About nRF5340 Audio synchronization
I am thinking of using nRF5340 Audio on a development board.
The I2S-compatible IC on the headset side is an IC called AK4432VT.
The following settings are required to support the above IC.
MCLK: 12.288MHz
BICK: 3.07MHz
LRCK: 48kHz
Bit length: 32bit
To achieve this, I set the source as follows.
static nrfx_i2s_config_t cfg = {
/* Pins are configured by pinctrl. */
.skip_gpio_cfg = true,
.skip_psel_cfg = true,
.irq_priority = DT_IRQ(I2S_NL, priority),
.mode = NRF_I2S_MODE_MASTER,
.format = NRF_I2S_FORMAT_I2S,
.alignment = NRF_I2S_ALIGN_LEFT,
.ratio = NRF_I2S_RATIO_256X,
.mck_setup = 0xCCCCC000,
.channels = NRF_I2S_CHANNELS_STEREO,
.clksrc = NRF_I2S_CLKSRC_ACLK,
.enable_bypass = true,
.sample_width = NRF_I2S_SWIDTH_32BIT,
Now the expected waveform is displayed, but
LED2 is no longer lit and synchronization is no longer possible.
This is probably due to the change in MCLK,
but what and how should I change to make it synchronized?
    Could you kindly help provide the application log from UART and the following information?
    • Which NCS version are you using now? It would be great to use NCS v2.6.0 or the latest main version.
    • Are you using BIS or CIS?
    • Could you describe what the audio sounds like?
    • Providing the full log from the nRF5340 would be very helpful since we can know if the drift/pres compensation is working properly or not.
    Amanda H.
            ->V2.5.0
            ->CIS
            -> The AK4432 is used as the I2S IC for line input.
      ->As I asked in another ticket, when I build in debug mode
    an error occurs, so I cannot output the log via UART output.
    Junichi said:
    ->V2.5.0
    Could you try the latest version v2.7.0 which has bugfixs?
    This doesn't answer the question. Please describe what the audio sounds like
    Without logs, I could not provide any suggestions.
    -Amanda H.
