SDK
I have a question about SDK.
Why not a single example build out of the box in SDK.
As a beginner to learn about nRF devices, if i have to face all these weird issues in all examples then how i will be able to understand the code.
First, waste a lot of time to fix issues then test the codes.
Why it is like that?
I am using Segger studio and latest SDK>
Can someone guide me what i am missing here?
Thanks
  • I setup VS and Connect SDK by following the course at academy.
    I am facing these issues in a simple blinky example
    #include errors detected based on information provided by the configurationProvider setting. Squiggles are disabled for this translation unit (C:\nordic\myApps\blinky_pwm\src\main.c).
    cannot open source file "syscall_list.h" (dependency of "C:\Users\ALIKH\.vscode\extensions\ms-vscode.cpptools-1.20.5-win32-x64\bin\zephyr\kernel.h")
    cannot open source file "devicetree_generated.h" (dependency of "C:\Users\ALIKH\.vscode\extensions\ms-vscode.cpptools-1.20.5-win32-x64\bin\zephyr\device.h")
    cannot open source file "syscalls/pwm.h" (dependency of "C:\Users\ALIKH\.vscode\extensions\ms-vscode.cpptools-1.20.5-win32-x64\bin\zephyr\drivers\pwm.h")
    The PWM drivers must be enabled by CONFIG_PWM to be included in the build
    Segger Studio and the latest nRF Connect SDK are not compatible so you will have to go through https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/ as you say to to see how to get started with nRF Connect SDK in VS Code.
    Could you verify what release of the SDK you're using? And is the sample from the same SDK or is it from the Academy course github repo? In general you should also include the full build log as there may be items you've missed when only pasting a snippet.
    Andreas
  • Hi
    I downloaded latest Segger studio and latest verions of SDK nRF5_SDK_17.1.0_ddde560
    I am using SDK sample but not any GitHub repo. As you said they are not compatible. I agreed but i also downloaded VS and nRF connect in VS. Their blinky example also has problem. Actually, i opened this thread related to VS and nRF connect but not segger studio. I mistakenly mentioned Segger studio in first message.
    Although, i worked on Segger studio and make it work a blinky examples after some research and fixing bugs
  • I was able to compile this example by deleting SEGGER_RTT_Syscalls_SES.c: file from the project(read in another threads)
    Now i want to understand, what this example is supposed to do after reading Analog channel?
    Will it print something on some terminal or what?
       Author : Abdelali Boussetta @rmptxf
       Description : This saadc example uses one channel (AIN1 (P0.3)), samples at 100ms (10 samples) =  get result each (1 second).
       It uses 14Bit as a resolution.
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nrf.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define SAMPLES_IN_BUFFER 10
    static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
    static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t     m_ppi_channel;
    static uint32_t              m_adc_evt_counter;
    // RESULT = [V(P) � V(N) ] * GAIN/REFERENCE * 2(RESOLUTION - m)
    // (m=0) if CONFIG.MODE=SE, or (m=1) if CONFIG.MODE=Diff.
    // V(N) = 0;
    // GAIN = 1/6;
    // REFERENCE Voltage = internal (0.6V);
    // RESOLUTION : 12 bit;
    // m = 0;
    // 12bit
    // V(P) = RESULT x REFERENCE / ( GAIN x RESOLUTION) = RESULT x (600 / (1/6 x 2^(12)) =  ADC_RESULT x 0.87890625;
    //#define ADC_RESULT_IN_MILLI_VOLTS(ADC_RESULT) ((ADC_RESULT * 0.87890625))
    // 14bit
    // V(P) = RESULT x REFERENCE / ( GAIN x RESOLUTION) = RESULT x (600 / (1/6 x 2^(14)) =  ADC_RESULT x 0.2197265625;
    #define ADC_RESULT_IN_MILLI_VOLTS(ADC_RESULT) ((ADC_RESULT * 0.2197265625))
    void timer_handler(nrf_timer_event_t event_type, void * p_context)
        ret_code_t err_code;
        /* setup m_timer for compare event every 100ms */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 100);
                                       NRF_TIMER_CC_CHANNEL0,
                                       ticks,
                                       NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                       false);
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                              timer_compare_event_addr,
                                              saadc_sample_task_addr);
            uint32_t buffer_samples = 0;
            uint16_t adc_result = 0;
            uint16_t adc_voltage_mv = 0;
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
            m_adc_evt_counter++;
            NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
            for (uint8_t i = 0; i < SAMPLES_IN_BUFFER; i++)
                buffer_samples += p_event->data.done.p_buffer[i];
            adc_result = buffer_samples/SAMPLES_IN_BUFFER;
            adc_voltage_mv = ADC_RESULT_IN_MILLI_VOLTS(adc_result);
            NRF_LOG_INFO("adc result : %d.", adc_result);
            NRF_LOG_INFO("voltage : %d mV.", adc_voltage_mv);
            NRF_LOG_INFO("---------------------------");
    void saadc_init(void)
        // Using the channel default single ended (SE) config
        // pin NRF_SAADC_INPUT_AIN1 : P0.03
        nrf_saadc_channel_config_t channel_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
        // changing the saadc resolution to 12bit
        nrf_drv_saadc_config_t saadc_config ;
        saadc_config.resolution = NRF_SAADC_RESOLUTION_14BIT;
        err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
        err_code = nrf_drv_saadc_channel_init(0, &channel_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
        uint32_t err_code = NRF_LOG_INIT(NULL);
        ret_code_t ret_code = nrf_pwr_mgmt_init();
        APP_ERROR_CHECK(ret_code);
        saadc_init();
        saadc_sampling_event_init();
        NRF_LOG_INFO("SAADC HAL simple example started.");
        while (1)
            nrf_pwr_mgmt_run();
            NRF_LOG_FLUSH();
    You need to be a bit more clear here. Are you using nRF Connect SDK or nRF5 connect SDK?  "SDK" is not and means "Software Development Kit". The names of the respective SDK's are either "nRF 5" SDK or "nRF Connect" SDK so to find the proper resources that you need to follow you need to always specify.
    Your comment here
    implies nRF Connect SDK. All of the other previous comments are ambigious (except for your latest comment)
    What SDK do you want to use? nRF5 or nRF Connect? What's your end goal?
    Could you post the build log here and state what version of nRF Connect you were using?
    Noted, thats clear. Thank you for specifying
    Andreas
