NB-IoT RRC Connection Re-establishment on nRF9161
NB-IoT RRC Connection Re-establishment is supposedly available on nRF9161/51. Is there a related AT-command to enable / disable?
François.
  • Hello François.
    I'm not able to find any information on this in the current nRF91x1 Cellular AT Commands document. I will need to ask internally. I hope to have an answer by end of tomorrow.
    Øyvind
  • Greetings,
    Would it be possible to get an update on the level of support of this feature on nRF91x1 modules ? Any specific minimum firmware required? Any AT-command to enable/disable?
    Is it by chance now also supported on nRF9160 ?
    3GPP Rel-14 introduced NB-IoT RRC connection re-establishment in Control Plane CIoT EPS optimization mode. It is a Connected Mode Mobility (CMM) enhancement : in case of radio link failure, it allows UE to move from one cell to another without having to renegociate a new connection, for improved service continuity. It works as follows : if a source eNodeB fails to send downlink NAS data to a UE, it returns the data to the MME. The MME then instructs a target eNodeB to send the data to the UE.
    The eNB indicates to the UE that RRC connection Re-establishment is supported via the SIB2-NB channel.
    François.
  • Hello François,
    My sincerest apologies, this question did get an answer but fell of the radar with the other tickets/questions. Here is the answer I got back in June 2024
    RRC connection re-establishment is supported in nRF9161/51 in NB-IoT mode. There is no AT-command to enable/disable it.
    Reduced Mobility feature (3GPP Relaxed Monitoring TS36.304 and Nordic-proprietary feature) based on %REDMOB command
    In nRF9161/51 %REDMOB command parameters are these:
    0 - enable 3GPP Rel14 Relaxed Monitoring feature
    1 - enable Nordic proprietary Relaxed Monitoring feature
    2 - disable 3GPP Rel14 and Nordic proprietary Relaxed Monitoring features and enable full measurements to achieve best possible mobility.
    Relaxed Monitoring feature applies to both NB-IoT and LTE-M systems.
    LTE-M Data Inactivity Timer
    In nRF9161/51 Data Inactivity Timer is supported by default. There is no AT-command to enable/disable it.
    NB-IoT Dual HARQ and Max TBS size enhancement
    In nRF9161/51 NB-IoT Dual HARQ and Max TBS size enhancement are supported by default. There are no AT-commands to enable/disable those.
    Let me know if you need more information on this topic.
    Øyvind
  • Hello Øyvind,
    No worries, thanks for the detailed answer and the recap !
    One final query: is RRC Connection Re-Estab also supported on nrF9160 ? If that's the case, any specific AT command needed, and with which minimal FW version?
    François
    Our team responds with the following answer:
    RRC Connection Re-establishment for NB-IOT is supported from MFW-2.0.0 onwards - no specific AT-command needed. For
    HW-wise, MFW-2.0.0 is supported only in nrf91x1 hardware → So, not supported in nrf9160 at all.
    Øyvind
