Reading file nrf_fprintf(line) ?
Dear Members,
We tried reading file with nrf_fprintf()....
Code :
 NRF_LOG_RAW_INFO("Entries count _sd: %u\r\n", entries_count);
	  //printf("UART text \r\n");
		NRF_LOG_INFO("Reading file \r \n");
		f_open(&fil, "HRM.TXT", FA_READ);
								/* Read all lines and display it */
								while (f_gets(line, sizeof line, &fil))
								 nrf_fprintf(line);
										/* Close the file */
								NRF_LOG_INFO("Finished reading file.. \n \r\n");
								f_close(&fil);
Output in UART :
0:00:00.000,000] <info> app: USBD MSC example started.
0:00:00.000,000] <info> app: Initializing disk 0 (SDC)...
sting directory _sd: /
 <DIR>   SYSTEM~1
   6716  NORDIC.TXT
  29900  RIXTRO.TXT
 305208  HRM.TXT
 210693  SPD.TXT
 120038  SPD_MPS.TXT
  75344  POW.TXT
 150265  DIS.TXT
 102699  CAD.TXT
 147407  TOR.TXT
1246035  GPS.TXT
tries count _sd: 12
[00:00:00.000,000] <info> app: Reading file
[00:00:00.000,000] <error> app: ASSERTION FAILED at ..\..\..\..\..\..\external\f
intf\nrf_fprintf.c:67
Does anyone know on how to rectify it ?
Kind regards..
    Please check which ASSERT is triggered at line 67 in nrf_fprintf.c in your SDK version.
    Vidar
  • Hi Vidar,
    Thanks for the reply,
    We can see :
    Line 67 is
     ASSERT(p_ctx->fwrite != NULL);
    SDK =
    D:\nRF5_SDK_17.0.2_d674dde\external\fprintf\nrf_fprintf.c,
    What do we miss here ?
    We want to display all the content of text file to UART.
  •  BYTE line[1024];
    Related with variable above ?
    D:\nRF5_SDK_17.0.2_d674dde\components\libraries\util\nrf_assert.h
    Line 103
    #define ASSERT(expr)                                                          \
    if (NRF_ASSERT_PRESENT)                                                       \
        if (expr)        \
        else        \
            assert_nrf_callback((uint16_t)__LINE__, (uint8_t *)__FILE__);         \
    uint16_t and BYTE ?
  • I'm not sure how you were able to build the code in the first place as you are only passing 1 argument to your nrf_fprintf() call. I checked the function declaration, and it seems to require at least 2:
    You can use the NRF_LOG_RAW_INFO() macro if you want to print strings without the logger prefix.
  • Hi Vidar,
    We tried :
                                    uint32_t bytes_written;
                                    while (f_gets( line, sizeof  line,   &fil))
                                    NRF_LOG_INFO("data: %s",line);
                                    f_close(&fil);
    Output :
     <DIR>   SYSTEM~1
       6716  NORDIC.TXT
      31700  RIXTRO.TXT
     340020  HRM.TXT
     234612  SPD.TXT
     134173  SPD_MPS.TXT
      84336  POW.TXT
     166711  DIS.TXT
     114309  CAD.TXT
     164256  TOR.TXT
    1356104  GPS.TXT
    1;31mLogs dropped (294)
    0:00:00.000,000] <info> app: data:
     app: data:
    1;31mLogs dropped (295)
    [00:00:00.000,000] <info> app: Finished reading file..
