ive been having a problem since yesterday with building procedure. Those are the errors that im having, I cant actually build any project even samples, i dont remember doing anything with files from zephyr/nrf. I was basically developing simple app with UART, but most ive done was using KConfig and devicetree from config point of view.
[3/150] Generating include/generated/version.h
-- Zephyr version: 3.4.99 (/home/hubert/ncs/zephyr), build: v3.4.99-ncs1-2
[34/150] Building C object CMakeFiles/app.dir/src/main.c.obj
In file included from /home/hubert/ncs/HUBERT_PRAKTYKI/Uart_P1/src/main.c:2:
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:471:15: warning: 'uart_err_check' declared 'static' but never defined [-Wunused-function]
471 | __syscall int uart_err_check(const struct device *dev);
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:508:15: warning: 'uart_poll_in' declared 'static' but never defined [-Wunused-function]
508 | __syscall int uart_poll_in(const struct device *dev, unsigned char *p_char);
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:542:15: warning: 'uart_poll_in_u16' declared 'static' but never defined [-Wunused-function]
542 | __syscall int uart_poll_in_u16(const struct device *dev, uint16_t *p_u16);
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:577:16: warning: 'uart_poll_out' declared 'static' but never defined [-Wunused-function]
577 | __syscall void uart_poll_out(const struct device *dev,
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:603:16: warning: 'uart_poll_out_u16' declared 'static' but never defined [-Wunused-function]
603 | __syscall void uart_poll_out_u16(const struct device *dev, uint16_t out_u16);
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:637:15: warning: 'uart_configure' declared 'static' but never defined [-Wunused-function]
637 | __syscall int uart_configure(const struct device *dev,
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:672:15: warning: 'uart_config_get' declared 'static' but never defined [-Wunused-function]
672 | __syscall int uart_config_get(const struct device *dev,
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:869:16: warning: 'uart_irq_tx_enable' declared 'static' but never defined [-Wunused-function]
869 | __syscall void uart_irq_tx_enable(const struct device *dev);
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:890:16: warning: 'uart_irq_tx_disable' declared 'static' but never defined [-Wunused-function]
890 | __syscall void uart_irq_tx_disable(const struct device *dev);
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:946:16: warning: 'uart_irq_rx_enable' declared 'static' but never defined [-Wunused-function]
946 | __syscall void uart_irq_rx_enable(const struct device *dev);
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:967:16: warning: 'uart_irq_rx_disable' declared 'static' but never defined [-Wunused-function]
967 | __syscall void uart_irq_rx_disable(const struct device *dev);
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:1058:16: warning: 'uart_irq_err_enable' declared 'static' but never defined [-Wunused-function]
1058 | __syscall void uart_irq_err_enable(const struct device *dev);
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:1079:16: warning: 'uart_irq_err_disable' declared 'static' but never defined [-Wunused-function]
1079 | __syscall void uart_irq_err_disable(const struct device *dev);
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:1105:15: warning: 'uart_irq_is_pending' declared 'static' but never defined [-Wunused-function]
1105 | __syscall int uart_irq_is_pending(const struct device *dev);
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:1148:15: warning: 'uart_irq_update' declared 'static' but never defined [-Wunused-function]
1148 | __syscall int uart_irq_update(const struct device *dev);
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:1284:15: warning: 'uart_tx' declared 'static' but never defined [-Wunused-function]
1284 | __syscall int uart_tx(const struct device *dev, const uint8_t *buf,
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:1323:15: warning: 'uart_tx_u16' declared 'static' but never defined [-Wunused-function]
1323 | __syscall int uart_tx_u16(const struct device *dev, const uint16_t *buf,
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:1357:15: warning: 'uart_tx_abort' declared 'static' but never defined [-Wunused-function]
1357 | __syscall int uart_tx_abort(const struct device *dev);
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:1393:15: warning: 'uart_rx_enable' used but never defined
1393 | __syscall int uart_rx_enable(const struct device *dev, uint8_t *buf,
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:1436:15: warning: 'uart_rx_enable_u16' declared 'static' but never defined [-Wunused-function]
1436 | __syscall int uart_rx_enable_u16(const struct device *dev, uint16_t *buf,
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:1545:15: warning: 'uart_rx_disable' declared 'static' but never defined [-Wunused-function]
1545 | __syscall int uart_rx_disable(const struct device *dev);
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:1576:15: warning: 'uart_line_ctrl_set' declared 'static' but never defined [-Wunused-function]
1576 | __syscall int uart_line_ctrl_set(const struct device *dev,
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:1610:15: warning: 'uart_line_ctrl_get' declared 'static' but never defined [-Wunused-function]
1610 | __syscall int uart_line_ctrl_get(const struct device *dev, uint32_t ctrl,
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:1647:15: warning: 'uart_drv_cmd' declared 'static' but never defined [-Wunused-function]
1647 | __syscall int uart_drv_cmd(const struct device *dev, uint32_t cmd, uint32_t p);
[83/150] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
In file included from /home/hubert/ncs/zephyr/drivers/serial/uart_nrfx_uarte.c:11:
/home/hubert/ncs/zephyr/include/zephyr/drivers/uart.h:1393:15: warning: 'uart_rx_enable' declared 'static' but never defined [-Wunused-function]
[145/150] Linking C executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /home/hubert/ncs/HUBERT_PRAKTYKI/Uart_P1/build_1/zephyr/zephyr_pre0.map
: && ccache /home/hubert/zephyr-sdk-0.16.3_linux-x86_64/zephyr-sdk-0.16.3/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -fuse-ld=bfd -T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=/home/hubert/ncs/HUBERT_PRAKTYKI/Uart_P1/build_1/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/picolibc/liblib__libc__picolibc.a zephyr/lib/libc/common/liblib__libc__common.a zephyr/soc/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/soc/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/segger/libmodules__segger.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a -L"/home/hubert/zephyr-sdk-0.16.3_linux-x86_64/zephyr-sdk-0.16.3/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m/nofp" -L/home/hubert/ncs/HUBERT_PRAKTYKI/Uart_P1/build_1/zephyr -lgcc zephyr/arch/common/libisr_tables.a -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -Wl,-no-pie -DPICOLIBC_INTEGER_PRINTF_SCANF /home/hubert/ncs/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/soft-float/no-interrupts/libnrf_cc310_platform_0.9.18.a --specs=picolibc.specs -lc -lgcc && cd /home/hubert/ncs/HUBERT_PRAKTYKI/Uart_P1/build_1/zephyr && /usr/bin/cmake -E true
/home/hubert/zephyr-sdk-0.16.3_linux-x86_64/zephyr-sdk-0.16.3/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `main':
/home/hubert/ncs/HUBERT_PRAKTYKI/Uart_P1/src/main.c:162: undefined reference to `uart_rx_enable'
collect2: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: /usr/bin/cmake --build /home/hubert/ncs/HUBERT_PRAKTYKI/Uart_P1/build_And in output TAB(VSC): Ive tried earlier to change toolchain or update it, i got an errors, but i don't think it is caused by git version
[15:33:51] =========== Toolchain validation report for Zephyr SDK 0.16.3 =========== 📦 Using the nRF Connect SDK v2.5.2 at /home/hubert/ncs ️❗️ gn is not found, but required if you wish to build Matter applications. This can be ignored otherwise. 🕒 git is outdated. Found 2.34.1, but 2.37.3 is required by the SDK. [15:38:47] west build --build-dir /home/hubert/ncs/HUBERT_PRAKTYKI/Uart_P1/build_1 /home/hubert/ncs/HUBERT_PRAKTYKI/Uart_P1 --pristine --board nrf52840dk_nrf52840 --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DCACHED_CONF_FILE=/home/hubert/ncs/HUBERT_PRAKTYKI/Uart_P1/prj.conf -DDTC_OVERLAY_FILE=/home/hubert/ncs/HUBERT_PRAKTYKI/Uart_P1/nrf52840dk_nrf52840.overlay [15:38:53] Failure (code 1). [15:39:47] west build --build-dir /home/hubert/ncs/HUBERT_PRAKTYKI/Uart_P1/build_1 /home/hubert/ncs/HUBERT_PRAKTYKI/Uart_P1 --pristine --board nrf52840dk_nrf52840 --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DCACHED_CONF_FILE=/home/hubert/ncs/HUBERT_PRAKTYKI/Uart_P1/prj.conf -DDTC_OVERLAY_FILE=/home/hubert/ncs/HUBERT_PRAKTYKI/Uart_P1/nrf52840dk_nrf52840.overlay [15:39:51] Failure (code 1).
Steps that i've already done:
- Run west -v update - nothing special happens
- Tried to change toolchain(u can see errors above)
- Checked disk space( not a problem )
- updated git
-swapped toolchain from zephyr SDK 16.0.3(that i was working with) to NRF connect SDK 2.6.1
-tried various KConfigs for UART
-tried many samples from zephyr/nrf- everywhere are errors.
The funny thing is that it was actually building 2 days ago, i just booted Ubuntu yesterday and it started...
