Distinguish new connection from previous
I am developing a wearable device that utilises nRF51822. Right now, I am having a problem because when the wearable device is connected to a new phone, it needs to be able to know that and reset memory.
How should I go about distinguishing a new mobile phone from a re-connection to a previously bonded phone?
I tried to use the peer address to do this, but it changes everytime I disable then enable bluetooth on my iPhone.
  • Two other solutions come to mind:
    The first solution is only valid if memory isn't accessed before you bond. If you are bonded to the central, you will receive the BLE_GAP_EVT_SEC_INFO_REQUEST event when the central wants to encrypt the link, see this. If you are not bonded you will receive the BLE_GAP_EVT_SEC_PARAMS_REQUEST event when the central wants to bond, see this. You can use this event to trigger a memory reset.
    The second solution is to try to resolve the device address with the IRK(s) of the currently bonded central(s). Have a look at Ulrich's answer here. If you are able to resolve, don't reset memory, if you are not, reset memory.
