Larger UpLink TBS size in LTE-M on nRF9161/51 ?
Greetings,
One question on the nRF9161/51 capabilities: is the 3GPP Rel-14 LTE-M Cat-M1 larger UpLink transport block size (TBS) of 2984 bits supported (instead of 1000 bits in Rel-13 Cat-M1) ?
Cf. Rel-14-defined ce-PUSCH-NB-MaxTBS-r14 Information Element (IE) reported by the UE.
François.
    Which 3GPP Rel 13 and Rel 14 Technical Specifications do you refer to? Can you provide links to relevant pages/tables in those documents?
    Dejan
    This evolution was introduced in Rel-14 for LTE-M, in the UpLink only.
    Please refer to the following GSMA documentation :
    Mobile IoT Deployment Guide
    https://www.gsma.com/solutions-and-impact/industries/smart-mobility/wp-content/uploads/2022/10/Mobile-IOT-Deployment-Guide-October-2022-1-1.pdf
    More precisely §5.2 LTE-M Specific features, section « Higher UL peak rate » :
    Higher UL peak rate
    This Release 14 feature introduces support for a larger transport block size (TBS) of 2984 bits instead of 1000 bits in order to increase the UL peak rate for Cat-M1. Increasing the UL TBS is not expected to increase the UE complexity significantly but will provide an UL peak rate boost which may be particularly useful in DL-heavy TDD configurations.
    Recommendations
    It is recommended Higher UL peak rate for LTE-M be supported by both the network and devices.
    From what I understand this is specified by 3GPP TS36.213, §8.6.1 & §8.6.2 (the ce-pusch-nb-maxTbs IE element is mentioned there).
    It points to Table 8.6.1-2A which was added in Rel-14
    For a BL/CE UE
    -    if the UE is configured with CEModeA, and higher layer parameter ce-pusch-nb-maxTbs-config configured with value 'On', and if the MPDCCH corresponding to the PUSCH transmission is located in UE-specific search space, the modulation order is determined according to table 8.6.1-2A.
    -    elseif the UE is configured with higher layer parameter ce-pusch-nb-maxTbs-config with value 'On', and if the MPDCCH corresponding to the PUSCH transmission is located in UE-specific search space, the UE shall first determine the TBS index () usingand Table 8.6.1-2A;
    Table 8.6.1-2A: Modulation and TBS index table for PUSCH
    MCS Index
    Modulation Order
    TBS Index
    0
    2
    0
    1
    2
    2
    2
    2
    4
    3
    2
    5
    4
    2
    6
    5
    2
    8
    6
    2
    10
    7
    4
    10
    8
    4
    12
    9
    4
    14
    10
    4
    16
    11
    4
    17
    12
    4
    18
    13
    4
    19
    14
    4
    20
    15
    4
    21
    Hope this helps.
    François.
  • Hi François,
    I have asked internally for more information about this. I will get back to you by the end of the next week.
    Dejan
  • Hi François,
    Unfortunately, our nrf91 product series does not support described capability.
    Dejan
  • Hello Dejan,
    Noted. Thanks for your support.
    François.
