Detect External Pin Interrupts with nRF51
Hello, I am using external interrupt from an ADXL345 . Can you tell me how to detect that external interrupt with the nRF51 ?
  • The following code will detect a Low-to-High transition on a given Interrupt Pin( needs to be defined by you).
    GPIOTE Event Handler:
    void gpiote_evt_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
        switch(action)
            case NRF_GPIOTE_POLARITY_LOTOHI:
                //do something
                //do nothing
    Main Function:
        ret_code_t ret_code;
        ret_code = nrf_drv_gpiote_init();
        APP_ERROR_CHECK(ret_code);
        nrf_drv_gpiote_in_config_t config =
            .sense = NRF_GPIOTE_POLARITY_LOTOHI,
            .pull = NRF_GPIO_PIN_NOPULL ,
            .is_watcher = false,
            .hi_accuracy = false
        ret_code = nrf_drv_gpiote_in_init(INTERRUPT_PIN, &config, gpiote_evt_handler);
        nrf_drv_gpiote_in_event_enable(INTERRUPT_PIN,true);
    Update:
    Project files for an example that toogles a led when a button is pressed
    toggle_led_fixed.zip
  • finally. its working.thanks for your great help!!
