Precise data bus error on mqtt_helper_thread
I have an application that each 30 minutes connects to AWS, sends some data and then disconnects and goes to sleep. I have based my aplication on the asset_tracker application example.
The first time the devices connects to the AWS cloud everything works correctly. The device connects to AWS, sends the data and disconnects. But the second time it tries to connect I get the following error:
[00:00:49.673,004] <inf> app_event_manager: DATA_EVT_DATA_READY
[00:00:49.679,687] <inf> cloud_module: Connecting to AWS IoT Core
[00:00:49.686,309] <dbg> aws_iot: aws_iot_connect: No hostname provided, using Kconfig value: ---------ats.iot.us-east-1.amazonaws.com
[00:00:53.357,116] <dbg> aws_iot: on_connack: MQTT client connected!
[00:00:53.366,302] <err> os: ***** BUS FAULT *****
[00:00:53.371,765] <err> os: Precise data bus error
[00:00:53.377,502] <err> os: BFAR Address: 0x0
[00:00:53.382,873] <err> os: r0/a1: 0x73776124 r1/a2: 0x00067f62 r2/a3: 0x00000000
[00:00:53.391,601] <err> os: r3/a4: 0x73776124 r12/ip: 0x00000000 r14/lr: 0x0001cbeb
[00:00:53.400,299] <err> os: xpsr: 0x61000000
[00:00:53.405,578] <err> os: s[ 0]: 0x200156f0 s[ 1]: 0x20015664 s[ 2]: 0x00000001 s[ 3]: 0x00000 000
[00:00:53.416,046] <err> os: s[ 4]: 0x00000000 s[ 5]: 0x0003d855 s[ 6]: 0x00000000 s[ 7]: 0x0003d 925
[00:00:53.426,544] <err> os: s[ 8]: 0x00000010 s[ 9]: 0x00000000 s[10]: 0x20015664 s[11]: 0x0003c 253
[00:00:53.437,011] <err> os: s[12]: 0x00050cd5 s[13]: 0x00040109 s[14]: 0x00000000 s[15]: 0x00000 000
[00:00:53.447,479] <err> os: fpscr: 0x00000000
[00:00:53.452,728] <err> os: Faulting instruction address (r15/pc): 0x00009038
[00:00:53.460,662] <err> os: >>> ZEPHYR FATAL ERROR 25: Unknown error on CPU 0
[00:00:53.468,627] <err> os: Current thread: 0x20012c98 (mqtt_helper_thread)
This is my prj.conf
# General
CONFIG_PICOLIBC=y
CONFIG_FPU=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_LOG=y
CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_ASSERT=y
CONFIG_INIT_STACKS=y
# We are simulating transmission of frames 0 NO, 1 YES
CONFIG_IS_SIMULATION=0
#logging
CONFIG_LOG_MAX_LEVEL=4
CONFIG_MODEM_MODULE_LOG_LEVEL_DBG=y
CONFIG_APP_MODULE_LOG_LEVEL_DBG=y
CONFIG_DATA_MODULE_LOG_LEVEL_DBG=y
CONFIG_CLOUD_MODULE_LOG_LEVEL_DBG=y
CONFIG_CONFIG_MODULE_LOG_LEVEL_DBG=y
CONFIG_SENSOR_MODULE_LOG_LEVEL_DBG=y
CONFIG_LOCATION_MODULE_LOG_LEVEL_DBG=y
CONFIG_CLOUD_CODEC_LOG_LEVEL_DBG=y
CONFIG_BUTTONS_MODULE_LOG_LEVEL_DBG=y
CONFIG_LEDS_MODULE_LOG_LEVEL_DBG=y
CONFIG_EXT_MEMORY_MODULE_LOG_LEVEL_DBG=y
CONFIG_FLASH_LOG_LEVEL_DBG=y
# nRF modem library
CONFIG_NRF_MODEM_LIB=y
CONFIG_NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC=y
# NEWLIB C
CONFIG_NEWLIB_LIBC=y
CONFIG_NEWLIB_LIBC_FLOAT_SCANF=y
CONFIG_TIMING_FUNCTIONS=y
CONFIG_CBPRINTF_FP_SUPPORT=y
# Memory and stack configuration
CONFIG_HEAP_MEM_POOL_SIZE=15200
CONFIG_MAIN_STACK_SIZE=8190
CONFIG_AT_MONITOR_HEAP_SIZE=1024
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_HW_STACK_PROTECTION=y
CONFIG_THREAD_NAME=y
# CJSON
CONFIG_CJSON_LIB=y
# Configuration required by Event Manager
CONFIG_APP_EVENT_MANAGER=y
CONFIG_APP_EVENT_MANAGER_LOG_EVENT_TYPE=n
# CAF - Common Application Framework
CONFIG_CAF=y
# LTE Link Control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y
# CONFIG_LTE_MODE_PREFERENCE_LTE_M_PLMN_PRIO=y
CONFIG_LTE_MODE_PREFERENCE_LTE_M=y
CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG=y
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_CHOICE=CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
# Date Time library
CONFIG_DATE_TIME=y
CONFIG_DATE_TIME_AUTO_UPDATE=y
# AWS IoT library
CONFIG_AWS_IOT=y
CONFIG_AWS_IOT_BROKER_HOST_NAME="--------------ats.iot.us-east-1.amazonaws.com"
CONFIG_MQTT_HELPER_SEC_TAG=16842753
CONFIG_AWS_IOT_TOPIC_UPDATE_DELTA_SUBSCRIBE=y
CONFIG_AWS_IOT_AUTO_DEVICE_SHADOW_REQUEST=n
CONFIG_AWS_IOT_TOPIC_UPDATE_ACCEPTED_SUBSCRIBE=n
CONFIG_AWS_IOT_TOPIC_DELETE_ACCEPTED_SUBSCRIBE=n
CONFIG_AWS_IOT_TOPIC_DELETE_REJECTED_SUBSCRIBE=n
CONFIG_AWS_IOT_TOPIC_GET_REJECTED_SUBSCRIBE=n
CONFIG_AWS_IOT_TOPIC_GET_ACCEPTED_SUBSCRIBE=n
CONFIG_MQTT_CLEAN_SESSION=y
CONFIG_AWS_IOT_LOG_LEVEL_DBG=y
# Power manager
CONFIG_PM_DEVICE=y
CONFIG_PM=y
# FOTA Download
CONFIG_AWS_FOTA=y
CONFIG_FOTA_DOWNLOAD=y
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
# DFU Target
CONFIG_DFU_TARGET=y
CONFIG_DFU_TARGET_STREAM_SAVE_PROGRESS=y
# Settings
CONFIG_SETTINGS=y
CONFIG_SETTINGS_NVS=y
# Non-volatile Storage
CONFIG_NVS=y
# # Application update support
# # CONFIG_BOOTLOADER_MCUBOOT=y
# Image manager
CONFIG_IMG_MANAGER=y
CONFIG_FLASH=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
CONFIG_FLASH_MAP=y
CONFIG_FLASH_PAGE_LAYOUT=y
# # CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=n
# FILE SYSTEM
CONFIG_FLASH_JESD216_API=y
CONFIG_FILE_SYSTEM=n
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# # SENSORS
CONFIG_SENSOR=y
# BME680 - Temperature and humidity sensor.
CONFIG_BME680=y
# MAX17262 - Maxim battery fuel gauge
CONFIG_MAX17262=y
# CONFIG_BH1749 - RGB Sensor
CONFIG_BH1749=y
CONFIG_BH1749_TRIGGER=y
# PWM
CONFIG_PWM=y
# SPI external flash
CONFIG_SPI=y
CONFIG_SPI_NOR=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_PM_EXTERNAL_FLASH_BASE=0x0
#UART GSM
CONFIG_UART_ASYNC_API=y
CONFIG_UART_LINE_CTRL=y
CONFIG_RING_BUFFER=y
# CONFIG_REBOOT=y
# # WiFI
CONFIG_WIFI=y
CONFIG_WIFI_NRF700X=y
CONFIG_WIFI_NRF700X_SKIP_LOCAL_ADMIN_MAC=y
# Scan only using offload API
# CONFIG_WPA_SUPP=n
CONFIG_NRF_WIFI_SCAN_MAX_BSS_CNT=4
CONFIG_WIFI_NRF700X_SCAN_TIMEOUT_S=10
CONFIG_NET_L2_ETHERNET=y
# CONFIG_NET_NATIVE=y
# CONFIG_NET_IPV4=y
# CONFIG_NET_DHCPV4=y
# CONFIG_NET_STATISTICS=y
# CONFIG_NET_STATISTICS_WIFI=y
# CONFIG_NET_STATISTICS_USER_API=y
# CONFIG_NET_CONTEXT_SYNC_RECV=y
# # Disable unused networking options
# CONFIG_NET_IPV6=n
# For nRF9160 the default is socket interface
# CONFIG_NET_DEFAULT_IF_ETHERNET=y
# CONFIG_MBEDTLS=n
# CONFIG_NORDIC_SECURITY_BACKEND=n
I'm using NCS 2.6.1
