Configuring pm_static.yml when porting from SPM to TFM
I'm working on updating my copy of the nRF Connect SDK from 1.7.0 to 2.4.2. My project runs on an nRF9160 so I had SPM configured for my project and now I need to use TFM instead. To do that, I'm following these instructions: https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/security/tfm.html#ug-tfm-migrate. However, I get an error during build configuration from the partition manager saying that there are gaps in my partitions:
Partition manager failed: Incorrect amount of gaps found in static configuration. There must be exactly one gap in the static configuration to support placing the dynamic partitions (such as 'app').
Gaps found (2):0x20000000-0x20010000 0x200144e8-0x20040000 The most common solution to this problem is to fill the smallest of these gaps with statically defined partition(s) until there is only one gap left.
Alternatively re-order the already defined static partitions so that only one gap remains.
I'm not finding any gaps in my file, and I'm changing over the names as instructed. Here's my new pm_static.yml file
app:
  address: 0x1c200
  end_address: 0xfa000
  region: flash_primary
external_flash:
  address: 0xf2000
  end_address: 0x400000
  placement:
    after:
    - mcuboot_secondary
  region: external_flash
mcuboot:
  address: 0x0
  end_address: 0xc000
  placement:
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0xc000
  # end_address: 0xc200
  placement:
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0xc000
  end_address: 0xfe000
  orig_span: &id001
  - tfm
  - mcuboot_pad
  - app
  span: *id001
mcuboot_primary_app:
  address: 0xc200
  orig_span: &id002
  - app
  - tfm
  span: *id002
mcuboot_secondary:
  address: 0x0
  device: MX25L3
  end_address: 0xf2000
  placement:
    align:
      start: 0x0
nrf_modem_lib_ctrl:
  address: 0x20010000
  end_address: 0x200104e8
  inside:
  - sram_nonsecure
  placement:
    after:
    - start
  region: sram_primary
nrf_modem_lib_rx:
  address: 0x200124e8
  end_address: 0x200144e8
  inside:
  - sram_nonsecure
  placement:
    after:
    - nrf_modem_lib_tx
nrf_modem_lib_sram:
  address: 0x20010000
  orig_span: &id003
  - nrf_modem_lib_ctrl
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id003
nrf_modem_lib_tx:
  address: 0x200104e8
  end_address: 0x200124e8
  inside:
  - sram_nonsecure
  placement:
    after:
otp:
  address: 0xff8108
  end_address: 0xff83fc
  region: otp
tfm:
  address: 0xc000
  end_address: 0x1c200
  inside:
  placement:
    before:
    - app
tfm_secure:
  address: 0xc000
  span: [mcuboot_pad, tfm]
tfm_nonsecure:
  address: 0x1c200
  span: [app]
sram_nonsecure:
  address: 0x20010000
  end_address: 0x20040000
  orig_span: &id004
  - sram_primary
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id004
sram_primary:
  address: 0x200144e8
sram_secure:
  address: 0x20000000
  end_address: 0x20010000
  orig_span: &id005
  span: *id005
lwm2m_carrier:
  address: 0xfa000
  inside:
  - tfm_nonsecure
settings_storage:
  address: 0xfe000
  end_address: 0x100000
  placement:
    before:
    - end
  inside:
  - tfm_nonsecure
compared to my old one:
app:
  address: 0x1c200
external_flash:
  address: 0xf2000
  placement:
    after:
    - mcuboot_secondary
mcuboot:
  address: 0x0
  end_address: 0xc000
  placement:
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0xc000
  end_address: 0xc200
  placement:
    before:
mcuboot_primary:
  address: 0xc000
  orig_span: &id001
  - spm
  - mcuboot_pad
  - app
  span: *id001
  address: 0xc200
  orig_span: &id002
  - app
  - spm
  span: *id002
mcuboot_secondary:
  address: 0x0
  device: MX25L3
  placement:
    align:
      start: 0x0
nrf_modem_lib_ctrl:
  address: 0x20010000
  inside:
  - sram_nonsecure
  placement:
    after:
    - spm_sram
    - start
nrf_modem_lib_rx:
  address: 0x200124e8
  inside:
  - sram_nonsecure
  placement:
    after:
    - nrf_modem_lib_tx
nrf_modem_lib_sram:
  address: 0x20010000
  orig_span: &id003
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id003
nrf_modem_lib_tx:
  address: 0x200104e8
  inside:
  - sram_nonsecure
  placement:
    after:
otp:
  address: 0xff8108
  region: otp
spm:
  address: 0xc200
  inside:
  placement:
    before:
    - app
spm_sram:
  address: 0x20000000
  inside:
  - sram_secure
  placement:
    after:
    - start
sram_nonsecure:
  address: 0x20010000
  orig_span: &id004
  - sram_primary
  - nrf_modem_lib_tx
  - nrf_modem_lib_rx
  span: *id004
sram_primary:
  address: 0x200144e8
sram_secure:
  address: 0x20000000
  orig_span: &id005
  - spm_sram
  span: *id005
lwm2m_carrier:
  address: 0xfa000
settings_storage:
  address: 0xfe000
  placement:
    before:
    - end
Does anyone see anything glaringly wrong or have any tips?
  • I've gotten the project to build now, but I think that I have the partitions set up incorrectly because I receive this log from MCUBoot:
    *** Booting Zephyr OS build v3.3.99-ncs1-2 ***
    [00:00:00.474,884] <wrn> mcuboot: Failed reading image headers; Image=0
    [00:00:00.474,914] <err> mcuboot: Unable to find bootable image
    Here's my updated pm_static.yml file:
    app:
      address: 0x1c200
    external_flash:
      address: 0xf2000
      placement:
        after:
        - mcuboot_secondary
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0xc000
    mcuboot_primary:
      address: 0xc000
      orig_span: &id001
      - tfm
      - mcuboot_pad
      - app
      span: *id001
      address: 0xc000
      orig_span: &id002
      - app
      - tfm
      span: *id002
    mcuboot_secondary:
      address: 0x0
      device: MX25L3
      placement:
        align:
          start: 0x0
    nrf_modem_lib_ctrl:
      address: 0x20010000
      inside:
      - sram_nonsecure
      placement:
        after:
        - start
    nrf_modem_lib_rx:
      address: 0x200124e8
      inside:
      - sram_nonsecure
      placement:
        after:
        - nrf_modem_lib_tx
    nrf_modem_lib_sram:
      address: 0x20010000
      orig_span: &id003
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id003
    nrf_modem_lib_tx:
      address: 0x200104e8
      inside:
      - sram_nonsecure
      placement:
        after:
    otp:
      address: 0xff8108
      region: otp
    placeholder:
      address: 0xc200
    tfm:
      address: 0x10000
      end_address: 0x18000
      inside:
      placement:
        before:
        - app
    tfm_secure:
      address: 0xc000
    tfm_nonsecure:
      address: 0x18000
      span: [app]
    # placeholder2:
    #   address: 0x1c000
    #   size: 0x200
    #   region: flash_primary
    sram_nonsecure:
      address: 0x20010000
      orig_span: &id004
      - sram_primary
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id004
    sram_primary:
      address: 0x200144e8
      inside:
        - sram_nonsecure
    sram_secure:
      address: 0x20000000
    tfm_sram:
      address: 0x20000000
      placement:
        after:
        - start
    lwm2m_carrier:
      address: 0xfa000
      inside:
      - nonsecure_storage
    settings_storage:
      address: 0xfe000
      placement:
        before:
        - end
      inside:
      - nonsecure_storage
    nonsecure_storage:
      address: 0xfa000
    And here's the generated partitions.yml
    app:
      address: 0x18000
    external_flash:
      address: 0xf2000
      placement:
        after:
        - mcuboot_secondary
    lwm2m_carrier:
      address: 0xfa000
      inside:
      - nonsecure_storage
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0xc000
      end_address: 0xc200
    mcuboot_primary:
      address: 0xc000
      orig_span: &id001
      - tfm
      - mcuboot_pad
      - app
      span: *id001
      address: 0xc000
      orig_span: &id002
      - app
      - tfm
      span: *id002
    mcuboot_secondary:
      address: 0x0
      device: MX25L3
      placement:
        align:
          start: 0x0
    nonsecure_storage:
      address: 0xfa000
    nrf_modem_lib_ctrl:
      address: 0x20010000
      inside:
      - sram_nonsecure
      placement:
        after:
        - start
    nrf_modem_lib_rx:
      address: 0x200124e8
      inside:
      - sram_nonsecure
      placement:
        after:
        - nrf_modem_lib_tx
    nrf_modem_lib_sram:
      address: 0x20010000
      orig_span: &id003
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id003
    nrf_modem_lib_tx:
      address: 0x200104e8
      inside:
      - sram_nonsecure
      placement:
        after:
    otp:
      address: 0xff8108
      region: otp
    placeholder:
      address: 0xc200
    settings_storage:
      address: 0xfe000
      inside:
      - nonsecure_storage
      placement:
        before:
        - end
    sram_nonsecure:
      address: 0x20010000
      orig_span: &id004
      - sram_primary
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id004
    sram_primary:
      address: 0x200144e8
    sram_secure:
      address: 0x20000000
    tfm:
      address: 0x10000
      inside:
      placement:
        before:
        - app
    tfm_nonsecure:
      address: 0x18000
      span:
      - app
    tfm_secure:
      address: 0xc000
      span:
      - mcuboot_pad
      - tfm
    tfm_sram:
      address: 0x20000000
      placement:
        after:
        - start
    There's some discrepancy between the addresses but not sure why that would be?
  • Hi esisk,
    Does this mean that you have resolved the original "Incorrect amount of gaps found in static configuration" issue?
    Could you please try compiling without pm_static.yml, test, and share with us the result and the generated partitions.yml file?
    When you mention updating your copy of NCS from 1.7.1 to 2.4.2, what do you mean? Did you checkout a new west manifest and run west update, or did you install a new copy of the SDK?
    Hieu
  • Technically yes I solved my initial question since the project builds. Functionally, no since I believe that I've built the project in an incorrect way. MCUBoot can't find a suitable program to boot into so I probably have the address of either TFM or my app configured incorrectly.
    Sure I just tried building without pm_static.yml and got this error during build:
    !!!Partition alignment error!!!
    The non-secure start address in pm_static.yml or generated partition.yml is: 0x14000
    which is not aligned with the SPU region size.
    Refer to the documentation section 'TF-M partition alignment requirements'
    for more information.
       16 | #pragma message "\n\n!!!Partition alignment error!!!"\
    /home/ethan/ncs/nrf/modules/tfm/tfm/boards/common/assert.c:22:2: error: #error "TF-M non-secure start address is not aligned on SPU region size"
       22 | #error "TF-M non-secure start address is not aligned on SPU region size"
    The generated partitions.yml is:
    EMPTY_0:
      address: 0xfa000
      placement:
        after:
        - settings_storage
    app:
      address: 0x14000
      end_address: 0xf8000
    external_flash:
      address: 0xec000
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0xc000
      end_address: 0xc200
      placement:
        before:
    mcuboot_primary:
      address: 0xc000
      orig_span: &id001
      - app
      - tfm
      - mcuboot_pad
      span: *id001
      address: 0xc200
      orig_span: &id002
      - app
      - tfm
      span: *id002
    mcuboot_secondary:
      address: 0x0
      device: DT_CHOSEN(nordic_pm_ext_flash)
      end_address: 0xec000
      placement:
        align:
          start: 0x4
      share_size:
      - mcuboot_primary
    mcuboot_sram:
      address: 0x20000000
      end_address: 0x20008000
      orig_span: &id003
      - tfm_sram
      span: *id003
    nonsecure_storage:
      address: 0xf8000
      orig_span: &id004
      - settings_storage
      span: *id004
    nrf_modem_lib_ctrl:
      address: 0x20008000
      end_address: 0x200084e8
      inside:
      - sram_nonsecure
      placement:
        after:
        - tfm_sram
        - start
    nrf_modem_lib_rx:
      address: 0x2000a568
      end_address: 0x2000c568
      inside:
      - sram_nonsecure
      placement:
        after:
        - nrf_modem_lib_tx
    nrf_modem_lib_sram:
      address: 0x20008000
      orig_span: &id005
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id005
    nrf_modem_lib_tx:
      address: 0x200084e8
      end_address: 0x2000a568
      inside:
      - sram_nonsecure
      placement:
        after:
    otp:
      address: 0xff8108
      region: otp
    settings_storage:
      address: 0xf8000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x8000
        before:
        - end
    sram_nonsecure:
      address: 0x20008000
      orig_span: &id006
      - sram_primary
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id006
    sram_primary:
      address: 0x2000c568
    sram_secure:
      address: 0x20000000
      orig_span: &id007
      - tfm_sram
      span: *id007
    tfm:
      address: 0xc200
      end_address: 0x14000
      inside:
      placement:
        before:
        - app
    tfm_nonsecure:
      address: 0x14000
      orig_span: &id008
      - app
      span: *id008
    tfm_secure:
      address: 0xc000
      orig_span: &id009
      - mcuboot_pad
      - tfm
      span: *id009
    tfm_sram:
      address: 0x20000000
      inside:
      - sram_secure
      placement:
        after:
        - start
    I ended up just installing an entirely new copy of the SDK. It's important that I get this working with the correct application address offsets since I need to update devices that are already in the field running code build with NCS 1.7.0 and an immutable MCUBoot bootloader.
  • There was an issue in NCS 2.2.0 and 2.3.0 where the Partition Manager with dynamic configuration causes this issue. I thought that this has been fixed in 2.4.2 though... Does this still happen in your standalone new copy of NCS? I will probably have to approach this from a different angle.
    Regarding the new application address offset, you are completely right that it has to be the same as it was originally on the in-field device.
  • /home/ethan/build_keys/cell_priv.pemYes I followed the instructions for command line installation found here https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/installation/install_ncs.html. I did not update my old version of the SDK, just made a completely new copy and checked out v2.4.2 from GitHub. Is there a PR on GitHub where I can reference the partition manager fix you mentioned? Maybe I could try to patch my issue locally based on that
    Thanks for confirming that the application address offset must be the same. I tried to simplify pm_static.yml as much as possible and got:
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    mcuboot_primary: # mcuboot primary contains the updatable apps (tfm and main app) and mcuboot pad
      address: 0xc000
      span: [tfm, mcuboot_pad, app]
    mcuboot_primary_app: # mcuboot primary contains the updatable apps (tfm and main app)
      address: 0xc200
      span: [tfm, app]
    tfm_nonsecure:
      address: 0x1c200
      span: [app]
    tfm_secure:
      address: 0xc000
    mcuboot_pad:
      address: 0xc000
      end_address: 0xc200
    tfm:
      address: 0xc200
    app:
      address: 0x1c200
    external_flash:
      address: 0xf2000
      placement:
        after:
        - mcuboot_secondary
    mcuboot_secondary:
      address: 0x0
      device: MX25L3
      placement:
        align:
          start: 0x0
    I received an error while building saying:
    The non-secure start address in pm_static.yml or generated partition.yml is: 0x1c200
    Is configuring this impossible? I've tried a few different set ups where the non-secure region is aligned with the SPU region size and my project will build. However, MCUBoot will run and print out something like
    [00:00:00.494,262] <inf> mcuboot: Starting bootloader
    [00:00:00.494,903] <wrn> mcuboot: Cannot upgrade: not a compatible amount of sectors
    [00:00:00.535,491] <err> mcuboot: Image in the primary slot is not valid!
    [00:00:00.535,522] <err> mcuboot: Unable to find bootable image
    Thanks for looking into this Hieu
    Edit:
    I believe I've gotten pm_static.yml into a state that satisfies my requirements as well as the build system's: my app is in the same address as what's in the field and T-FM is aligned correctly. I'd appreciate you confirming that there shouldn't be any problems with this set up based on the original pm_static.yml file I shared in my original post.
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
      address: 0xc000
      address: 0xc200
      span: [tfm, app]
    tfm_nonsecure:
      address: 0x18000
      span: [app]
    tfm_secure:
      address: 0xc000
    mcuboot_pad:
      address: 0xc000
      end_address: 0xc200
    tfm:
      address: 0xc200
    app:
      address: 0x1c200
    external_flash:
      address: 0xf2000
      placement:
        after:
        - mcuboot_secondary
    mcuboot_secondary:
      address: 0x0
      device: MX25L3
      placement:
        align:
          start: 0x0
    My project builds. When running I get output from MCUBoot which seems like it's functioning correctly, but my application never boots. Here's the log output:
    [00:00:00.518,890] <inf> mcuboot: Starting bootloader
    [00:00:00.519,622] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    [00:00:00.519,958] <inf> mcuboot: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    [00:00:00.519,958] <inf> mcuboot: Boot source: none
    [00:00:00.520,385] <inf> mcuboot: Swap type: none
    Any insights as to what could be wrong? Also, is there a way to route T-FM logs via RTT? It'd be great to see if MCUBoot is booting into T-FM and there's some error there.
    Edit 2:
    After more debugging, I've found that MCUBoot is getting hung in the function boot_validate_slot in the file loader.c. This leads me to believe that MCUBoot cannot validate the images that are programmed in flash on my board. I looked in autoconf.h and found:
    #define CONFIG_TFM_KEY_FILE_S "/home/ethan/ncs/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072.pem"
    #define CONFIG_TFM_KEY_FILE_NS "/home/ethan/ncs/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072_1.pem"
    which is different than the path of my actual signing key which is /home/ethan/build_keys/cell_priv.pem. I made sure that I set:
    CONFIG_TFM_KEY_FILE_S="/home/ethan/build_keys/cell_priv.pem"
    CONFIG_TFM_KEY_FILE_NS="/home/ethan/build_keys/cell_priv.pem"
    in my application prj.conf and setting:
    CONFIG_BOOT_SIGNATURE_KEY_FILE="/home/ethan/build_keys/cell_priv.pem"
    in child_images/mcuboot/prj.conf
    However after making those changes, the application still isn't running. Any thoughts after these findings?
    Edit 3:
    Found a function where there are no more function calls and MCUBoot is getting stuck:
     * Check that a memory area consists of a given value.
    static inline bool
    boot_data_is_set_to(uint8_t val, void *data, size_t len)
        uint8_t i;
        uint8_t *p = (uint8_t *)data;
        for (i = 0; i < len; i++) {
            BOOT_LOG_ERR("boot_data_is_set_to i: %u, p: %p val: %u", i, p, val);
            if (val != p[i]) {
                BOOT_LOG_ERR("false");
                return false;
        BOOT_LOG_ERR("done");
        return true;
    In the console, "false" is getting printed so I know that the function should return it just doesn't. Which makes me realize that I had to reduce CONFIG_MAIN_STACK_SIZE to 5000 in order to build the project with logging, so the stack must have overflowed at some point. However, setting it back to CONFIG_MAIN_STACK_SIZE=10240 overflows the RAM allocated for MCUBoot by 600ish bytes when building. Setting the stack size to anything lower than 10240 results in my app not running and I can't build the project now with the original stack size.
    I'm assuming because more features/code have been added to MCUBoot since my previous SDK version. Could you give me guidance as to where I should go from here? I'm thinking of defining RAM partitions in my pm_static.yml that are the same as I had in my original pm_static.yml. I'm leaving work for today but would appreciate any feedback you have regarding this.
