutes and not on the timestamp on the ppk app.
Ideally, we expect to see that after 5 min the version 4.0.0 will have less time recorded and version 4.1.2 will have the correct time.
Swathy
For me running 5 minutes with 1000 sps and using my phone stopwatch to time stuff:
version 4.1.2
2-4 fps, always
5 minutes realtime gives 2:28.1 minutes ppk time
version 4.0.0
28-32fps, always
5 minutes realtime gives 2:28.2 minutes ppk time
Interesting issue.
Changing usb ports (annoying on stationary computer), but worth a try.
version 4.1.2
26-31 fps
5 minutes realtime gives 5:00.1 minutes ppk time (works well)
version 4.0.0
28-32fps
5 minutes realtime gives 4:59.8 minutes ppk time (works well)
So my issue is with a specific usb port. But I regularly use this port for data transfer as well so I believe it 'works'.
It's basically the same
with 4.0.0
After 2 minutes the elapsed time was 42s on the UI
After 5 minutes the elapsed time was 1:43s on the UI
But the chart refreshed at 31fps.
On the latest version I see almost the same behaviour, but with only 3fps
After 2 minutes the elapsed time was 38s on the UI
After 5 minutes the elapsed time was 1:41s on the UI
I'm plugged directly into my PC. I'll try another USB
I changed ports 2x but its the same .I also unplugged my jlink etc
I then unplugged my Bluetooth audio dongle and swapped my mouse with the PPK2 and now it's 30fps
