Crash in sd_clock_hfclk_is_running on Soft Device S140, 7.3.0
Hi, I recently noticed crashing in sd_clock_hfclk_is_running() on a nrf52840 using SoftDevice S140 7.3.0. This is the callstack:
??@0x00000ac4 (Unknown Source:0)
<signal handler called>@0xffffffe9 (Unknown Source:0)
sd_clock_hfclk_is_running@0x000276ae (.../nRF5_SDK_17.1.0_ddde560/components/softdevice/s140/headers/nrf_soc.h:720)
I'm using the following to enable the hfclk whenever I enable QSPI to avoid errata 244:
sd_clock_hfclk_request();
uint32_t isHfclkRunning = 0;
do {
  APP_ERROR_CHECK(sd_clock_hfclk_is_running(&isHfclkRunning));
} while (!isHfclkRunning);
I can trigger this somewhat reliably if I unplug and plug usb power while this code triggers.
Any tips on how I can avoid this issue?
Jeff
  • One possible explanation is corruption of the instruction in FLASH itself, does this happen easily for you on many different boards? If you have only reproduced it on only one board, is it possible that you have exhausted the number flash erase cycles nrf52840 supports. From top of my head I think that is 10'000.
    To answer this question - this happens on every board I've tested on, some with single digit erase cycles
  • Another explanation might be corruption of callstack somehow, maybe you can try increasing the interrupt callstack a bit and see if problem goes away?
    Just to make sure I'm not mis-understanding it - is the stack here shared with user and interrupts? Or is interrupts separate?
    I use an 8kb stack size on the nrf52840, and the code (minus nrf5 specific stuff) runs on a 2kb stack on another mcu.
  • Thanks for sharing latest stack frame, Im not able to see anything interesting from it, other than that now the fault seems to happen somewhere in  your application (beaus 0x25ed8 is higher than the highest address in s140).  or is 0x25ed8 just an adress in your hardfault-handler maybe?
    Since it happens on many different boards, and also on pretty fresh boards then I think we can rule out flash-wearing too.
    Coretex has concept of two differint stacks, msp and psp. one for "main mode" (also called "thread mode), that cpu is using when it is not handling interrupts, and another callsstack it uses for interrupts. it is optional to use two different stacks for interrupts and "main mode", so I'm not sure what your application does.
    But all of the code in Softdevice anyway runs in interrupt mode, since all the calls to Softdevice is implemented as SVC interrupts.  And since there is only one callstack for all interrupts, Softdevice and application end up sharing the same callstack.
  • My linker file is set up like this:
    MEMORY
      FLASH (rx) : ORIGIN = 0x27000, LENGTH = 0x7d000
      RAM (rwx) : ORIGIN = 0x20008000, LENGTH = 0x38000
      CODE_RAM (rx) : ORIGIN = 0x808000, LENGTH = 0x38000
     And this was based on the notes in s140_nrf52_7.2.0_release-notes-update-1.pdf.
    The callstack clearly had `sd_clock_hfclk_is_running` in it, which looks like it's going into the SVC.
    Is 0x25ed8 not in the soft device memory space?
    What flag/code would help identify whether two different stacks are being used?
  • Looks like generic case where USB handlers works from USB IRQ (APP_USBD_CONFIG_EVENT_QUEUE_ENABLE is 0) and USB IRQ is higher (<4) than SoftDevice's SVC IRQ (==4).
