Build problems after changing to Linux: zephyr/zephyr_pre0.elf section `text' will not fit in region `FLASH'
I have recently changed my development platform from a Windows 10 PC to another PC running Ubuntu. I am using the v2.5.0 SDK version on both platforms and the nrf52840dk as build target.
I try to compile my project based on the Matter Light Bulb sample, to which I have added some SPI functionality, however I receive the following error and the build fails.
Since I was able to compile and flash on the Windows PC I don't believe it is actually a size conflict, but maybe has something to do with file locations?
The way I transferred my project was by compiling the unmodified sample on the Ubuntu device and then replacing all the Files I have modified.
I am not sure how to go about fixing this, any help is appreciated.
[145/340] Linking C static library modules/nrf/subsys/nfc/ndef/lib..__nrf__subsys__nfc__ndef.a
[146/340] Building C object modules/nrf/subsys/nfc/lib/CMakeFiles/..__nrf__subsys__nfc__lib.dir/platform_internal_irq.c.obj
[147/340] Linking C static library modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a
[147/340] Performing build step for 'mcuboot_subimage'
[1/6] Linking C executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
: && ccache /home/install/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  -fuse-ld=bfd  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/install/nrf_apps/spi_light_bulb/build/mcuboot/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/picolibc/liblib__libc__picolibc.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/soc/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/soc/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -L"/home/install/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m+fp/hard"  -L/home/install/nrf_apps/spi_light_bulb/build/mcuboot/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfpu=fpv4-sp-d16  -mfloat-abi=hard  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  -DPICOLIBC_DOUBLE_PRINTF_SCANF  /home/install/ncs/v2.5.0/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_platform_0.9.18.a  --specs=picolibc.specs  -lc  -lgcc  /home/install/ncs/v2.5.0/nrfxlib/crypto/nrf_cc310_bl/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_bl_0.9.12.a && cd /home/install/nrf_apps/spi_light_bulb/build/mcuboot/zephyr && /home/install/ncs/toolchains/1f9b40e71a/usr/local/bin/cmake -E true
/home/install/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `text' will not fit in region `FLASH'
/home/install/ncs/toolchains/1f9b40e71a/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `FLASH' overflowed by 7102 bytes
collect2: error: ld returned 1 exit status
[198/340] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_debug.c.obj
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf
cd /home/install/nrf_apps/spi_light_bulb/build/mcuboot && /home/install/ncs/toolchains/1f9b40e71a/usr/local/bin/cmake --build . --
[200/340] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_debug_assert.c.obj
[201/340] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_peripherals_alloc.c.obj
[202/340] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_encrypt.c.obj
[203/340] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_pib.c.obj
[204/340] Building C object modules/nrfxlib/nrf_802154/nrf_802154/driver/CMakeFiles/nrf-802154-driver.dir/src/nrf_802154_tx_work_buffer.c.obj
FATAL ERROR: command exited with status 1: /home/install/ncs/toolchains/1f9b40e71a/usr/local/bin/cmake --build /home/install/nrf_apps/spi_light_bulb/build
 *  The terminal process terminated with exit code: 1.
    If you've compiled the exact same firmware for the exact same build target using the exact same version of NCS then it should not be the case that you get a flash overflow on one version of the
    Here's a couple of tests:
    1. Could you remove the build folder completely before rebuilding? Pristine build is not as pristine as you would suggest, so some changes may be cached between pristine builds
    2. Use the exact same firmware that compiles on Windows on your Linux machine and compile it with the exact same toolchain and SDK version (this is a sanity check step to ensure that you're actually trying to compile the same thing)
    Andreas
  • Thanks for the reply. I somehow managed to mix up components of the v2.4.2 and the v2.5.0 SDK without noticing.
  • Happy to help
    That happens sometimes. It's easy to mix up the the various samples from the various SDK versions since the only thing that differs between them is a number in the samples paths.
    I assume that this case can be closed for now, but as always please feel free to open new cases if you have any new questions or queries
    Andreas
