Hey guys,
I'm designing an antenna for our open source sensor beacon, RuuviTag: http://ruuvi.com
Because we're using 1/4 wavelength monopole antenna, I'm considering to drop the PI network based on what Nordic's nWP-017 antenna tuning white paper states:
There are the following two methods to tune an antenna:
If the physical dimensions of the antenna can be altered, for example, witha PCB antenna, adjusting the length will be one part of the tuning. Another part is to add a component, inductor, or capacitor, to pull the antenna impedance towards the 50 ohm center point.
If the antenna cannot be altered physically, more external components must be used to tune the antenna. These external components are called the matching network.
If it is not possible to get the impedance exactly 50 ohm by adjusting the length of the antenna, a component must be used to pull the impedance to the 50 ohm point. It is preferable to use a shunt capacitor since a capacitor is cheaper than an inductor and because a shunt component can be removed without any impact.
Layout (we've also an integrated NFC antenna):
Schematic:
github.com/.../ruuvitag_revb2_schematic.pdf
Antenna tuning will be done by adjusting the length of the antenna and assembling a suitable cap/inductor to pull the impedance towards 50 ohm. What I'm asking is that do you also think that this is an ok way to do it? nRF52 reference design has a 0.8pF capacitor and a 3.9nH inductor:
You can find everything from our GitHub organisation:
