Setup:
- windows 11
- VS studio code
- Toolchain and SDK v2.6.1
- hardware: nRF52840DK / PCA10056 (bought June 2024)
- Using sdk/zigbee-Template as the base for the project.
Goal:
- Mains powered Zigbee controller with multiple switches to turn on/off multiple devices in a room.
- Using Home Assistant to bind a device/group to a switch on the controller.
What works:
- adding an OnOff cluster.
- the device and cluster are recognized by Home Assistant
- I can bind the device to a lightbulb via Home Assistant.
- Every switch will have it's own endpoint switch one is endpoint 11.
The problem:
In the Switch example I found the following code to send an On or Off command. This example binds the switch directly to a lamp. In my situation the switch and the light are binded first to the coördinator. Then (using home assistant / zigbee2mqtt) the switch binds with the light.
Using Shell commands I can see that the switch knows which bindings exist. How can I modify the code below so that I can control the light?/**@brief Function for sending ON/OFF requests to the light bulb.
* @param[in] bufid Non-zero reference to Zigbee stack buffer that will be
* used to construct on/off request.
* @param[in] cmd_id ZCL command id.
static void light_switch_send_on_off(zb_bufid_t bufid, zb_uint16_t cmd_id)
LOG_INF("Send ON/OFF command: %d", cmd_id);
ZB_ZCL_ON_OFF_SEND_REQ(bufid,
bulb_ctx.short_addr,
ZB_APS_ADDR_MODE_16_ENDP_PRESENT,
bulb_ctx.endpoint,
LIGHT_SWITCH_ENDPOINT,
ZB_AF_HA_PROFILE_ID,
ZB_ZCL_DISABLE_DEFAULT_RESPONSE,
cmd_id,
NULL);
