After the power failure of the host, the master and slave are disconnected.
What is the slave still doing at this time?
Please describe your setup. What is the host, master, and slave in this context? Also, are you using Bluetooth?
Vidar
Sorry. Let me rephrase my question.
When I add the following code and then disconnect the power supply from the central and continue the power supply from the peripheral, a fatal error is reported.
void BTN_Init(void)
nrf_gpio_cfg_input(BUTTON_1,NRF_GPIO_PIN_PULLUP);
nrf_gpio_cfg_input(BUTTON_2,NRF_GPIO_PIN_PULLUP);
nrf_gpio_cfg_input(BUTTON_3,NRF_GPIO_PIN_PULLUP);
nrf_gpio_cfg_input(BUTTON_4,NRF_GPIO_PIN_PULLUP);
nrf_gpio_cfg_input(BUTTON_5,NRF_GPIO_PIN_PULLUP);
nrf_gpio_cfg_input(BUTTON_6,NRF_GPIO_PIN_PULLUP);
nrf_gpio_cfg_input(BUTTON_7,NRF_GPIO_PIN_PULLUP);
nrf_gpio_cfg_input(BUTTON_8,NRF_GPIO_PIN_PULLUP);
nrf_gpio_cfg_input(BUTTON_9,NRF_GPIO_PIN_PULLUP);
nrf_gpio_cfg_input(BUTTON_10,NRF_GPIO_PIN_PULLUP);
00> <info> app: Disconnected, reason: 0x8 00> 00> <info> app: Connection timeout. 00> 00> <error> app: Fatal error
If you do not add this code, the result of the run will not be "Fatal error".
Please try to build your project with the "debug" build configuration instead "release". This will replace the "Fatal error" message with information about where the error raised.
How to build my project with the "debug" ?
I have selected debug in the follwing image.
I assumed you were using Segger embedded studio. For Keil, you can add the DEBUG flag to the list of pre-processor symbols.
