I have successfully implemented an interrupt-driven method to read data from the MPU6050 sensor on the NRF52840, and it functions as expected. However, I encounter an issue where I am unable to establish a Bluetooth connection while the interrupt-based reading is active. I am working with the nrf connect sdk v2.6.1
and have configured the peripheral_uart
example.
After I deleted that line, the Bluetooth connection became normal:
mpu_read_n_reg(info, ACCEL_XOUT_H, info->sensor_data.raw_data, 14);
static void mpu6050_thread(void *p1, void *p2, void *p3) { ARG_UNUSED(p2); ARG_UNUSED(p3); int ret = 0; uint16_t tmp[7]; mpu6050_info_t *info = p1; struct sensor_value val[7]; while (1) { k_sem_take(&info->gpio_sem, K_FOREVER); data_cnt++; mpu_read_n_reg(info, ACCEL_XOUT_H, info->sensor_data.raw_data, 14); gpio_pin_interrupt_configure_dt(info->int_gpio, GPIO_INT_EDGE_TO_ACTIVE); info->sensor_data.accel_x = sys_be16_to_cpu(info->sensor_data.raw_data[0]); info->sensor_data.accel_y = sys_be16_to_cpu(info->sensor_data.raw_data[1]); info->sensor_data.accel_z = sys_be16_to_cpu(info->sensor_data.raw_data[2]); info->sensor_data.temp = sys_be16_to_cpu(info->sensor_data.raw_data[3]); info->sensor_data.gyro_x = sys_be16_to_cpu(info->sensor_data.raw_data[4]); info->sensor_data.gyro_y = sys_be16_to_cpu(info->sensor_data.raw_data[5]); info->sensor_data.gyro_z = sys_be16_to_cpu(info->sensor_data.raw_data[6]); } }
MPU6050 CONFIG:
static const uint8_t mpu6050_init_cmd[11][2] = { {PWR_MGMT_1, 0x80}, // PWR_MGMT_1, DEVICE_RESET // need wait {PWR_MGMT_1, 0x00}, // cleat SLEEP {GYRO_CONFIG, 0x18}, // Gyroscope Full Scale Range = ± 2000 °/s {ACCEL_CONFIG, 0x00}, // Accelerometer Full Scale Range = ± 2g {INT_ENABLE, 0x01}, // Interrupt Enable. DATA_RDY_EN {USER_CTRL, 0x00}, // User Control.auxiliary I2C are logically driven by the primary I2C bus {FIFO_EN, 0x00}, // FIFO Enable.disenable {SMPLRT_DIV, 99}, // Sample Rate Divider.Sample Rate = 1KHz / (1 + 99) {CONFIG, 0x23}, // EXT_SYNC_SET = GYRO_ZOUT_L[0]; Bandwidth = 3 {PWR_MGMT_1, 0x01}, // Power Management 1.PLL with X axis gyroscope reference {PWR_MGMT_2, 0x00} // Power Management 2 };
