Hi, I am working with ncs v2.6.0 and I face the same issue than this post :
https://devzone.nordicsemi.com/f/nordic-q-a/98765/weird-nrf5340-behavior/420856?focus=true
My complete log is the following :
warning: Experimental symbol BT_LL_SW_SPLIT is enabled. warning: ENTROPY_NRF5_RNG (defined at drivers/entropy/Kconfig.nrf5:14) has direct dependencies !ENTROPY_NRF_FORCE_ALT && DT_HAS_NORDIC_NRF_RNG_ENABLED && ENTROPY_GENERATOR with value n, but is currently being y-selected by the following symbols: - BT_LLL_VENDOR_NORDIC (defined at subsys/bluetooth\controller\Kconfig.ll_sw_split:8), with value y, direct dependencies SOC_COMPATIBLE_NRF && !n && !n && BT_LL_SW_SPLIT && BT_CTLR && BT_HCI && BT (value: y), and select condition SOC_COMPATIBLE_NRF && !n && !n && BT_LL_SW_SPLIT && BT_CTLR && BT_HCI && BT (value: y) error: Aborting due to Kconfig warnings
The difference is I don't have CONFIG_BT_CTLR=y in my prj.conf. nor any file in the project. Here is my prj.conf :
# Peripheral drivers
# I2C
CONFIG_NRFX_TWI0=y
CONFIG_NRFX_TWI1=y
# Timer
CONFIG_NRFX_TIMER2=y
# GPIO
CONFIG_NRFX_GPIOTE0=y
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=5
# Flash
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# Others
CONFIG_NRFX_PWM0=y
CONFIG_NRFX_SPI0=y
CONFIG_NRFX_UART0=y
CONFIG_NRFX_NVMC=y
# Power management
CONFIG_POWEROFF=y
CONFIG_RESET_ON_FATAL_ERROR=y
# Logging
CONFIG_USE_SEGGER_RTT=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME_DYNAMIC=y
# CONFIG_BT_CTLR_CONN_RSSI=y
# CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y
CONFIG_BT_MAX_CONN=1
# Enable printf floating point support beware this take up to 7ko of flash
CONFIG_CBPRINTF_FP_SUPPORT=y
# Build options
CONFIG_BUILD_NO_GAP_FILL=y
CONFIG_MAIN_STACK_SIZE=8192
The only way to get rid of the warning (that prevents the build) is to move CONFIG_BT=y to cpunet_defconfig, but I see that the ble_coex sample have CONFIG_BT=y in its prj.conf so it should do.
I am trying to compile a legacy code that was ported to Zephyr/nrfconnect and is working on nRF52832. I just took the nrf7002dk_nrf5340 board and was hoping to make it work (taken appart code incompatibilities but at least to have a viable configuration). There might be dependencies with nrf_rng driver in the code, but KConfig warnings occurs BEFORE compilation right? It doesn't know the actual implementation? I would really appreciate some explanations.
Thank you very much
